Calculation of InAS WurtZite bragg peak position
The calculation of the InAs Wurtzite Bragg peak position involves determining the distance between the (1 0 3/2)sur layers using the cubic coordinates conversion (1 0 3/2)sur = (7/6 7/6 -5/6)cubic. The distance can be calculated with the formula d = 2π/Ghkl = acub / (sqrt(123/36)). To find the angle of reflection, Bragg's law (2dsin(angle) = wavelength) is applied. For ease, users can utilize PowderCell software to automate these calculations.
  • Understanding of Wurtzite crystal structures
  • Familiarity with Miller indices and their application in crystallography
  • Knowledge of Bragg's law for diffraction analysis
  • Experience with PowderCell software for crystallographic calculations
  • Learn how to convert between cubic and Wurtzite coordinates in crystallography
  • Study the application of Bragg's law in X-ray diffraction experiments
  • Explore the use of PowderCell for calculating diffraction patterns
  • Read Busing and Levy (1967) for detailed methods on calculating diffractometer angles
Researchers in materials science, crystallographers, and anyone involved in the analysis of Wurtzite structures and their diffraction properties.
poul
Hey
If I have a InAs Wurtzite structure, and now the a and c parameter from tables. How can i calculate the distance between (1 0 3/2)_sur layers? (in surface coordinates)
I need it to find the angle of reflection, for a (1 0 3/2) WZ InAs peak.
Is it just so simple?
(1 0 3/2)_sur = (7/6 7/6 -5/6)_cubic (in cubic coordinates)
And then the distance is just
d=2*pi/G_hkl= a_cub / (sqrt(123/36))
And then i can just use braggs law
2dsin(angle)=wavelength
Not a 100% sure what you are asking, but as I understand it you want to find the 2θ angle of your peak in a diffractogram?
If so the calculation should be straight forward. I.e. use whatever miller indice you want, find the corresponding d- value (i.e. plane spacing) for your specific lattice and then use Bragg's law.
Keep in mind that the Wurtzite structure is hcp and the commutative restraints that puts on Miller indices.
Or you could just download PowderCell, enter the structure data, and let it calculate it for you!
If I misunderstood you, please let me know and I'll see if I can help.
Hope this is of use!
If you only want the scattering angle, then yes, it is that easy.
Otherwise you have to figure out the exact relation between the standard and surface reciprocal space bases.
How to calculate diffractometer angles from that is very nicely described by Busing and Levy (1967).
http://scripts.iucr.org/cgi-bin/paper?a05492
