Calculating force of hydraulic cylinder
The discussion revolves around calculating the force generated by expanding air due to heating it to 800 degrees Celsius in a Lamina Flow Stirling engine. The user has calculated the moment of inertia and kinetic energy of a flywheel but incorrectly equates force with energy, leading to confusion in pressure calculations. Key thermodynamic principles are applied, but the user struggles with unit consistency and the relationship between pressure, force, and energy. Clarification on how the piston connects to the flywheel is requested to provide better assistance. The conversation highlights the importance of accurate unit usage and understanding thermodynamic relationships in mechanical systems.
CognitiveNet
I want to calculate the force generated (as a result of expanding air) from pressure created by heating air up to a maximum temperature of 800 degrees Celsius.
My flywheel with a radius of 0,030m is rotating at a speed of 850RPM and weights 0,27Kg.
Angular velocity: w=850RPM*(2pi/60)=89rad/s
Moment of inertia of the flywheel: I=0,5*m*r^2=0,5*0,27*0,030^2=0,0001215 kgm^2
Kinetic energy: Ek=0,5*I*w^2=0,5*0,0001215*89^2=0,48N
Now I use Thermodynamics to calculate the supplied heat.
The room temperature is 20 degrees Celsius and the piston is 0,020m in diameter.
Area of piston: pi/4 *d^2=pi/4 *0,020^2=pi*10^-4
Force acting on piston due to the pressure inside the cylinder: F=P*A
I'm assuming this force is equal to the kinetic energy stored in the flywheel.
Thus P=F/A=0,47N/pi*10^-4=1527Pa
P1*V1/T1=P2*V2/T2
(Excluding the volumes because I just care about the initial kinetic force)
Pa = Normal atmospheric pressure at 20 degrees Celsius (or 293 Kelvin)
Thus T2=P2*T1/P1=1527Pa*293K/101300Pa=4K IMPOSSIBURU!
But the supplied heat is at least 800 degrees Celsius.
Assuming all of the heat is transferred into the air inside the cylinder, that's equal to 1073K.
Please tell me what's going on here. I have the feeling that I don't know how to calculate how much force the air is acting on the piston, as a result of an increase of pressure due to the increase of temperature.
Your units are not correct. Energy has the dimension of Force x distance and units in MKS are Joules.
This is also dimensionally incorrect. Force cannot equal energy.
You have not explained the problem very well. Perhaps if you explained exactly how the piston is connected to the flywheel, we might be able to help you out.
AM
AM
It's a Lamina Flow Stirling, or a thermodynamic stirling.
Thread 'Gauss' law seems to imply instantaneous electric field propagation'
Imagine a charged sphere at the origin connected through an open switch to a vertical grounded wire. We wish to find an expression for the horizontal component of the electric field at a distance ##\mathbf{r}## from the sphere as it discharges. By using the Lorenz gauge condition: $$\nabla \cdot \mathbf{A} + \frac{1}{c^2}\frac{\partial \phi}{\partial t}=0\tag{1}$$ we find the following retarded solutions to the Maxwell equations If we assume that...
Thread 'Griffith, Electrodynamics, 4th Edition, Example 4.8. (First part)'
I am reading the Griffith, Electrodynamics book, 4th edition, Example 4.8 and stuck at some statements. It's little bit confused. > Example 4.8. Suppose the entire region below the plane ##z=0## in Fig. 4.28 is filled with uniform linear dielectric material of susceptibility ##\chi_e##. Calculate the force on a point charge ##q## situated a distance ##d## above the origin. Solution : The surface bound charge on the ##xy## plane is of opposite sign to ##q##, so the force will be...
Dear all, in an encounter of an infamous claim by Gerlich and Tscheuschner that the Greenhouse effect is inconsistent with the 2nd law of thermodynamics I came to a simple thought experiment which I wanted to share with you to check my understanding and brush up my knowledge. The thought experiment I tried to calculate through is as follows. I have a sphere (1) with radius ##r##, acting like a black body at a temperature of exactly ##T_1 = 500 K##. With Stefan-Boltzmann you can calculate...
