What Is the Torque When the Line of Force Intersects the Center of Rotation?
The discussion revolves around the concept of torque, specifically when the line of force intersects the center of rotation. Participants are exploring the implications of this intersection on the calculation of torque.
  • Participants are attempting to understand the relationship between the line of force and the center of rotation, questioning how this affects the torque calculation. There are discussions about the formula for torque and the significance of the perpendicular distance from the pivot point to the line of force.
The conversation is ongoing, with participants raising questions about the application of force and the resulting torque. Some guidance has been offered regarding the relationship between the force vector and the position vector, but there is no explicit consensus on the implications of the intersection for torque.
Participants are grappling with the concept of torque in relation to a specific setup involving a rod and the application of force. There is mention of a pressure scenario affecting the entire stick, which introduces additional complexity to the discussion.
medo_andnino
what is the torque if you know the the line of force intersects the center of the rotation ?
I think the torque will be T= ( f*sin (45) )*d
But I'm not sure will there be a torque or not ...the intersection of virtual line of force with the center of rotation is confusing me !
About what point are you trying to find the torque?
about the center of the rod
In that case, what would the distance be in your formula for torque?
Torque is the ability of a force to rotate an object around a point.
T = F*r
The distance r is the perpendicular distance between the pivot point and the line of the force that works in on the point (virtual line).
So what is the perpendicular distance between the virtual line of force and the pivot point?
What now ??
medo_andnino said:
What now ??
Where is the force being applied? I assume that the point indicated, which is apart from the center. (1 m to the left and 1 m up from the center.)
The easy way is to just extend the line of the force and see that it intersects the axis of rotation. That should immediately tell you what the torque is, without the need for any calculation.
But if you want to calculate torques from each component separately, that's fine also. You'll get the same answer.
One thing to realize when calculating the torque using F*r*sinθ, is that θ is the angle between the force vector ([itex]\vec{F}[/itex]) and the position vector ([itex]\vec{r}[/itex]).
So you mean that the torque is going to be zero, right !
right...
T= ( f*sin (0) )*r
okay ... one more question to be fully understood the topic ...assume that this left stick is under a pressure (the whole stick) ... Now How can I calculate the torque
  • · Replies 25 ·
  • · Replies 35 ·
  • · Replies 17 ·
