Calculating horizontal distance using angle and max height
The discussion focuses on calculating the horizontal distance covered by the froghopper, Philaenus spumarius, during its record jump. The takeoff speed for the leap is established at 4.00 m/s, with a maximum height of 58.7 cm achieved at an angle of 58.0 degrees. To determine the horizontal distance, participants are guided to use the formulas v_y = v_0 * sin(θ) and v_x = v_0 * cos(θ), followed by calculating time using v_f = v_y + at. The final horizontal distance can be computed with s = v_x * t.
  • Understanding of projectile motion principles
  • Familiarity with trigonometric functions (sine and cosine)
  • Knowledge of kinematic equations
  • Basic algebra skills for solving equations
  • Study the derivation of projectile motion equations
  • Learn how to apply trigonometric functions in physics problems
  • Explore kinematic equations in greater depth
  • Practice calculating horizontal distances in various projectile scenarios
Students studying physics, educators teaching projectile motion, and anyone interested in the biomechanics of insect jumps.
kgianqu2
The froghopper, Philaenus spumarius, holds the world record for insect jumps. When leaping at an angle of 58.0 above the horizontal, some of the tiny critters have reached a maximum height of 58.7 above the level ground.
A)What was the takeoff speed for such a leap?
I got 4.00 m/s which was correct.
B)What horizontal distance did the froghopper cover for this world-record leap?
I really am not even sure how to attempt this.
Close! The answer should be 40 m/s. Use this form v_y = v_0 * sin(θ). Then, find d from this form:
v_f² = v_y² + 2ad
Then, you will need to use this form:
v_x = v_0 * cos(θ)
This gives you the time. Now, find the time using this form: v_f = v_y + at [You need to use part (a) to answer this question!] Finally, using the value of v_x and the time you found (given v_y), find the horizontal distance traveled.
s = v_x * t
When I answered 4.00m/s, mastering physics said it was correct.
I am not sure how to get time, but is v_x=36.7?
