Thanks for all the responses.
I have been trying to come up with a simple yet intuitive explanation, shorn of all mathematics, for this important concept in relativity.
My thoughts have led me to this description
- The Lorentz factor is 'the ratio of time passage rates (or time-speeds) between two observers'.
Is that a correct description of the Lorentz factor? Or too simplistic - i.e. does not cover all situations?
Or, if you consider this description obvious, inane or plain stupid, I would like to know that too.
This is really the reason for my original post - I am trying to validate my thinking about this. I didn't put the above description in my original post, to see if I could get validation or refutation of the same independently.
robphy said:
It is the time-dilation factor...
Suppose inertial observers A and B met at event O.
For any other event Q on B's worldline,
[tex]\gamma=\frac{\Delta t_{OQ,\ according\ to\ A}}<br />
{\Delta t_{OQ, \ according\ to\ B}},[/tex] as you wrote.
In other words,
[tex]\gamma=\frac{\mbox{number of A's ticks used to measure an elapsed time on B's worldline}}<br />
{\mbox{number of B's ticks used to measure an elapsed time on B's worldline}}.[/tex]
It is analogous to the cosine of the angle between two unit vectors.
Given the 4-velocities [itex]\hat t_A[/itex] and [itex]\hat t_B[/itex] of observers A and B,
[tex]\gamma=\hat t_A \cdot \hat t_B =\cosh\theta_{between},[/tex] where [itex]\tanh\theta=v_{AB}[/itex] the relative-velocity.
I understand the mathematical explanation, but am looking for something more intuitive - i.e. something one can describe in simple English without the mathematics. Would like to know your opinion on the description I have given.
Mentz114 said:
My own view is that one has to abandon intuition when dealing with relativity. The idea that clocks do not record some universal time but that each one records the proper time along its own worldline is probably the most counter-intuitive concept ever introduced in physics...
No issues with the above statement. Still, among this counter-intuitiveness, I am trying to get an intuitive description of the 'Lorentz factor'. Let me know if you agree with the description I have given earlier in this post.
ghwellsjr said:
Instead of γ = dt/dτ, I like to think of dτ/dt = 1/γ, which applies to the tick rate of a moving clock with respect to the coordinate time of an inertial reference frame. The faster a clock moves, the slower it ticks.
From the SR definition perspective, completely agree. Is it the same thing as the description I have put?
harrylin said:
It's not just about time dilation, but a simple physical SR description is as ghwellsjr says: The faster a clock moves, the slower it ticks (according to the used reference system).
- robphy explained how it corresponds to a space-time rotation.
- alternatively it can be described as a conversion factor between measures of duration, length, etc. according to different inertial reference systems.
PS I just found the following presentation that could be helpful:
http://www.astro.ufl.edu/~vicki/AST3019/Special_Relativity.ppt
Understand. However, I am trying to see if we can describe it simply as a ratio of time rates between different observers, rather than being a conversion factor between other dimensions like length etc...
DaleSpam said:
I don't get the question. You know the definition of the Lorentz factor. The definition is the meaning, that's the whole reason why we make definitions.
What is the difference between the definition and the "real meaning"?
I think the other members who responded understood my question quite well. The description at the top of this post may help clarify what I was looking for...
DaleSpam said:
Do you somehow think that the standard definition is a facade that some conspiracy publishes and that if you know the secret handshake they will let you in and give you a different definition, the "real meaning"?
There
is a conspiracy. Unfortunately, it is hatched by the physical laws of the Universe, rather than any human agency. So I am not very hopeful that you will be able to help with the 'secret handshake code'...
Naty1 said:
I put this together for a previous post... ...agreed upon by all reference frames (i.e. is invariant under the Lorentz transform).
Thanks for the response. Is this ultimately same as the description I provided at the top of the post?
Bill_K said:
Shhhh! You promised not to mention that...
Naty1 said:
I knew it! A secret 'physics society' on how stuff really works...
