- 9,561
- 2,681
harrylin said:Next we discussed what I called a "cheap trick": apparently Hamilton's model even has a discontinuity in the speed of light, right in the middle of a heavy body. As a physical model such a discontinuity is extremely ugly and it looks very unreasonable. Of course, the topic of this thread is slightly different, but also according to GR the following is a basic law of nature:
"A material particle upon which no force acts moves, according to the principle of inertia, uniformly in a straight line."6
To elaborate a little more and clarify that this has nothing to do with "vacuum" or not:
Suppose that the Earth has a tunnel right through, from one side to the other. Consider the kind of equation of motion that GR allows for a stone that falls through the centre of the Earth. And similarly, what "distant" descriptions of velocity as function of time does GR permit for a light ray passing through that hole. Right in the middle of the Earth, the space-time constants are "flat"; surely GR allows no infinitely rapid change in velocity at that point. That violates the law of inertia and the law of "local" constancy of the speed of light.
I thus came to the conclusion that even if Hamilton's model accurately matches predictions of currently verifiable observations, it does not correspond to the concepts of GR: it is the antithesis of Einstein's "stationary" space and as we understand Hamilton's model, it violates laws of nature that are fundamental to GR for common, "down to Earth" situations.
This I chalk up to your misunderstanding the points made in #2 and #3 of this thread. The river model only applies to two specific geometries. It can be applied outside the Earth (to excellent approximation), but its validity ceases as soon as you reach the earth. It doesn't matter whether you drill through the Earth or not - the fact that Earth is there means that below its surface you immediately deviate from the geometry the river model applies to. If, instead of the earth, you had a black hole with event horizon, then the river model would continue to apply. The Earth has no event horizon or singularity at all.
