Magnitude of frictional force during terminal velocity
The discussion revolves around the forces acting on a parachutist during free fall, specifically focusing on the frictional force experienced as the parachutist accelerates downward and reaches terminal velocity. The subject area includes dynamics and forces, particularly the concepts of net force, gravitational force, and frictional force.
  • Mixed
  • Participants explore the relationship between gravitational force and frictional force during different phases of the parachutist's descent, questioning how these forces interact when the parachutist reaches terminal velocity.
There is ongoing exploration of the forces involved, with some participants suggesting that the frictional force should equal the gravitational force at terminal velocity. Others express uncertainty about the calculations and the direction of forces, indicating a productive dialogue about the underlying physics principles.
Participants are navigating through the implications of Newton's laws and the definitions of net force, with some confusion regarding the signs and directions of the forces involved. There is also mention of homework constraints that may affect the depth of analysis.
Ace.
A parachutist, after jumping from the plane, is accelerating down with average acceleration of 1.6 m/s2 (relative to the ground). What is the force of friction slowing his motion is mass of the parachutist with his equipment is 124 kg? What is the frictional force when the parachutist reaches terminal velocity?
F = ma
F=ma
F=124 kg x 1.6 m/s2
F= 199.36 N [down]
Would the force of friction also be 199.36 N except in [up] direction because for every action there is an equal and opposite reaction?
What happens when he reaches terminal velocity? Wouldn't acceleration = 0 and cause force unbalance to equal to 0. Doesn't this mean the two forces of gravity and friction are equal but in opposite direction? So how do I find the frictional force upwards during terminal velocity?
Note that when F = ma is used the symbol F represents the RESULTANT force on the system.
Then when he is accelerating, resultant force (downwards) = weight - frictional force
and when he is moving at terminal speed, resultant force = 0.
F = ma
F=ma
F=124 kg x 1.6 m/s2
F= 199.36 N [down]
This is the net force acting down. There are 2 forces acting on the 'chutist. The net force is the vector sum of both.
No.
yes
yes
solve your last question!
Well...
Fg=ma
=124 kg x9.8m/s2 [down]
=1215.2 N[down]
This is force of gravity on the parachutist.
FNET = 199.36 N [down]
FNET = Fg + Ff
Ff = FNET - Fg
= 199.36 N[down] - 1215.2 N [down]​
= -1015.84 N [down]​
∴ Frictional force during Vterminal = 1015.84 N [up]
Ace. said:
Well...
Fg=ma
=1215.2 N[down]
FNET = Fg + Ff
Ff = FNET - Fg
This however is not right because frictional should be equal to gravity?
Am I overthinking everything and the frictional force at V_terminal is simply 1215.2 N [up] (magnitude of his weight).
EDIT: sorry for double posting, I accidentally clicked quote instead of edit and I don't know how to delete this
Yes - at terminal velocity friction must exactly "balance" weight force.
Okay, thank you.
Say Ace. it appears that you made an error in determining the direction of the friction force when the chutist is accelerating downward. One must be very careful in the use and interpretation of the minus sign. Please give this important topic some thought.
  • · Replies 16 ·
  • · Replies 21 ·
