Harmonic Motion Lecture: Deriving Equations
The discussion focuses on deriving equations related to harmonic motion, specifically for pendulum motion involving extended objects. The key equation presented is a second-order differential equation that describes the motion as simple harmonic motion (SHM). Participants express confusion about the term ω(initial)/Ω and its relevance to the solution of the equation. There is debate over whether the derived equation truly represents SHM, as it suggests a frequency that may change with amplitude, indicating potential non-linearity in the restoring force. Clarification is sought on the meaning of the ωi term and its implications for the model being discussed.
tonykoh1116
I had a lecture regarding harmonic motion.
he also derived equation related to pendulum motion with extended object and equation is following.(motion is a simple harmonic motion)
d^2θ/dt^2+(RcmMg)θ/I=0
θ(t) = θcos(Ωt)+(ω/Ω)sin(Ωt) where Ω is defined angular frequency oscillation for all types of pendulums and ω is defined angular frequency for all linear motion such as mass and spring system.
I don't get how he derived ω(initial)/Ω...
can anyone explain to me?
Welcome to PF;
Have you found the general solution to:$$\frac{d^2\theta}{dt^2}+\frac{MgR_{cm}}{I} \theta = 0$$...in a form that does not have that ##\frac{\omega_{i}}{\Omega}## in it?
But that does not look like SHM to me.
In SHM - the frequency does not change.
are you talking about
\vartheta(t)=Acos(\omegat+\phi)?
I don't know - was I?
That would be SHM all right.
You wanted to know about: θ(t) = θ cos(Ωt)+(ω/Ω)sin(Ωt)
Looking at it properly I see that the the equation seems to be saying:$$\theta(t)=\frac{\frac{\omega}{\Omega}\sin(\Omega t)}{1-\cos(\Omega t)}$$... which is nothing like SHM right?
What was it attempting to model? That equation of motion and boundary conditions must have come from somewhere. We need to know what the ωi term is supposed to represent. Is it an attempt to take into account the non-linearity of the restoring force in a pendulum (the frequency is amplitude dependent and, hence it is time dependent if it is decaying, for instance)
Hi there, im studying nanoscience at the university in Basel. Today I looked at the topic of intertial and non-inertial reference frames and the existence of fictitious forces. I understand that you call forces real in physics if they appear in interplay. Meaning that a force is real when there is the "actio" partner to the "reactio" partner. If this condition is not satisfied the force is not real. I also understand that if you specifically look at non-inertial reference frames you can...
This has been discussed many times on PF, and will likely come up again, so the video might come handy. Previous threads: https://www.physicsforums.com/threads/is-a-treadmill-incline-just-a-marketing-gimmick.937725/ https://www.physicsforums.com/threads/work-done-running-on-an-inclined-treadmill.927825/ https://www.physicsforums.com/threads/how-do-we-calculate-the-energy-we-used-to-do-something.1052162/
I have recently been really interested in the derivation of Hamiltons Principle. On my research I found that with the term ##m \cdot \frac{d}{dt} (\frac{dr}{dt} \cdot \delta r) = 0## (1) one may derivate ##\delta \int (T - V) dt = 0## (2). The derivation itself I understood quiet good, but what I don't understand is where the equation (1) came from, because in my research it was just given and not derived from anywhere. Does anybody know where (1) comes from or why from it the...
