Does Dark Energy Repel Light and Cause Damage?
  • Context: Undergrad
  • Thread starter Thread starter alext180
    Dark energy Light
The discussion clarifies that dark energy does not repel light or cause damage to objects through light beams. Instead, dark energy is a term used to describe the phenomenon causing the universe's accelerated expansion, which is better understood as a curvature constant in the General Relativity (GR) equations. This curvature, often referred to as "vacuum curvature," is a very small residual effect that does not dynamically interact with light. The expansion rate is minimal, approximately 1/140 of one percent every million years, and does not influence light in a damaging manner.
  • Understanding of General Relativity (GR) equations
  • Familiarity with the concept of curvature in spacetime
  • Knowledge of cosmological constants and their implications
  • Basic grasp of light behavior in expanding space
  • Research the implications of vacuum curvature in cosmology
  • Study the effects of the Cosmological Constant on cosmic expansion
  • Explore the relationship between redshift and the expansion of the universe
  • Learn about General Relativity and its equations in detail
Astronomers, physicists, and students of cosmology seeking to understand the nature of dark energy and its effects on the universe's expansion.
alext180
If dark energy repels things at the speed of light, does that mean if light energy is produced near it, it would repel it so hard and fast that it could actually damage things with a light beam? Basically what I'm asking is does dark energy repel light and if so could the light beams damage things?
Astronomy news on Phys.org
It hasn't been shown to actually be an energy, Alex. So the name is a bit misleading. What seems to fit the observations best so far is simply a curvature constant that appears in the GR equation. A very small residual curvature that is inherent in spacetime geometry. Not necessarily resulting from any mysterious "energy". Over the past couple of years some scientists have started preferring to call it "vacuum curvature" instead of "dark energy".
I can tell you the exact curvature if you want to know, it is measured in units of inverse area.
A curvature is the reciprocal of an area ("one over" some area expressed in square kilometers or square lightyears). So a very tiny built in curvature corresponds to a very big area. That is just how the Cosmological Constant happens to be expressed mathematically---it's a constant curvature.
It contributes to expansion and expansion is what stretches wavelengths and redshifts light, but this expansion is very very slight, only 1/140 of one percent every million years. And the inherent curvature has contributed so far only a fraction of that!
Otherwise the Cosmo curvature Constant does not affect light! It is very un-dynamic. Not a big deal. So you would not expect it to deflect light or cause physical effects like that.
I agree in general with what Drakkith said just now.
  • · Replies 73 ·
9K
  • · Replies 23 ·
