PeterDonis
Mentor
- 50,179
- 26,225
harrylin said:In fact that chart is an equation. You next suggest that another equation has more physical content than the equation which was derived from it, using reasonable physical assumptions.
No, I don't. I suggest that the first chart/equation (exterior Schwarzschild) does not cover a particular portion of the spacetime that the second chart/equation (Kruskal) does.
However, underlying all of this is just one equation, the EFE. That equation is what's really at issue here. See below.
harrylin said:If I correctly understood the explanations, those equations lead to white holes when blindly followed through without physical concerns; following your arguments, white holes are "really GR".
You didn't correctly understand the explanations. The EFE leads to white holes only if we assume the spacetime is vacuum everywhere (and spherically symmetric, but that's a minor point for this discussion). Nobody thinks that assumption is physically reasonable. If the spacetime is not vacuum everywhere--for example, if there is collapsing matter present--then the EFE does *not* predict white holes. So white holes are part of the set of all possible mathematical solutions of the EFE, but they are not part of the set of physically reasonable solutions of the EFE.
Just an "equation" isn't enough; you have to add constraints--initial/boundary conditions--to get a particular solution. Which solution of the equation you get--i.e., which spacetime geometry models the physical situation you're interested in--depends on the constraints.
harrylin said:However, and as we discussed earlier, we agree that considerations of what makes physical sense should play a role. Most theories do contain more than mere equations, and GR is no exception. For me a theory consists of its physical foundations (both those postulated and those clearly mentioned).
Of course. See above.
harrylin said:Those foundations are all kept except if they lead to contradictions; and an equation is only physically valid insofar as those physical foundations are not violated. An obvious one is the Einstein equivalence principle, but there are also the physical reality of gravitational fields and the requirement that theorems must describe the relation between measurable bodies and clocks.
Sure.
harrylin said:Consequently I expect that Einstein would reject Peter's argument and say that Peter denies the physical reality of gravitational fields.
Einstein *did* reject arguments of this type. Einstein was wrong.
harrylin said:Einstein would argue that the clock's worldline never really stops, but does not reach beyond 42 due to the physical reality of the gravitational field.
What is "the gravitational field"? What mathematical object in the theory does it correspond to? Before we can even evaluate this claim, we have to know what it refers to. But let's try it with some examples:
(1) The "gravitational field" is the metric. The metric (the coordinate-free geometric object, not its expression in particular coordinates) is perfectly finite and continuous at the horizon, and for reasons that both PAllen and I have explained, it can't "just stop" at the horizon without violating the EFE.
(2) The "gravitational field" is the Riemann curvature tensor. Like the metric, this is perfectly finite and continuous at the horizon.
(3) The "gravitational field" is the proper acceleration experienced by a "hovering" observer (an observer who stays at the same radius and does not move at all in a tangential direction). This *does* increase without bound as you get closer and closer to the horizon. However, there is *no* "hovering" observer *at* the horizon, because the horizon is a null surface: i.e., a line with constant r = 2M and constant theta, phi is not a timelike line; it's a null line (the path of a light ray--a radially outgoing light ray). So there is no observer who experiences infinite proper acceleration, and this definition of "gravitational field" simply doesn't apply at or inside the horizon.
As far as I can see, the only possible basis you could have for claiming that "the physical reality of the gravitational field" means that the clock's worldline stops as tau->42, would be #3. However, #3 doesn't apply to infalling observers; it only applies to accelerated, "hovering" observers. Infalling observers don't feel any acceleration, so there's nothing stopping them from falling through the horizon. The "gravitational field" in the sense of #3 is simply not felt by them at all.
Note that in all these cases, the physical "field" has to correspond to something invariant in the mathematical model, *not* something that only exists in a particular coordinate chart. That is something Einstein would have *agreed* with. Note also that none of the definitions of "gravitational field" I gave above used Schwarzschild coordinate time, or the fact that t->infinity as you approach the horizon. Einstein simply didn't understand that claims about t->infinity as you approach the horizon were claims about something that only exists in a particular coordinate chart.
harrylin said:I think that Kruskal's white holes and his inside solution for black holes are not compatible with Einstein's GR.
See above. You are equivocating on different meanings of "Einstein's GR". White holes are mathematically compatible, but not physically reasonable. Black hole interiors are both mathematically compatible *and* physically reasonable.
harrylin said:And don't you think that Einstein would have exclaimed the same, if it was really a "gross violation of the principle of equivalence"? Instead he commented that "there arises the question whether it is possible to build up a field containing such singularities". (E. 1939.)
As I've said before, Einstein's paper only considered the stationary case--i.e., he only considered systems of matter in stable equilibrium. All his paper proves is that *if* a system has a radius less than 9/8 of the Schwarzschild radius corresponding to its mass, the matter can't be in stable equilibrium. A collapsing object that forms a black hole meets this criterion: the collapsing matter is not in stable equilibrium. So Einstein's conclusion doesn't apply to it.
