The Nuclear Power Thread
The discussion focuses on nuclear power, particularly in the context of its viability, environmental impact, and the challenges associated with spent fuel management. Participants explore various aspects of nuclear energy, including its safety, economic implications, and comparisons to fossil fuels, as well as the future of nuclear technology and research.
  • Some participants argue that nuclear power is essential for energy generation and that the arguments against it are often based on ignorance and emotion.
  • Concerns are raised about the management of spent nuclear fuel, with some suggesting that it is a significant unresolved issue.
  • Others propose that spent fuel is not as problematic as perceived, noting that the majority of nuclear waste comes from the weapons industry and that large-scale nuclear energy production could be managed with less health impact than fossil fuels.
  • There are claims that nuclear energy is not as environmentally friendly as often portrayed, particularly due to greenhouse gas emissions associated with uranium enrichment.
  • Participants discuss the safety of nuclear plants, with some expressing confidence in current safety measures while acknowledging the potential for human error and the risk of terrorism.
  • Economic considerations are debated, with some asserting that only electric companies benefit from nuclear power, while consumers may not see the same advantages.
  • There is mention of ongoing research into nuclear technology, including fusion reactors, which some believe could provide a more sustainable solution in the future.
Participants express a range of views on the benefits and drawbacks of nuclear power, with no clear consensus on its overall viability or the best path forward for energy generation. Disagreements persist regarding the environmental impact, safety, and economic implications of nuclear energy.
Participants highlight various limitations in the discussion, including the complexity of nuclear waste management, the dependence on definitions of safety and environmental impact, and the unresolved nature of certain technical and economic aspects of nuclear power.
  • #451
wizwom said:
Actual capacity factors are much lower - more on the order of 25.
http://en.wikipedia.org/wiki/Capacity_factor.
The source you cite does not really support your assertion. Perhaps you can find another one.
  • #452
zapperzero said:
I was being charitable.
Regarding "Nuclear is just a bit more expensive than wind"? My point was that nuclear might be considerably more expensive than wind for the moment.
  • #453
Yes, this is my impression as well. I do not see a rush of investors into nuclear. Perhaps it is perceived as high-risk, post-Fukushima? What usually happens with high-risk ventures is the cost of financing increases.
I am baffled by the evolution of the price of uranium, though, long-term (or what constitutes long term for markets, in any case - the past 15 years). Seems there was a bubble in '05-'07, then a slow meltdown (pun intended).
  • #454
Wind is much smaller scale; you can reasonable do one 10 KW rated wind turbine and expect they same payback and profitability as a farm of 100 MW.
Nuclear, because you need licensing and staffing, is decidedly NOT entirely scalable.
Since these costs are fairly constant, there is no reason to go small.
But total lifecycle cost for nuclear is around 6 cents a KWh; for wind it is more like 17.
  • #455
Maybe you can source this statement?
  • #456
That is not realistic, the small wind turbine will certainly cost more per kWh produced, just like a 200 MW farm will produce more cheaply than a 100 MW farm. Last time I looked, 1 million Euro would buy about 1 MW capacity (looking for a current commercial wind turbine in the ~2 MW size) Typically such a machine would be designed/sited to maximize energy yield per Euro invested at a capacity factor of about 0.25-0.40, so that over an expected life time of 20 years it would produce 45-70 million kWh per installed MW. Even assuming the project price would mount to as much as double the price of the wind turbine, that would still be only about 3-4 cents a kWh. To be sure there are different estimates out there, but I don't know how you get it to be 17 cents a kWh, it doesn't look like anything I've seen elsewhere.
  • #457
A quick survey shows a 100kW turbine at $35,000 & a 10kW at $7,000; s expected, prices are all over. The IEA report from 2011 http://www.nrel.gov/docs/fy12osti/53510.pdf puts the total cost at $1500-$2000 per installed rated kW
Capacity factors are in the 25-30% range; the 40% was never seen anywhere, even 35% was anomalous. This means that the cost per usable kW is now $5000-$7400.
That report shows the cost dropped to near 5 cents in 2007, but then has risen to 7c.
Sorry for the old data.
  • #458
russ_watters said:
snip
There may be a thread around here somewhere about it, but a few years ago, I did some calculations about solar and concluded that with good solar panels, we'd nee to cover an area of about 300 miles square - similar to your father's calculation of the entire state of Arizona.
snip
Sorry that my first post will be "off track" where this thread is currently but I simply had to register to point out this unbelievably huge mistake.
FYI- the state of Arizona covers 114,006 square miles. Much, much larger than the 300 square miles needed to power the entire US by your own calculations. Phoenix AZ covers roughly 500 square miles, so in exchange for giving up less land than a single large metro area we could power the US with a truly clean energy.
-hh
  • #459
What survey? Yours? This IEA report:
is for the *installed*, up and running cost for utility scale (>1MW) turbines. What source reports an installed cost for a 100kW turbine?
  • #460
-hh
Welcome to PF!
I didn't say "300 square miles", I said "300 miles square". As in - a square 300 miles on a side or 90,000 square miles. The reason I worded it that way is that most people can wrap their arms around the size better if you describe the dimensions, not the area.
  • #461
wizwom said:
Capacity factors are in the 25-30% range; the 40% was never seen anywhere, even 35% was anomalous. <..>.
IIRC, the world record for a single commercial wind turbine is a capacity factor of 44 % over a (so far) 9 year operation time. Danish offshore wind farms operate overall well above 35 %. Horns Rev II (a 209 MW farm) has performed best, with a capacity factor of about 47 %. The second best measured by capacity factor is Rødsand II (207 MW), at 42 %.
  • #462
Scotland and Denmark seem to be in really good spots for wind energy. Many coastal areas are.
US
http://rredc.nrel.gov/wind/pubs/atlas/
http://rredc.nrel.gov/wind/pubs/atlas/maps/chap2/2-06m.html
http://www.windpoweringamerica.gov/wind_installed_capacity.asp?&print
Canada
http://www.windatlas.ca/en/maps.php
Europe
http://www.windatlas.dk/europe/index.htm
http://www.windatlas.dk/europe/landmap.html
World
http://www.windatlas.dk/World/Index.htm
http://www.windatlas.dk/World/Atlases.html
This is not exactly nuclear power though.
  • #463
Astronuc said:
Scotland and Denmark seem to be in really good spots for wind energy. Many coastal areas are.<..>
No that's true, nuclear power tends to become irrelevant such places, unless nuclear load-following power can be produced economically. I don't know if new types of nuclear promise that. As soon as wind power is being viably produced in a region, the need will be for viable absorbers of the variability that is then inherently produced too, rather than for what nuclear traditionally has to offer.
  • #464
Nuclear energy is generally produced in base load, but the French do a lot of load following and frequency control with their nuclear units.
With wind at 50% availability one would twice the installed capacity on a kW basis to achieve the same kWh as compared to a unit that runs constantly at full power. Many nuclear units achieve 90+% capacity factor. Of course, there are some units that have poor performance.
If wind is only available at 35% or 20%, then the number of wind units greatly increases, as does the transmission infrastructure. If one looks at the various atlases, there are some areas that have great wind capability, but many larger areas that do not. In the US, the majority of population live in areas of relatively low wind availability.
  • #465
Astronuc said:
...In the US, the majority of population live in areas of relatively low wind availability.
That's true if US offshore wind potential is omitted. At the moment offshore wind is not economic nor technically practical on the US east coast due to hurricanes, but that may change w/ stronger wind tower designs.
  • #466
OK, yes, With the very high penetration of nuclear power in France there would be little other choice than to sacrifice on the capacity factor, such as to make the production fit the variable consumption, or alternatively export periodically against little demand from other countries. Perhaps France seen in isolation can be said to be oversupplied with nuclear power. By the same token, France might not be in a good position to start exploiting its available wind resources. (Newly added wind power would act in the system as additional consumption variation, only then from 'negative consumers')
I am not sure what you mean by availability of wind in this context, but you do seem to indicate it to be a measure comparable to the capacity factor of nuclear. The best wind sites over here may well have wind turbines operating at capacity factor about 50%, and in a mathematical sense that means that a same sized wind turbine or another system running at 100 % could replace two of such units. Or, could one say, one of the 50% capacity factor turbines replaces two turbines running at a capacity factor of 25 %. However, I am not sure what the superposition elucidates. Whether you look at a nuclear plant targeting a 90% capacity factor, or a wind turbine at a given site targeting a 50% capacity factor, in either case that target is an effect of economic optimisation.
Well, of course you can have too small and/or too distant wind resources left worth exploiting, and maybe that is the case in USA. Certainly the magnitude and quality of the wind resource at a given site strongly influence the economical viability of a wind power project, and the incorporation of such a project in the existing grid must of course make economic sense. However, I can see no problem with wind turbines operating at capacity factors of 35% or 20% if that now happens to be the economic optimum for the sites. About 30 GW of on average less capacity factor is operating onshore in Germany currently, I never thought that to be a problem. While the push has become for adding offshore wind power from the North Sea there will indeed be a need for another investment in the transmission infrastructure, but so what, I can't remember when there wasn't :-)
  • #467
WASHINGTON, Aug. 7, 2012 /PRNewswire-USNewswire/ - The U.S. Nuclear Regulatory Commission (NRC) acted today to put a hold on at least 19 final reactor licensing decisions – nine construction & operating licenses (COLS), eight license renewals, one operating license, and one early site permit – in response to the landmark Waste Confidence Rule decision of June 8th by the U.S. Court of Appeals for the D.C. Circuit.
The NRC action was sought in a June 18, 2012 petition filed by 24 groups urging the NRC to respond to the court ruling by freezing final licensing decisions until it has completed a rulemaking action on the environmental impacts of highly radioactive nuclear waste in the form of spent, or 'used', reactor fuel storage and disposal.
  • #468
First license for Canadian new build
http://www.world-nuclear-news.org/NN-First_licence_for_Canadian_new_build-2008127.html
The nuclear site preparation [Darlington] license issued to Onatrio Power Generation (OPG) will be valid for ten years, from 17 August 2012 to 17 August 2022.
Meanwhile, back in Washington DC - NRC suspends final licensing decisions
08 August 2012
Licences for US nuclear plants - including those for new construction and life extension - will not be issued until the Nuclear Regulatory Commission (NRC) addresses a court decision on waste confidence. However, licensing activities will continue as normal.
On 8 June, the US Court of Appeals for the District of Columbia found that the NRC's rules for the temporary storage and permanent disposal of nuclear waste stood in violation of the National Environmental Policy Act. This requires that either an environmental assessment or environmental impact statement be prepared for all major government agency actions.
Regarding the development of a waste facility, the court noted that 20 years of work towards building a repository was effectively abandoned when the Department of Energy withdrew its application for the Yucca Mountain repository in 2010, and that, "At this time there is not even a prospective site for a repository, let alone progress towards the actual construction of one."
and how many $billion wasted?
  • #470
http://www.world-nuclear-news.org/C_Coping_with_energy_transition_1411121.html
14 November 2012
EOn continues to struggle under German energy policy, with gas generation made "barely profitable" by pro-renewable market arrangements and nuclear generation slashed and taxed by government decree.
The utility has summarised its performance from January to the end of September, explaining to shareholders that it would honour dividend predictions for 2012, but would revise ambitions for 2013 and 2015. Despite a worsening outlook, the company still recorded pre-tax earnings of €8.8 billion ($11.2 billion) with 'underlying net income' of about €4 billion ($5.0 billion) for the first nine months of 2012.
One problem is that renewable generation is given priority access to the grid when it is available. This sometimes prevents gas-fired generation from operating during peak hours and has altered the economics of gas to such an extent that it is now "barely profitable to operate," said CEO Johannes Teyssen. "In most European markets, the gross margin for gas-fired units is approaching zero or is indeed already negative."
This an example of a poor energy and economic policy on the part of the German government, and it is harming the economy.
  • #471
German energy policy is constrained by anti nuclear sentiment on the one hand (fuelled by media support of a small cadre of activists plus public distrust sustained by unrelenting publicity focused on the nuclear industry's failures) along with the recognition that gas supply from Russia is unreliable (it was turned off just a couple of winters ago).
The fix is more coal fired power, because the 'green' alternatives are falling well short of requirements for reliability and quantity.
  • #472
mPower empowered by SMR funds
http://www.world-nuclear-news.org/NN-mPower_empowered_by_SMR_funds_121112a.html
Meanwhile
Alstom unveils world's longest turbine blade (for large low pressure (LP) steam turbines)
http://www.world-nuclear-news.org/C-Alstom_unveils_longest_turbine_blade-2011128.html
Also, note that Europe uses 50 Hz, to large turbines are usually 1500 RPM (although some are designed for 3000 rpm) rather than 1800 rpm used in 60 Hz systems.
In 3000 rpm turbines, the last stage blade length is on the order of 1.35 m
http://www.rwe.com/web/cms/mediablob/en/247554/data/235582/1/rwe-power-ag/nuclear-power/blob.pdf
  • #473
I have done work on the ALSTOM HP and LP coolers used in the GT-24 and GT-26 gas turbines. Lots of ASME code calcs ...
  • #474
Bethlehem-based Lehigh Heavy Forge Corp. teaming with N.C. company to make nuclear reactors
http://www.lehighvalleylive.com/bethlehem/index.ssf/2012/11/lehigh_valley_forge_teaming_wi.html
Bethlehem-based Lehigh Heavy Forge Corp. expects to add 100 jobs over the next 10 years through a partnership announced today with a North Carolina nuclear technology company.
The South Side foundry is teaming with the Babcock & Wilcox Co. to supply forgings for a new brand of small modular reactors being developed by B&W. Officials announced the partnership at an event joined by Pennsylvania Gov. Tom Corbett and local business and government officials.
  • #475
World Nuclear Association said:
On 2 December 1942 a team of 49 scientists led by Enrico Fermi started the world's first nuclear reactor. 70 years on two of team recounted their experiences in this video.
Argonne nuclear pioneers: Chicago Pile 1
  • #477
  • #478
New US Nuclear Builds
Vogtle 3 and 4 and V C Summer 2 and 3 (both twin AP1000 sites) are under construction.
Vogtle has been doing ground work for sometime.
On March 9, pouring of the basemat for Unit 2 commenced. It lasted about 50 hours as a continuous pour.
The basemat provides a foundation for the containment and auxilary buildings that are within the unit's nuclear island. Measuring 1.8 metres thick, the basemat required some 5350 cubic metres of concrete to cover an area about 76 metres by 49 metres. The concrete-pouring process took just over 50 hours and was completed at about 10.00am on 11 March.
http://www.world-nuclear-news.org/NN-AP1000_construction_underway_at_Summer-1203134.html
Update: March 13, 2013
Southern Nuclear began pouring the basemat at Vogtle 3, a day after SCANA/SCE&G began the pour at Summer 2. It takes about 50 hours to pour the basemat.
http://chronicle.augusta.com/news/metro/2013-03-13/concrete-poured-new-vogtle-reactor-foundation
Southern Nuclear has begun pouring of specially designed basemat concrete for the foundation of its Unit 3 Plant Vogtle reactor, just three days after similar steps were completed at SCANA’s V.C. Summer plant in South Carolina.
http://chronicle.augusta.com/news/m...eaviest-reactor-parts-moved-plant-vogtle-site
(Jan 24) The reactor vessel head, weighing 160 tons, serves as the “lid” of the Unit 3 reactor and will be bolted to the even-larger reactor vessel body – a 300-ton component that remains in Savannah, Ga., awaiting shipment to the site aboard a specially built rail car.
  • #479
Japan signs deal with Turkey to build nuclear plant
http://www.cnn.com/2013/05/04/world/europe/turkey-japan-nuclear/?iref=obinsite
(CNN) -- Turkey and Japan have agreed to a $22 billion deal to build a nuclear power plant in Turkey, the semi-official Turkish news agency Anadolu reported.
http://www.atmea-sas.com/scripts/ATMEA/publigen/content/templates/Show.asp?P=57&L=EN
Large LWRs of Gen 3 generation are on the order of 1.1 to 1.2 GWe. ATMEA is roughly the same capacity as Westinghouse's AP-1000.
  • #480
Iaea inpro
The International Project on Innovative Nuclear Reactors and Fuel Cycles (INPRO) was established in 2000 to help ensure that nuclear energy is available to contribute to meeting the energy needs of the 21st century in a sustainable manner. It is a mechanism for INPRO Members to collaborate on topics of joint interest. The results of INPRO's activities are being made available to all IAEA Member States.
http://www.iaea.org/inpro/
http://www.iaea.org/INPRO/about.html
INPRO Programme 2012-2013
Project 1: National Long Range Nuclear Energy Strategies
Project 2: Global Nuclear Energy Scenarios on Sustainable Nuclear Energy
Project 3: Innovations in Nuclear Technology
  • · Replies 0 ·
  • · Replies 26 ·
  • · Replies 20 ·
