How can a hydraulic steering be replaces the modern power steering system
The discussion centers around the feasibility and implications of replacing modern power steering systems with a purely hydraulic steering system. Participants explore the technical modifications required, the historical context of steering systems, and the potential advantages and disadvantages of such a conversion.
  • One participant inquires about the rationale behind pursuing a pure hydraulic steering system, questioning its necessity.
  • Another participant notes that pure hydraulic steering systems have existed since the 1970s, particularly in tractors, and suggests searching for hydrostatic steering systems for more information.
  • A historical perspective is provided, detailing the evolution of steering systems from mechanical to hydraulic-assisted, highlighting the impact of consumer preferences on automotive design.
  • Concerns are raised about eliminating the rack and pinion system entirely, as it serves as a backup in case of engine failure.
  • Some participants argue that farm tractors and cars have different operational contexts, with tractors designed for low-speed, straight-line travel, which may not translate to automotive applications.
  • There is a discussion about the driving experience with purely hydraulic steering, with some expressing concerns that it would reduce driver feedback and connection to the vehicle.
  • Examples of full hydraulic steering conversions for off-road vehicles are mentioned, noting their strength but also their drawbacks, such as lack of road feedback and complexity in setup.
  • It is noted that modern vehicles are increasingly moving towards electric power steering systems, suggesting that a full hydraulic setup may not be an advancement.
Participants express a range of views, with no consensus on the viability or desirability of a purely hydraulic steering system. Some support the idea while others raise significant concerns about its practicality and safety.
Participants highlight various limitations, including the different operational requirements of tractors versus cars, regulatory restrictions in the EU against pure hydraulic steering systems in vehicles, and the potential loss of driver feedback with a purely hydraulic system.
varun atri
Hi every one,
i am a mechanical engineer working on a project hydraulic steering :smile:. i want to know that in power steering systems it has been used. but the thing is as far i know that the modern power steering system uses a hydraulic cylinder in addition to the rack and pinion arrangement.o:)
i want to know that i am removing that pinion and rack system and want to make the steering system completely working on hydraulics o:) . could it be possible and what will be the modifications i have to make it to the system to make it working. Also does the load will affect the hydraulic system more as i have considered the frictional losses and many other power losses.
A +VE CRITISM IS ACCEPTED FROM THE EXPERTS OF THE FIELD AND ANY OTHER IDEAS AND MODIFICATION IS WELCOMED. :approve:
"ONLY ENGINEERS KNOWS HOW THINGS CAN BE CREATED AND DESTROYED"
May I ask why you're set on having a pure hydraulic steering system?
varun atri said:
Hi every one,
Hi,
a pure hydraulic steering system already exists since 70s. It is used on tractors.
Search on google hydrostatic steering system or hydroguide, you would find a lot of information
A bit of history is in order. Automobile and truck steering was strictly mechanical for years. The hydraulic assisted power steering was an expensive Option. As more woman began driving in the 1950s and 60s ( originally the task was solely male dominated ( early 1900s) and more and more of the purchasing public began selecting the automatic transmission and air conditioning, the auto manufacturers began packaging the more popular car models with “ standard options” a true oxymoron. Certain features were sold at attractive prices to give the purchasing public incentive to buy the car off the lot and avoid custom manufacturing of each automobile. This reduced delivery time and even more importantly, decreased time of customer order to payment. Cheap credit and option to finance the car purchase were also refined by the automobile manufacturers.
Anyway, it is pretty common to buy a car with automatic transmission, power steering and air conditioning now.
Todays power steering is not pure hydraulic but a hybrid with electric power steering pump and slave cylinder rack and pinion.
Why electric..ease of installation during assembly..no long drive belts, pulleys, tensioners, to install, reduced warranty as you eliminate squeaky belts, parasitic drag on the power plant, It pretty much goes back to lowest cost to install AND Maintain over the warrant period.
You wouldn't want to eliminate the rack and pinion completely because it serves as a back-up system in case of power (engine) failure.
as usual Russ..most excellent point...as a safety feature all automoblies have steering ability even when engine is turned off..
that's wrong. On farm tractors it's used a pure hydrostatic system and in this case, the rotating valve is used as a pump. To reduce the steering wheel effort, it is used systems with two gerotor,i.e. valves: a big valve and a small ones.
here it is explained a bit.
http://www.pirate4x4.com/tech/billavista/PR-Hydro_Steering/index2.html
A farm tractor is not a car. Farm tractors spend most of their lives going perfectly straight at 1mph (so no risk of a crash) and often (big ones) have wheels too large and buried in dirt to turn easily by hand.
Unfortunately the tractor usage in completely changed in the last 20 years. Tractors with more than 100 kW are used for more than 50% of their life on road and they run 65km/h.
Anyway the EU regulation doesn't permit to install pure hydraulic steering systems on cars.
I imagine it would be a terrible experience driving a car with purely hydraulic steering, as it would remove most of the feedback the driver gets and further disconnect him from the machine.
The feeling while tractor driving is completely different than while car driving. In fact a high speed tractor has a mechnical steering with hydraulic assistance. As example there are hydrostatic steering system that you have to rotate the steering wheel after having run a curve because it doesn't allineate by itself.
If you are interested in, take a look at the following paper, it is well explained it.
http://elibrary.asabe.org/azdez.asp?JID=3&AID=36248&CID=t2011&v=54&i=1&T=1&redirType=
Full hydraulic steering conversions are already available for 4x4's, take for example here here:
http://www.pscmotorsports.com/motorsport-specific-products/offroad/full-hydraulic-steering
Hydraulic steering has the advantage of being very strong, which is a big plus on off-road vehicles with big tires driving on big rocks, but they have drawbacks too. They don't have any "on-center feel", little road feeback, are difficult or impossible to use without the engine running, require complex hydraulic setups including fluid coolers, etc etc.
As it is modern cars are going away from hydraulic altogether in favor of straight electric for power steering assist. A full hydraulic setup is a step backwards in terms of road manners rather than a step forward.
  • · Replies 19 ·
  • · Replies 35 ·
