Dale
Mentor
- 36,909
- 15,903
This is so self contradictory that it doesn't even rise to the level of philosophy, let alone science.Bjarne said:Yes this is true…
But on the other hand, our reality begins (or end, - if you prefer) where the photons reality begin. From the perspective of the photon there can (mathematically) not exist distances, time, and I guess even not space, - it must be nothing.
To be extreme “reality” as a whole includes nothing and everything between nothing and everything, depending on space-time 'perspective'
It is at least attempting to talk about “different space-time realities” – because "they" can be so diffrent, - but is as you point out also not perfect to do so, - because "these" are not clear separated but rather “one” reality - ("separated" by time, - at least photons, neutrinos etc. seems to be) and as you see now I contradict what I Just wrote. .
https://www.physicsforums.com/showthread.php?t=511170Bjarne said:We can measure a photon existence, and the speed of it, - but seen from the photons own perspective, it doesn’t exist (in space and time) because by the speed c, space-time doesn’t exist.
Here I post, for reference, a relevant answer for comparing clocks from our previous conversation. With a small amount of thought you should be able to turn those into methods for comparing distances instead.Bjarne said:As I see it, I cannot see any direct experiment is possible, to reveal that.
As I wrote; only logical indirect conclusion.
How can A prove to B that his definition of one meter is "correct" (meaning universal).
The problem is A is still in top of the skyscraper and B in the cellar.
Where must the comparison take place?
I simply have no idea, and don’t think such experiments are done already.
Should I be wrong I would like to hear about it.
http://74.86.200.109/showpost.php?p=3783933&postcount=151
The result you get, as I have said many times, depends on the method of comparison, and GR can correctly predict the result for each method.
