Some questions about hypothesis testing
The discussion revolves around the concept of hypothesis testing, specifically focusing on the definition and interpretation of the significance level, denoted as \(\alpha\). Participants explore its meaning in the context of statistical tests, including one-tailed tests, and seek clarification on related textbook examples and notations.
  • One participant expresses confusion about the definition of \(\alpha\) and its relation to the parameter \(\theta\) in the context of hypothesis testing.
  • Another participant provides an example using a coin flip to illustrate the concept of a null hypothesis and the acceptance region, explaining that hypothesis testing is not a proof of the null hypothesis's truth.
  • There is a discussion about the intuitive understanding of \(\alpha\) as the probability of rejecting the null hypothesis when it is true, with a distinction made between different definitions of \(\alpha\) found in various texts.
  • Questions arise regarding specific textbook examples where \(\alpha\) is defined in terms of probabilities under the null hypothesis \(H_0\) and a probability of success \(p_0\), leading to further inquiries about the notation used.
  • A participant clarifies that the null hypothesis \(H_0\) is a statement rather than a number, and explains the meaning of the notations \(P_{H_0}[S \leq k]\) and \(P_{p_0}[S \leq k]\).
  • There is a discussion on the formulation of the null hypothesis in relation to the acceptance region, with differing opinions on whether it should state equality or inequality regarding treatment effectiveness.
Participants express varying levels of understanding and interpretation of the definitions and notations related to hypothesis testing. There is no consensus on the best way to phrase the null hypothesis in the context of the examples provided, indicating ongoing debate.
The discussion highlights potential ambiguities in textbook definitions and notations, as well as the implications of different formulations of the null hypothesis on the computation of \(\alpha\). Some assumptions about the nature of the null hypothesis and the acceptance region remain unresolved.
Artusartos
I think I’m a bit confused about what [tex]\alpha[/tex] is. For the definition that is given, what theta really means when they say [tex]\alpha = max_{\theta \in w_0} P_{\theta} [(X_1, … , X_n) \in C]. I just think that it’s not really clear in my head, so is it ok if anybody explains/gives and example about this?<br /> <br /> (my question is about the second attachment)<br /> <br /> Thanks in advance[/tex]
Perhaps the example of a "one tailed" test is the best intuitive explanation for that. Suppose we have a coin and our "null hypothesis" is "the coin is not biased toward heads". This hypothesis is different that the hypothesis "the coin is fair" because "not biased toward heads" would include the cases where the probability of the coin landing heads was 0.0 or 0.01 or 0.499 etc.
Hypothesis testing is a procedure where you define some feature of experimental data as "the test statistic" and define some "acceptance region" for that feature. If the feature of the particular data that you observe is outside the "acceptance region", you "reject" the null hypothesis. (Hypothesis testing isn't a mathematical proof that the null hypothesis is true or that it is false and it doesn't compute the probability that the null hypothesis is true or the probability that the null hypothesis is false. It is simply a procedure.)
To apply hypothesis testing to the above example, you must pick a feature of the data. Let's say the data is 100 independent flips of the coin. Let the feature be the total number of heads that occurred. Let's say the "acceptance region" is "80 or fewer flips of the coin produced heads".
The intuitive idea of "alpha" is to answer the question "What is the probability that I will reject the null hypothesis when it is actually true?". In this example, the question is "What is the probability that the observed number of heads will be more than 80 when the coin is actually "not biased toward heads". However, we can't compute a probability for this event because the statement the statement that the coin is "not biased toward heads" doesn't give us a specific probability to compute with. We don't know whether to assume that the probability of a head is 0.0 or 0.01 or .499 etc. Intuitively, if we assume the probability of heads is 0.5 then we are letting the coin be "as prone as possible to produce a head, without actually being biased toward producing a head". Assuming the probability of a head is 0.5 gives us a specific probability to use and it captures the idea of "the situation where the null hypothesis would be most likely to produce a false result".
Your book's definition is more sophisticated than the definition found in many introductory texts. Many texts define alpha as "the probability of rejecting the null hypothesis when it is true". Your text defines it as "the maximum of the probabiilities of rejecting the null hypothesis taken over all the possible ways the null hypothesis can be true". That is the more general definition of alpha.
Thank you so much for your help, but I think I'm a bit confused again...
There is an example in my textbook (which I attached)...
It says that [tex]\alpha = P_{H_0} [S \leq k][/tex] and [tex]\alpha = P_{p_0} [S \leq k][/tex]
I have two questions:
1) In my previous attachments the textbook defined alpha as the maximum of [tex]P_{\theta} [(X_1, ... , X_n) \in C][/tex] So in this example, are they saying that [tex]\theta = H_0[/tex] when they are saying [tex]\alpha = P_{H_0} [S \leq k][/tex]?
2) How did [tex]H_0[/tex] turn into [tex]p_0[/tex] when they wrote [tex]P_{p_0} [S \leq k][/tex]
instead of [tex]\alpha = P_{H_0} [S \leq k][/tex]
Thanks in advance
Artusartos said:
1) So in this example, are they saying that [tex]\theta = H_0[/tex] when they are saying [tex]\alpha = P_{H_0} [S \leq k][/tex]?
The null hypothesis [itex]H_0[/itex] is a statement, not a number. So it wouldn't make sense to say [itex]\theta = H_0[/itex]. As I understand their notation [itex]P_{ H_0}[S \leq k ][/itex] means "The probability that S is less than or equal to k under the assumption that [itex]H_0[/itex] is true" and [itex]P_{p_0}[ S \leq k ][/itex] means the "The probability that S is less than or equal to k under the assumption that the probability of success is [itex]p_0[/itex]. So both expressions refer to the same probability. (Your text didn't do a good job of definining those notations.)
In that example it is not necessary to speak of the maximum probability computer over the set of all [itex]\theta[/itex]. The null hypothesis in the example is stated as [itex]\theta = p = p_0[/itex]. So the null hypothesis only deals with a single value of [itex]\theta[/itex].
If they had chosen to state the null hypothesis as [itex]\theta = p \ge p_0[/itex] then we would have done the same computation for [itex]\alpha[/itex] as the example did, since [itex]p = p_0[/itex] is the value of [itex]p[/itex] that maximizes the probability that [itex]S \leq k[/itex] among all the possible values of [itex]p[/itex] that are allowed when the null hypothesis is true.
It's an interesting question whether the null hypothesis in the example should be "The new treatment has the same effectiveness as the old treatment" or whether it makes more sense to make it say "The new treatment is no more effective than the old treatment". Since the example proposes a "one tailed" acceptance region, I think it makes more sense to phrase the null hypothesis the second way.
Trying to prove whether a particular type of acceptance region (one tailed, two tailed, or a even bunch of isolated intervals) is "best" involves defining what "best" means. The only way I know to approach that topic in frequentist statistics is to compare the "power" of tests that use difference acceptance regions. The power of a test is defined by a function, not by a single number, so comparing the power of two tests is not straightforward either.
Thank you so much for your time.
  • · Replies 24 ·
