Friction Velocity from Law of the Wall
The discussion focuses on calculating friction velocity (u*) from wall shear stress (t) in a turbulent flow experiment using Hot Wire Anemometry. The method referenced is based on Kline et al.'s approach, where u* is derived from the equation u* = (t * ρ)^0.5. Participants emphasize the importance of plotting velocity (U) against distance from the wall (Y) in the laminar near-wall region (Y+ < 10) to extract the wall shear stress from the slope of the graph.
  • Understanding of turbulent flow dynamics
  • Familiarity with Hot Wire Anemometry techniques
  • Knowledge of wall shear stress calculations
  • Concept of non-dimensional parameters like Y+ and u+
  • Study the methodology in Kline et al.'s paper on friction velocity determination
  • Learn how to plot velocity profiles in turbulent boundary layers
  • Explore advanced techniques for measuring wall shear stress in fluid dynamics
  • Investigate the implications of Y+ values on flow characteristics
Students and researchers in fluid dynamics, particularly those involved in experimental studies of turbulent flows and boundary layer analysis.
pobatso
Hi all,
Am currently studying a set of data from a Hot Wire Anemeotry lab that was done a few days ago. The experiment was investigating a turbulent flow of air in a wind tunnel near a flat wall.
As part of the write up, we're ment to find the friction velocity from the laminar near wall region of the data, specifically Y+<10, on a method based on the one used in a paper by Kline et al.
Now it appears that they are finding the frictional velocity from a direct measurement of wall shear stress (t), as u*=(t.rho)^0.5. This is done by plotting a graph of U (velocity) Vs. Y for the laminar near wall region and somehow getting a value for t from the slope of the near wall region.
I'm a bit confused as to the exact steps of how they went about this and was wondering if anyone could help shed some light. Hope I've explained it adequately.
Cheers,
pobatso
Very near to the wall (typically y+ < 5-10) in a turbulent boundary u+ = y+
If you understand what u+ and y+ are then you can use the above equation and your measurments to determine the wall shear stress.
Since this is probably for school I won't tell you exactly what to do. But it's relatively straight forward.
  • · Replies 20 ·
9K
