Question about the set of irrationals.
  • Context: Graduate
  • Thread starter Thread starter cragar
    Set
The discussion revolves around the measure of sets of irrational numbers, particularly whether it is possible to have a set of all irrationals with measure zero. Participants explore different types of measures, including Lebesgue measure and probability measures, and their implications for the measure of irrational numbers and other sets.
  • Some participants question whether a set containing all irrationals can have measure zero, noting that uncountable sets can have measure zero.
  • One participant asserts that the measure of the set of irrational numbers is one, while another challenges this claim.
  • There is a discussion about the distinction between different types of measures, particularly Lebesgue measure, with one participant stating that the irrationals between 0 and 1 have non-zero measure.
  • Some participants express confusion regarding the context of "measure" and clarify that in probability measures, the maximum measure is always 1.
  • The concept of infinite measure is introduced, with participants discussing whether sets can have infinite measure in the context of ZFC (Zermelo-Fraenkel set theory with the Axiom of Choice).
  • One participant mentions that the set of real numbers has infinite measure under Lebesgue measure, while another emphasizes that there cannot be a Lebesgue measurable set with a measure larger than that of the reals.
  • There is a mention of Cantor cardinalities and the power set of any set having higher cardinality, but this is distinguished from the discussion of Lebesgue measure.
Participants express differing views on the measure of irrational numbers and the implications of different types of measures. There is no consensus on whether a set of all irrationals can have measure zero, and the discussion remains unresolved regarding the nature of infinite measure in different contexts.
Participants highlight the need to specify which measure is being discussed, indicating that the discussion is dependent on definitions and the context of measure theory. There are unresolved mathematical steps regarding the measure of specific sets.
cragar
Is it possible to have a set that contain all the irrationals that has measure zero.
I don't know that much about measure theory. Or I guess we could just ask what is the measure of the irrationals. I know it is possible to have uncountable sets that have measure zero.
The measure of the set of irrational numbers is one.
So the measure of the rationals must be zero.
I seem to recall that the measure of any countable set is zero.
You didn't specify which measure you are talking about, so if we use the zero measure, then the answer is yes.
If you are talking about using the Lebesgue measure, the answer is no. Let A be all rationals between 0 and 1, and B be all irrationals between 0, and 1. Then
##m(A) + m(B) = m([0,1]) = 1##
But ##m(A) = 0##, so B has non-zero measure.
Note that if C is any set that contains every irrational between 0 and 1 then ##m(C) \geq m(B)## by monotonicity.
What? That's not true, is it?
I suspect that Imalooser meant the set of all irrational numbers between 0 and 1.
That would make sense.
Sorry, I'm so used to probability measures that I simply assumed that. Probability measures are normed so that the maximum measure is always 1 and the minimum is zero. Duh.
do they have sets with different infinite measure?
What do you mean with "they"??
Do you mean whether probability spaces have sets of infinite measure? The answer is no: the largest possible measure is 1.
I guess I mean in ZFC are their sets that have infinite measure.
But I guess you said they dont
First you need to specify what you mean with "measure". Which measure are you talking about? If you're talking about Lebesgue measure on [itex]\mathbb{R}[/itex] (which is basically the rigorous version of length), then there are sets of infinite measure. The set [itex]\mathbb{R}[/itex] itself has infinite measure.
I didn't say that. I said that in a probability space (that is when you work with a probability measure), then all sets have finite measure by definition. But when not working with a probability measure, then there might be sets of infinite measure.
ok thanks for your response. Are their sets that have larger Lebesgue measure
than the set of reals.
No, since they already have infinite measure.
In measure theory, there is only one kind of infinity. There is not an entire class of infinities like the infinites of Cantor.
Are you thinking of Cantor cardinalities? If so, the answer is yes. You can take the power set of any set, and the power set will have higher cardinality.
cragar explicitly asked about the Lebesgue measure, not cardinality.
To further what micromass said, the Lebesgue measure is a specific measure defined on certain subsets of ℝ. Therefore there can't be a Lebesgue measurable set that has measure larger than ##m(\mathbb{R})##.
  • · Replies 22 ·
  • · Replies 18 ·
  • · Replies 85 ·
10K
  • · Replies 55 ·
11K
