Compute the total power delivered to the circuit by two batteries
The discussion revolves around a circuit analysis problem involving two batteries and multiple loops. The original poster presents a circuit diagram and expresses confusion regarding the calculation of total power delivered by the batteries, particularly in relation to the currents in the circuit.
  • Exploratory, Conceptual clarification, Mathematical reasoning, Problem interpretation
  • Participants inquire about the methods used to calculate the currents and suggest defining the potential energy in each loop using relevant equations. There are discussions about the direction of current flow and the application of Kirchhoff's laws.
Several participants are actively engaging with the original poster's calculations and offering suggestions for setting up equations. There is an emphasis on understanding the relationships between the currents and the need for multiple equations to solve for them. The conversation reflects a collaborative effort to clarify concepts without reaching a definitive conclusion.
There is mention of potential confusion regarding the setup of the circuit and the interpretation of current flow. The original poster has provided some values for the currents but acknowledges uncertainty in their correctness.
brittydagal
http://tinypic.com/r/e8v1ad/6
^^ that is a photo of the circuit
P = I*V , but i don't understand how to do it with two loops and two batteries like in this photo.
I have calculated I1 to be .9, I 2 to be .15 and I3 to be .75.
On the very left of the photo is a 15 V battery and the resistor on the bottom that you can't really read is 100 olms.
The other battery (i put a square around the batterys) is 9 V.
Just kinda confused on how to put them together. thnks for your help
What method did you you use to find the currents? Can you show more of your work?
(I ask because they don't look right to me). From what I can tell from your attached picture the circuit looks something like this:
Some suggestion: You already suggested that there is 2 loops. Define the total potential energy of each loop in terms of the formula V = I*R... So if you choose the first loop, try defining it in terms of the equation. Do the same for the second loop and then you need a third equation seeing that you have 3 variables. How can you define these variables in terms of each other? Not an expert on electrical things but this seems like first principals...
Also when setting your equations, remember that flow goes from positive to negative for your loops, not as you stated in your second loop...
The power delivered to and consumed by a given circuit can be determined either by summing up all the individual power losses due to resistive elements (sum of P = I2R for each resistor in the circuit), or by multiplying the current leaving the + terminal of each voltage source by the potential of that source (P = I*R) [Edit: Oops, should have been P = I*V there]. and summing the results. Either way, knowledge of the individual currents in the circuit is required, hence the need to write and solve equations based upon Kirchhoff's circuit laws, KVL and KCL.
Actually, two equations suffice to solve for all the currents in a two-loop circuit; since the loops are interacting (they share one or more components), the "third" current is not truly an independent variable.
For purposes of analysis the assumed direction of flow of currents doesn't matter; the mathematics will always sort out the true directions. If the assumed direction for a current turns out to be incorrect, the equations will pop out a negative value for a result. No worries there.
gneill said:
or by multiplying the current leaving the + terminal of each voltage source by the potential of that source (P = I*R) and summing the results.
Actually this is what I ment with flow is from positive to negative, to start at the positive side... I didn't know the actual name of the equation.
With a third equation I ment define I1 in terms of I2 and I3, I guess it is a given just tried to explain it in a understandable manner. Search for unanswered posts and this one came up so thaught I will give it a try seeing that it is frustrating if no help is given.
But thanks for also correcting me, learned something myself...
  • · Replies 62 ·
