How to explain Einstein's Special theory of Relativity.
The discussion revolves around understanding and explaining Einstein's Special Theory of Relativity, focusing on concepts such as time dilation, the speed of light, and particularly the Lorentz transformation. Participants seek clarity on these topics and how to communicate them effectively to others.
  • Homework-related
  • One participant expresses a desire to understand the Special Theory of Relativity, specifically the Lorentz transformation, to grasp the theory fully.
  • Another participant explains that the Lorentz transformation relates coordinates between different frames of reference and is essential for understanding the constancy of the speed of light.
  • Some participants suggest that the questions posed are too broad and recommend more specific inquiries to facilitate better responses.
  • A participant notes that the Lorentz transformation is foundational for deriving time dilation and length contraction, indicating that understanding it is crucial for grasping the theory.
  • There is a discussion about the difficulty of providing simple explanations for complex topics, with one participant mentioning the challenge of conveying the ideas of relativity effectively.
  • Another participant highlights that different individuals may understand the theory differently, despite agreeing on its predictions.
  • One participant shares their basic understanding of the historical context of the theory, referencing the shift from Galilean transformations to the implications of Maxwell's work.
Participants express varying levels of understanding and approaches to explaining the theory, indicating that there is no consensus on how best to communicate the concepts involved. Some participants agree on the importance of the Lorentz transformation, while others emphasize the challenges in providing clear explanations.
Participants acknowledge the limitations of their explanations and the complexity of the theory, suggesting that different backgrounds in mathematics and physics may affect understanding. There is also mention of the need for illustrations and animations to aid comprehension.
  • #31
John Huang said:
If you limit the x' in the LT to x'=0, you will get x=vt and after you replace the x in the time equation by "vt", then you will get the time equation of SR.
If the x' in LT is not always 0, then the time equation of LT will be different from the one of SR. In this situation, which equation do you go by?
You seem to be under the very incorrect impression that SR is limited to the time dilation equation. This is false. The time dilation equation is a subset of the LT, which is in turn a subset of SR. In the situation you mention you go by the LT since the time dilation equation does not apply.
  • #32
Lochlan.h,
If you are still confused a bit try this YouTube site. After you click the link and the webpage loads, click "Browse videos", then once that page loads, click "Playlist" and there will be a whole playlist of videos on one dimensional special relativity waiting for you. They're awesome, I watched them myself.
http://www.youtube.com/user/InvariantSpace
  • #33
Thanks for the comment. I know that Einstein also supported LT and he claimed that he proved LT by 2 postulates. Actually I also know that after Einstein introduced his SR in the section 3 of his 6/30/1905 paper, he extended SR from "constant relative velocity" to "constant relative speed" in the section 4 right away. Even with the new expansion, I think SR should continue its support to the situation of "constant relative velocity". So, could you explain why in the situation that {the observed event happened at a location other than O'} we should use LT, not SR?
I think the main purpose of SR is to introduce the time dilation equation. However, if you could show me what else SR has provided to people, I will appreciate and study it.
Regards,
John
  • #34
John Huang said:
I also know that after Einstein introduced his SR in the section 3 of his 6/30/1905 paper...
You should start with the title of that paper... Einstein introduced Special Relativity to resolve the great unsolved problem of the second half of the 19th century, namely the incompatibilities between Galilean relativity and Newtonian mechanics on the one hand, and Maxwell's theory of electricity and magnetism on the other hand.
  • #35
The time equation of SR is LT. the lorentz transforms are a set of equations for transforming from one reference frame to another. They are a part of SR.
  • #36
Thanks. Do you think the "time dilation equation" is the solution created by Einstein?
No one else mentioned about it, right? At least I don't know who else mentioned about it. That is why I assign that solution (the time dilation equation) as the main purpose of SR.
  • #37
If you think LT is part of SR, that's fine. Now, we have two "time dilation" equations.
As I know, SR can be used for two systems with constant relative speed; however, in case of constant relative velocity SR should be correct as well. I mean, in cases of constant relative velocity, should I use LT or SR? Do you have website where I can find the answer of it? Thanks.
  • #38
There is a lot in SR. The Lorentz Transformations were a set of coordinate transformations that Lorentz first developed with regards to electromagnetism. It was Einstein who first used them to describe space itself, and the time dilation and length contraction equations come directly from the lorentz transformations.
You keep saying that LT and SR are seemingly two distinct things, which is completely wrong. The Lorentz Transformations are a part of SR. To ask whether to use Special Relativity or the Lorentz Transformations is like to ask whether to use Newtonian Mechanics or Newton's Second Law; the question doesn't make sense.
  • #39
I'm not quite sure I understand your question. When you say "Should I use LT or SR?", it makes no sense. It is my understanding that LT is a part of LR. There is no need to choose between the two.
Maybe if you gave me an example of what you consider to be an equation of SR and an equation of LT I would better understand your question.
  • #40
The changing of the term 'velocity' and 'speed' makes no operational difference. Speed is defined as s = √(vx2+vy2+vz2) where the v terms are the magnitudes of the x,y and z velocities. It is always possible to rotate the coordinates so only one component is non-zero in these coords.
What difference do you think it makes ?
  • #41
In that section he clearly derived the LT from his two postulates. Therefore, the LT is part of SR, and has been from the beginning of SR.
In section four he derives the time dilation equation from the LT with the additional restriction that the other clock is "at rest relative to the moving system, to be located at the origin". I.e. That is the only time that derived formula applies.
Can you explain in playing football why you should use your leg, not your foot?
Please re read the 1905 paper. Clearly he includes more than just the time dilation equation. So for you to make this statement is absurd. Furthermore, going beyond Einstein, SR now includes also Minkowski's spacetime, and even pseudo-Riemannian geometry on flat manifolds.
  • #42
No, you have the LT which simplifies to the time dilation equation under specific circumstances. When the circumstances match then you can use the simplified equation or the LT equally since they agree. When the circumstances don't match then you cannot use the simplified equation since it doesn't apply.
  • #43
That is the best answer I have received so far. Thanks. Do you mean, only when x'=0 we can use SR, otherwise, we should apply LT?
  • #44
With constant velocity, LT works for inertial systems only; with constant speed, SR can expand to circling or any kind of constant speed situation.
  • #45
According to # 42, my understanding is that SR is part of LT. What do you think?
  • #46
For example, if we focus on the events happen at the origin point of the stationary system, the point O, then we will have x=0. If LT is part of SR, then, both of the time equations in LT and SR should apply and under this situation, the time equations are inverse. Which one should apply?
  • #47
Realize that in common usage SR means "Special Relativity". The LT is part of SR, of course.
You seem to be using "SR" to mean the time dilation formula, which is a special case of the LT (as has been explained). Your non-standard use of "SR" is creating some confusion.
  • #48
If you want to convert measurements from one frame to another you can always use the LT. In certain cases the simplified 'time dilation' formula can be applied.
In this example, since the events in question all take place at x = 0, you can convert the time between them (Δt) to the moving frame (Δt') using the time dilation formula: Δt' = γΔt. But that's just an application of the LT.
What's your point?
  • #49
No, I mean what I said. The LT is part of SR. The time dilation formula (which is part of the LT) only applies when x'=0.
You continue to identify SR with only the time dilation formula. That is simply WRONG.
  • #50
No, you have this backwards. The LT is part of SR.
I think there is some language barrier. Perhaps this will help:
[itex]SR \supset LT \supset time \; dilation[/itex]
[itex]SR \neq time \; dilation[/itex]
  • #51
What's your point?
My point is a logical issue.
In above example, two systems have constant relative velocity so that the speed of time in the moving system t' and the speed of time in the stationary system t should be decided once we select the point O as the stationary point, and the O' as the moving point. Under this SPECIFIC arrangement, when we talk about a period of time for ONE SPECIFIC EVENT then we should have ONLY ONE event period Δt as recorded in the stationary system and ONLY ONE event period Δt' as recorded in the moving system.
Now, what SR claims is Δt' = Δt/γ and what LT claims is Δt' = γΔt for the ABOVE example. Logically speaking, this should not happen UNLESS γ=1, isn't it? How do you explain this logical issue?
If you like the event to stay in the moving system, then you may let x'=1.
  • #52
I don't know where you got this idea. In SR Δt' = γΔt not Δt/γ. It is the same for LT. That is where your confusion lies.
  • #53
You are wrong with these equations. In both LT and SR (it seems stupid as I previously mentioned to distinguish between the two like that but I'll cave for argument's sake), ##\Delta t'=\Delta t \gamma##. You may be confusing the time dilation equation with the length contraction equation, which is ##\Delta L'= \frac{\Delta L}{\gamma}##
  • #54
The simple explanation is that you do not understand how and when to apply the time dilation formula. (And please stop saying "SR claims...".)
Events that happen at x = 0 can be treated similar to a clock at that point that is stationary in the unprimed frame. From the primed frame, that clock is moving and obeys the 'time dilation' formula (which is derived from the LT). You'll get Δt' = γΔt no matter how you slice it.
  • #55
The explanation is easy: You made a mistake.
SR claims the same as the LT claims, specifically that in any given inertial frame a moving clock will tick more slowly. Your assertion to the contrary is simply a mistake on your part.
  • #56
I knew that you might claim the event at x=0 would reverse the moving and stationary status. I also mentioned "If you like the event to stay in the moving system, then you may let x'=1." in my response. When the event happens at x'=1, the time dilation equation of SR remains the same Δt' = Δt/γ but the time dilation equation of LT will include the variable x.
Now, we have a SPECIFIC event happens at x'=1, the SPECIFIC event period measured at two systems, Δt' and Δt, should be SPECIFIC as well. That means, logically speaking, we have three possible answers for this logical issue: 1) SR is correct, 2) LT is correct or 3) both of them are wrong. That is my logical issue. Could you please explain this logical issue? Thanks.
  • #57
You are not listening to the rest of us. You have your equations wrong, and you are going to continue to be wrong until you acknowledge and fix that. I don't want to repeat what has been posted already by several people, so I would go back and read their posts. Furthermore, it seems you are confusing the time dilation equation with the lorentz boost in the time dimension, which are two separate (not competing) equations.
  • #58
Thanks for your comment. But I did listen, otherwise, how could I respond?
You said that ".. it seems you are confusing the time dilation equation with the lorentz boost in the time dimension,..". I think SR is independent to the Lorentz boost. A Lorentz boost in any direction can be turned and moved to match the boost in the x-direction mathematically. I think I am fine with the term of boost.
  • #59
No, you are misunderstanding the equations. A lorentz boost, given the input of a time coordinate of an event for one observer, and the x-value and velocity of a second observer, will tell you the time coordinate of the event for the second observer.
The time dilation equation, given an input of an interval of time and the velocity of a second observer, will give you the interval of time measured by the second observer.
They are two totally different equations, and one can be derived from the other, so it's preposterous to claim one is true and the other isn't.
  • #60
Your "No," after your quote of my response {If you think LT is part of SR, that's fine. Now, we have two "time dilation" equations.} in the # 42 confused me. Now I know your "No," is for my second statement in your quote. Thanks for the clarification.
  • · Replies 19 ·
  • · Replies 37 ·
  • · Replies 61 ·
  • · Replies 61 ·
  • · Replies 27 ·
