How to explain Einstein's Special theory of Relativity.
The discussion revolves around understanding and explaining Einstein's Special Theory of Relativity, focusing on concepts such as time dilation, the speed of light, and particularly the Lorentz transformation. Participants seek clarity on these topics and how to communicate them effectively to others.
  • Homework-related
  • One participant expresses a desire to understand the Special Theory of Relativity, specifically the Lorentz transformation, to grasp the theory fully.
  • Another participant explains that the Lorentz transformation relates coordinates between different frames of reference and is essential for understanding the constancy of the speed of light.
  • Some participants suggest that the questions posed are too broad and recommend more specific inquiries to facilitate better responses.
  • A participant notes that the Lorentz transformation is foundational for deriving time dilation and length contraction, indicating that understanding it is crucial for grasping the theory.
  • There is a discussion about the difficulty of providing simple explanations for complex topics, with one participant mentioning the challenge of conveying the ideas of relativity effectively.
  • Another participant highlights that different individuals may understand the theory differently, despite agreeing on its predictions.
  • One participant shares their basic understanding of the historical context of the theory, referencing the shift from Galilean transformations to the implications of Maxwell's work.
Participants express varying levels of understanding and approaches to explaining the theory, indicating that there is no consensus on how best to communicate the concepts involved. Some participants agree on the importance of the Lorentz transformation, while others emphasize the challenges in providing clear explanations.
Participants acknowledge the limitations of their explanations and the complexity of the theory, suggesting that different backgrounds in mathematics and physics may affect understanding. There is also mention of the need for illustrations and animations to aid comprehension.
  • #61
John Huang said:
My point is a logical issue.
In above example, two systems have constant relative velocity so that the speed of time in the moving system t' and the speed of time in the stationary system t
SR, and the time dilation equation, do not say anything about "the speed of time", that's your misconception right there. The time dilation equation is about the rate of a clock as perceived in a frame where it's moving at speed v; nothing more. If you take two events on a clock's worldline and Δt is the time between them as measured by the clock, then naturally Δt is also the time between those events in the frame where the clock is at rest, where Δx for that pair of events is 0. If you plug Δx=0 into the Lorentz transformation equation Δt' = γ(Δt - vΔx/c2), you get the equation Δt' = γΔt, which is the time dilation equation (here Δt is the time between two events on a clock's worldline as measured by the clock itself, and Δt' is the dilated time between those same two events in an inertial frame where the clock is moving at speed v. So, in this frame the clock takes a time of Δt' to tick forward by a time increment Δt, and this is the only case that the time dilation equation was ever intended to cover).
  • #62
Vorde said:
No, you are misunderstanding the equations. A lorentz boost, given the input of a time coordinate of an event for one observer, and the x-value and velocity of a second observer, will tell you the time coordinate of the event for the second observer.
The time dilation equation, given an input of an interval of time and the velocity of a second observer, will give you the interval of time measured by the second observer.
They are two totally different equations, and one can be derived from the other, so it's preposterous to claim one is true and the other isn't.
Thanks. Now I found out SR is just for the event periods, it is not designed for the event time. Even if we let t=t'=0 when O=O', SR is not for event time due to the simultaneity issue. I should not ask the time equation of SR to tell event time, it is for the time period. My mistake.
If I use x'=1 for the location of an event, then, the variable of x will be canceled out and the event period calculated by LT will be the same as the event period calculated by SR.
  • #63
I recommend the intro in Schutz
  • #64
In above example, two systems have constant relative velocity so that the speed of time in the moving system t' and the speed of time in the stationary system t should be decided once we select the point O as the stationary point, and the O' as the moving point. Under this SPECIFIC arrangement, when we talk about a period of time for ONE SPECIFIC EVENT then we should have ONLY ONE event period Δt as recorded in the stationary system and ONLY ONE event period Δt' as recorded in the moving system.
Now, what SR claims is Δt' = Δt/γ and what LT claims is Δt' = γΔt for the ABOVE example. Logically speaking, this should not happen UNLESS γ=1, isn't it? How do you explain this logical issue?
If you like the event to stay in the moving system, then you may let x'=1.
Of course, LT is part of SR. The apparent contradiction is perhaps due to an important point that you may have missed: you cannot directly measure the rate of a moving clock with a single stationary clock, as the moving clock can only be at negligible distance from a single stationary clock at one moment - for comparing two time periods you need to use for example two clocks in the "stationary" system, one at x1 and one at x2 (there are other means, but this is the simplest to picture). According to the LT:
1. For x1'=x2' (Δx'=0, clock at rest in S', moving in S): Δt' = Δt/γ
2. For x1=x2 (Δx=0, clock at rest in S, moving in S'): Δt' = γΔt
I think that you selected situation 1. In that situation we compare the clock readings of a clock that is moving relative to S with the readings of clocks that are rest relative to S. For simplicity you can choose that "moving" clock at be positioned at O'. SR says simply what the LT say for each situation.
If I correctly recall it, I did not fully understand how this works until I actually derived that myself and made sketches of the physical meanings of 1. and 2. And it is necessary to understand relativity of simultaneity.
PS I see that others already gave roughly the same explanation with different words, but one never knows which one is the easiest to understand and regretfully some gave mistaken and even wrong answers. Probably such mistaken answers are the cause of your confusion. I may have identified the cause of your confusion and advice to ignore those answers that did not clarify if they took Δx or Δx' zero, or what they took as "moving".
  • #65
John Huang said:
I knew that you might claim the event at x=0 would reverse the moving and stationary status.
I hope you realize that the 'stationary' status is purely relative. Each frame considers themselves to be the stationary one. Better to use the distinctions of primed and unprimed.
I also mentioned "If you like the event to stay in the moving system, then you may let x'=1." in my response.
You seem to be confused about what an 'event' is. Events happen in all frames. (Their coordinates are different in different frames.)
When the event happens at x'=1, the time dilation equation of SR remains the same Δt' = Δt/γ but the time dilation equation of LT will include the variable x.
In order to discuss a time interval between events you need at least two events. What are they? I thought you wanted the events to all take place at x = 0?
Now, we have a SPECIFIC event happens at x'=1, the SPECIFIC event period measured at two systems, Δt' and Δt, should be SPECIFIC as well.
You seem to be mixing up two sets of events (as far as I can decipher):
(1) Events that occur at the same place in the unprimed frame with coordinates in that frame of (0,0) and (0, t). The interval between them is Δt. As measured in the primed frame, the interval between those same events is Δt' = γΔt.
(2) Events that occur at the same place in the primed frame with coordinates in that frame of (0,0) and (0, t'). The interval between them is Δt'. As measured in the unprimed frame, the interval between those same events is Δt = γΔt'.
Please take note of the symmetry here.
That means, logically speaking, we have three possible answers for this logical issue: 1) SR is correct, 2) LT is correct or 3) both of them are wrong. That is my logical issue. Could you please explain this logical issue?
Again, you insist on conflating the time dilation formula (which is only part of SR) with SR itself. That will always be wrong. Please stop, as it just makes you seem silly.
So assuming that what you are actually asking about is the time dilation formula compared to the LT: You are applying the time dilation formula incorrectly! Used correctly, they will always yield the same results (in those special cases where the time dilation formula applies).
  • #66
Ok. How does SR define an event time for an event moving in the moving system?
For example, if an event moves at speed v to the positive x direction relative to the O', then to LT, it is easy. It is x'=OO'=vt so that x2'-x1' is not zero.
For that moving event, we will get a different event period for this moving event from LT than from SR if SR still use the same equation for this moving event. If SR will use different equation for that moving event, what could that equation be? I don't know, do you have idea?
  • #67
That doesn't make sense. Events don't move. An event is something that happens at a specific place and time (with respect to some frame of reference).
Objects can move. Is that what you mean?
So, you have some object (I presume) moving with speed v relative to some frame. So the events might be the start of the object (at x = 0, t = 0) and the arrival of the object at some later point (vt, t). Is that what you mean? What about it?
In order to proceed in any sensible fashion to apply the LT (or the time dilation formula), first define the events you want to describe.
Again: Events don't move (objects do). Stop saying "SR" when you mean the time dilation formula. (If this thread keeps going in circles, it will be shut down.)
Define the two events you would like to talk about. Then we can discuss how the time interval between them will be measured in each frame.
  • #68
For the 5th or 6th time. LT is part of SR. What you are saying is literally nonsense.
  • #69
It uses the LT.
A little bit of terminology here. Events don't move, objects move.
An event is something that happens at a specific time and place, i.e. an event is a point in a 4D spacetime. Events have 4 coordinates (t,x,y,z). SR uses the LT to transform those coordinates from one inertial frame to another.
No, you won't. SR uses the LT to calculate the coordinates of events in different frames.
  • #70
John Huang said:
Ok.
Sorry but... can you please give a little more feedback? For example, did you follow my post #64? Was I right about the situation that you presented? For if I understood you correctly, then several others gave a wrong answer that may have confused you.
There is somewhat of a language problem... an object is not an event. :wink:
I suppose that you mean the time of a physical process, and you give as example an object. But your coordinates are all mixed up, I'm afraid that you'll never get anywhere like that. Try this:
An object moves at speed v in the positive x' direction from O' starting at t'=0. Then we can describe its x' coordinate as function of time as x'=v't'. And if we relate to a system in which the object is in rest at O (in the rest system S), then in S the object is simply at O which has as x-coordinate x=0.
Likely you meant something like that, but the question is not clear. Perhaps you can rephrase it using the above notation, and without repeating the error that LT is different from SR. In fact, "Ok" would mean that you would not write that error; your last post was a self contradiction.
  • #71
I could make a new term, like a "story", to include all continuous events relative to an object. If the object is stationary in a system, then, that object has a "stationay story" and if the object moves in the system then that object has a "moving story".
However, If LT is part of SR, then, this will not be a problem any more.
SR can let the LT portion of SR handle all "moving stories". Then the famous time dilation equation of SR can handle all "stationary stories" in the moving system. But for a "stationary story" in the stationary system people cannot use the famous time dilation equation of SR to calculate the "event period". They must use the inverse equation of it.
Or, people can simply use LT to calculate the event periods (or story periods) for all kinds of story in both systems.
  • #72
I think that you selected situation 1. In that situation we compare the clock readings of a clock that is moving relative to S with the readings of clocks that are rest relative to S. For simplicity you can choose that "moving" clock be positioned at O'. SR says simply what the LT say for each situation.
Yes, Einstein claimed that he proved LT so that you can say "at the beginning" SR did include LT but then SR claimed {Δt' = Δt/γ is the equation for the relation of the speed of time in two systems}. I think, after that, SR cannot claim to include LT any more.
In LT, the relation of the speed of time in two systems is not so simple, it is Δt' = γ(Δt-(vΔx/c^2)) and it is different from Δt' = Δt/γ except when x' is a constant.
  • #73
For the last time, LT is a part of SR
In special relativity (or, hypothetically far from all gravitational mass), clocks that are moving with respect to an inertial system of observation are measured to be running more slowly. This effect is described precisely by the Lorentz transformation.
And you were right about Δt' = γ(Δt-(vΔx/c^2)) but wrong about Δt' = Δt/γ. When Δx=0, Δt'=γΔt not Δt/γ. I don't understand where you got Δt' = Δt/γ. I've never seen this equation used and it seems to be what is getting in your way.
  • #74
Like I said before, Einstein didn't say anything about the "speed of time", that equation is intended to tell you how much time Δt elapses in the unprimed frame between two readings on a clock, if the clock itself shows an elapsed time of Δt' between those readings (so Δt' is also the time in the clock's rest frame, where Δx'=0). For example, if the readings are "10 seconds" and "15 seconds", then Δt' = 5 seconds, and in the second frame the clock is running slow so in this frame it will take a longer period of Δt = γ*5 seconds for the clock's second hand to move from 10 to 15.
Look at section 4 of Einstein's 1905 paper, where he uses t for the time elapsed on the clock in the "stationary system" and τ for the time elapsed in the "moving system" when the clock itself is at rest relative to the "moving system", i.e. the time between the two readings in clock's own rest frame, introducing the setup like this:
Further, we imagine one of the clocks which are qualified to mark the time t when at rest relatively to the stationary system, and the time τ when at rest relatively to the moving system, to be located at the origin of the co-ordinates of k, and so adjusted that it marks the time τ. What is the rate of this clock, when viewed from the stationary system?
He then goes on to show that the equation τ = t/γ describes the relation between these two times in this scenario, using the LT to derive it.
So, after having looking at that section of the 1905 paper, would you agree that Einstein was not talking about the "speed of time" but rather meant the equation Δt' = Δt/γ to apply to the time elapsed between two readings of a physical clock, as measured both in its own rest frame (where Δx'=0) and in the frame where it's moving? Would you agree that given those assumptions about what the equation is supposed to represent, Δt' = Δt/γ can be derived directly from the LT? It's easy to show why, since one of the LT equations is Δt = γ(Δt' + vΔx'/c2), so if you set Δx'=0 you are left with Δt = γΔt' or Δt' = Δt/γ.
If you disagree with any of this, please explain why you think I am mistaken about what Einstein meant, preferably pointing to a specific quote from the paper to make your case.
  • #75
tensor33 said:
And you were right about Δt' = γ(Δt-(vΔx/c^2)) but wrong about Δt' = Δt/γ. When Δx=0, Δt=γΔt not Δt/γ. I don't understand where you got Δt' = Δt/γ. I've never seen this equation used and it seems to be what is getting in your way.
It's an arbitrary matter of convention which frame to define as the clock's own rest frame, although most sources do use unprimed for the frame where the clock is at rest, you can find the occasional source that defines unprimed as the observer's frame like http://www.phy.duke.edu/courses/055/faqs/faq26/ from a university website, it's not really "wrong" as long as you explain which frame is which.
  • #76
I see your mistake. You are saying Δt' = Δt/γ when the equation is Δt=Δt'/γ. There is no contradiction between Δt=Δt'/γ and Δt'=γΔt. They are simply inverses. Someone correct me if I'm wrong.
  • #77
But if we do define the unprimed frame as the one where the clock is at rest, wouldn't the equation Δt' = Δt/γ be incorrect?
  • #78
I would say it's wrong that "the" time dilation is Δt=Δt'/γ rather than Δt' = Δt/γ, it all depends on which frame is chosen to be the one where the clock is at rest. If the clock is at rest in the unprimed frame the first is correct, if at rest in the primed frame the second is correct.
  • #79
Yes, in that case it would be incorrect, but John Huang hasn't specified that either is supposed to be the rest frame of a specific clock, and doesn't seem to understand that the time dilation equation is meant to deal specifically with the case of a clock at rest in one of the two frames (hopefully he will read my most recent comment to him).
  • #80
SR claims the different solutions for x' is a constant and for x is a constant, as I summarized in my post #64. In words those equations boil down to what Dalespam wrote in his post #55.
Do you remember where you read that wrong explanation of SR that you keep hanging on?
  • #81
You are correct that LT claims Δt' = γΔt when x=0. Here is a graph to illustrate a clock at rest at x=0. The blue dots represent ticks of the clock that occur every second:
Now we use the LT to transform the coordinates of all the events (the 1-second ticks represented by blue dots) into the coordinates of another frame moving at 0.866c with respect to the first frame. When we do the LT, we always call the original frame the unprimed frame and the new frame the primed frame:
Note that since the speed is 0.866c, gamma is equal to two. You can see that the first event which occurred at the time coordinate of 1 in the first frame occurs now at the time coordinate of 2 in the second frame, just like the LT formula indicates.
So far so good.
Now we want to see how to use the time dilation formula. Unlike the LT formula which applies to the coordinate times in two different frames, the time dilation formula applies to the relationship between the time (primed) on a clock compared to the coordinate time (unprimed), all in a single frame.
So let's apply the time dilation formula to the first graph where the speed of the clock is zero and gamma equals one. The formula says that the time on the clock is the same as the coordinate time and we see that because the spacing of the dots is the same as the spacing of the grid lines for the graph.
Now let's apply the time dilation formula to the second graph where the speed of the clock is 0.866 and gamma equals two. The formula says that the time on the clock will be one half of the coordinate time and we see that because the spacing of the dots is twice the spacing of the grid lines for the graph. In other words, the first dot after the origin, representing a clock time of one second occurs at a coordinate time of two seconds.
Got it?
  • #82
tensor33 said:
For the last time, LT is a part of SR.
If I ignore the fallowing logic, then, yes, LT is part of SR.
This is the only way SR can include LT, by CLAIMING.
Think about it, HOW the observers in the stationary system S measure the "event period" of ONE SPECIFIC event? By the stationary clock S-CLOCK in S, right? For the observers in the moving system S', they will use the moving clock M-CLOCK to measure the "event period" of ONE SPECIFIC event. For the SPECIFIC event in the arranged situation the observers in S will measure only one "event period" Δt and for observers in S' the observers will measure only one "event period" Δt'. Am I correct?
In the SPECIFIC situation, SR states based on the relative speed "v", the relation of the speed of time should be Δt' = Δt/γ, but regarding the "event period", we should go by Δt' = γ(Δt-(vΔx/c^2)). The "event period" reflects the speed of time, isn't it?
  • #83
Enough already. Please define what you mean by "SR".
Everyone in this thread besides you understands that SR means Special Relativity. And of course Special Relativity includes the Lorentz transformations. Any claim otherwise is just silly.
Please give your definition of "SR" in your very next post. (I am giving you the benefit of the doubt here.)
  • #84
Events happen at a single instant. There is no Δt for a single event, only between two events. "Event period" makes no sense.
Once again, the Lorentz transformations apply to any time interval. So Δt' = γ(Δt-(vΔx/c^2)) is always true. Realize that that is only one of the four basic transformations; Another is Δt = γ(Δt' + (vΔx'/c^2))
The time dilation formula Δt' = Δt/γ is only true for the special case where the events happen at the same position in the primed frame and thus Δx' = 0. In words, the time dilation formula says that 'moving clocks run slow'.
No.
  • #85
If you [John] don't understand the standard terminology that we use when we discuss SR, it doesn't help to make up your own terminology that we don't understand.
  • #86
This is essentially correct. The standard term for "story" is "worldline".
For pedagogical reasons my recommendation is always to follow your last suggestion which I highlighted in bold. It automatically simplifies to the time dilation equation whenever it is appropriate and it avoids accidentally using it when it is not appropriate.
  • #87
SR still includes the LT. A specialized simplification of a general equation does not in any way invalidate the general equation.
  • #88
Thanks for your correction. Now, I will rewrite my sentence.
How do observers everywhere in the stationary system S measure the "time period" Δt of ONE SPECIFIC SECTION of continuous events from event 1 at point A to event 2 at point B? They use the synchronized stationary clocks in S. For the observers everywhere in the moving system S', they will use the synchronized moving clocks to measure the "time period" Δt' from event 1 to event 2. Now, we have a better defined case.
There are two ways to do the measure jobs.
The easy way is to measure event time t1 and t1' for event 1 at point A and measure event time t2 and t2' for event 2 at point B. We will have Δt' = t2'-t1' and Δt = t2-t1.
The difficult way is to measure event time by assigned observers, one in S and one in S'. The simplest assginment is let them stay at origin points O and O'. Let us look at this simplest situation. Since the distances of each pair of four points A, B, O and O' could be different, we must adjust the influence of the distance. When A=B=O', it will be the situation arranged by Einstein. We will have Δt' = t2'-t1' and Δt = t2-t1.
For this SPECIFIC SET of t1,t2, t1' and t2', SR states based on the relative speed "v", the relation of the speed of time in S' and S should be Δt' = Δt/γ, but regarding the "time period", we should go by Δt' = γ(Δt-(vΔx/c^2)). Am I correct?
Yes, "In words, the time dilation formula says that 'moving clocks run slow'." and for relative speed v, the time dilation formula Δt' = Δt/γ stands.
In Δt' = Δt/γ, Δt' is for the time period in the moving system S' of a given SECTION OF EVENTS and Δt is for the stationary system S of the same SECTION OF EVENTS.
  • #89
ghwellsjr said:
Got it?
Thanks.
  • #90
That's much better defined. :smile:
OK so you now moved on to two ways of measuring the same interval: the simplest, "local" way of measuring and the indirect or "non-local" way. SR predicts the same for both set-ups; that is necessary for consistency.
Ok, you take here the special case that Δx'=0, just as you did before - correct? And for the LT we choose O=O' at t1=0. Here's a generic sketch of it:
t1...t2
O--------------------- S
A....B
A,B
O'---------------- S'
t1'
t2'
For this SPECIFIC SET of t1,t2, t1' and t2', SR states based on the relative speed "v", the relation of the speed of time in S' and S should be Δt' = Δt/γ, but regarding the "time period", we should go by Δt' = γ(Δt-(vΔx/c^2)). Am I correct? [..]
That is not correct; Δt' = γ(Δt-(vΔx/c^2)) is valid for both; and there is no difference of prediction between using local clocks or distant observers. I copy-paste my earlier reply:
Once more: you selected the time period of situation 1, with x1'=x2' and thus Δx≠0.
You should find from the LT that the time period Δt' = Δt/γ for that situation, based on the relative speed v.
If that is not clear to you, please ask. :smile:
  • · Replies 19 ·
  • · Replies 37 ·
  • · Replies 61 ·
  • · Replies 27 ·
