Linear actuators for mechanical project
The discussion centers around finding suitable linear actuators for a mechanical project that requires specific performance characteristics, including speed, load capacity, and compatibility with an Arduino logic board. Participants explore various actuator options and control methods.
  • One participant outlines the specifications needed for the linear actuators, including speed, load, and control requirements.
  • Another participant suggests that overvolting a specific actuator model could achieve the required speed, depending on the duty cycle, and recommends contacting the manufacturer for further advice.
  • Questions are raised about the maximum travel distance of the actuators, with one participant providing an estimate of around 18 inches.
  • A different participant proposes a specific actuator model that may meet the requirements and suggests using a DPDT relay or a high-current analog switch IC for control with the Arduino.
Participants have not reached a consensus on a specific actuator solution, and multiple options and control methods are being discussed without agreement on the best approach.
There are limitations regarding the duty cycle and maximum travel distance that may affect the suitability of the proposed solutions. The discussion does not resolve these aspects.
aortucre
Hey guys, I was wondering if you could help me out here. I'm working on a project that needs two fast linear actuators which I'm planning to control with the Arduino logic board, but I can't seem to find anything that suits what I need. Here are the specs.
-Type of actuator: Linear
-Minimum acceptable speed: 100 mm/s
-Minimum acceptable load: 5kg
-Input: Signal from Arduino UNO logic board
-Frequency: Approx 10 Hz
I would appreciate any help that you guys could give me. All the actuators that I've found online are either too weak or too slow.
Dependent on the duty cycle required you could possibly overvolt http://www.servocity.com/html/25_lbs__thrust_linear_actuator.html
these @ 24VDC and get the 100mm/sec required.
If the actuators need to run more than intermittently, I would contact ServoCity about their recommendations. They've been easy to work with for this sort of thing in my experience.
Max travel?
Jupiter6 said:
Max travel?
Around 18"
