Question about artificial gravity (orbitting earth) in space
This discussion centers on the concept of artificial gravity in space, particularly in relation to a spaceship in orbit around Earth. It establishes that while Earth rotates at approximately 1,600 km/h, this rotation has minimal impact on perceived gravity due to the slow speed relative to the vast gravitational force of Earth. Astronauts appear weightless because they and their spacecraft are in free fall, experiencing gravity equally, which negates the sensation of weight. The discussion also highlights that in a rotating tube, individuals would experience a form of artificial gravity due to centrifugal force acting away from the axis of rotation.
  • Understanding of gravitational forces and their effects in space
  • Basic knowledge of orbital mechanics
  • Familiarity with centrifugal force concepts
  • Awareness of the principles of free fall and weightlessness
  • Research the physics of artificial gravity in rotating systems
  • Study orbital mechanics and the dynamics of spacecraft motion
  • Explore the effects of centrifugal force in different rotational scenarios
  • Learn about the experiences of astronauts in microgravity environments
Aerospace engineers, physicists, students of space science, and anyone interested in the principles of gravity and motion in space environments.
ihaveabutt
Considering artificial gravity can be created in a large enough tube orbiting an axis at a fast enough speed, consider the following:
If a spaceship is in a fixed orbit around the earth, wouldn't it be bound to Earth's axis by its gravitational pull? And if so, since the Earth rotates at 1,600 km/h, wouldn't there be a point where the angular momentum would be enough to mimmick the effects of gravity onboard? (<--more important question | not as important question -->) And if that's the case than why do astronauts always appear weightless?
Yep.
The rotation of the Earth has only a small effect on the perceived gravity at the Earth's surface. In other words, the Earth is just spinning too slowly to have much effect (except maybe on the tides). So almost all of the perceived gravity at the Earth's surface is due to actual gravity caused by the mass of the Earth.
They have nothing else to compare their motion to. Here on earth, the surface of the Earth is stationary, while we are getting pulled down by gravity. But astronauts get pulled down by gravity at the same rate as their spaceship, so they do not experience gravity on the floor of their spaceship.
Also, the example of the spinning tube, any person inside will naturally be falling away from the axis of rotation, while the tube stays rigid, so they do experience a 'perceived' gravity on the outer end of the tube.
  • · Replies 31 ·
22K
  • · Replies 36 ·
