Can a Battery-Powered Heater Wire Prevent Freezing in Fridge Drainage Tubes?
The discussion revolves around the issue of ice blockage in the drainage tube of a refrigerator, which leads to water accumulation inside the fridge. Participants explore potential solutions, including the feasibility of using a battery-powered heater wire to prevent freezing, as well as other factors that may contribute to the problem, such as temperature settings and airflow restrictions.
  • One participant suggests that a battery-powered heater wire could be placed inside the drainage tube to prevent freezing, though others express skepticism about the practicality of this solution due to power consumption concerns.
  • Another participant raises the possibility that the freezer temperature might be set too low or that airflow restrictions could be causing cold air to accumulate in the water reservoir, leading to freezing.
  • There are suggestions to increase the freezer temperature to prevent freezing without affecting frozen food, as long as it remains below -20°C (4°F).
  • Some participants mention the importance of ensuring the drainage tube is clean and free of obstructions, as food scraps or growth could impede water flow.
  • Discussion includes the potential malfunction of the defrost heater, which is responsible for melting ice in the freezer, and the need to inspect it for defects.
  • One participant notes that the fridge's insulation around the drainage pipe may be insufficient, contributing to the freezing issue.
  • There are inquiries about whether the fridge is level, as this could affect drainage and freezing.
  • Some participants share experiences with similar issues in other appliances, suggesting that the problem is not uncommon.
Participants express a range of views on the causes of the freezing issue and potential solutions. There is no consensus on the effectiveness of a battery-powered heater wire, and multiple competing explanations for the problem are presented, indicating that the discussion remains unresolved.
Participants highlight various factors that could influence the freezing issue, including temperature settings, airflow, cleanliness of the drainage tube, and the condition of the defrost heater. However, specific assumptions and dependencies on the fridge's design and environment are not fully explored.
bosklong
Hi there!
I recently noticed that the little drainage tube in the back of my fridge keeps blocking up with ice. As a result massive condensation develops around the ice which eventually drips down the back causing the bottom of the fridge to fill with water the whole time.
Apparently the insulation around the drainage pipe is too thin, causing the cold temperature to freeze the water.
The drainage tube is about 8mm in diameter. So I was wondering...is it possible to build a small battery powered heater wire that can be placed inside the drainage tube to prevent the tube from freezing up?
Hi bosklong, http://img96.imageshack.us/img96/5725/red5e5etimes5e5e45e5e25.gif
Can you post a pic? While anything is possible, it's difficult to imagine that the manufacturer's testing would have missed such a glaring flaw. Some alternative fix may provide a better/permanent solution.
Is this a new fridge, and still under warranty?
You may have the freezer temperature too low or the airflow to the fridge too restricted (by the temperature control) so that cold air accumulates in the water reservoir.
It is normal for some condensation to occur here, but the air coming from the freezer should not be cold enough to freeze the water before it flows down the tube.
The water comes from frost which forms on the walls of the freezer but is melted periodically so that it does not need to be defrosted later.
If it blocks, water can no longer flow down the the tube and it builds up in a little reservoir until it runs down the inside of the fridge at the back.
Try increasing the temperature of the freezer. This will save you power and have no effect on the frozen food as long as the temperature is still -20°C (4°F) or lower. Ensure that the control for the fridge temperature (if it is a mechanical one) is at least halfway open.
The tube can also get blocked with food scraps and then it needs to be cleaned with a pipe cleaner or similar.
Heating with a battery is usually a bad idea, because heating uses a lot of power, and you would have to exchange the battery a lot. If the drainage hole is open on the other side, you could try to put in a copper wire, to transport a little more heat from the outside into that hole.
Hi Guys,
Sorry, I was away for a couple of days.
Please find attached a picture as requested. The fridge is modern, but past its warantee, a with most electronics nowadays! There is definitely no food stuff falling down the drain pipe and the temerature is set correctly. I do however think that ventilation at the back of the fridge might be a cause to the problem as listed earlier by someone. Kitchen cupboards are built all around the fridge, preventing good ventilation. My dad has asked around and some of the local refrigeration companies reckon the insulation around the pipe in the back is not sufficient to prevent the drain pipe from cooling to such an level where it freezes the droplets. Naturally the more ice is present, the faster it freezes up.
Have you checked to see if the fridge is level? Also, some fridges have a defrosting element in the freezer section and if it's defective...
Have you tried to clean the tube really well - it is very easy to stuff to start growing in there, reducing the ease of flow.
What's behind those two screws?
That looks like the defrost heater cover to me.
Defrost heater comes on once a day to melt ice from the coils, and that looks like many days worth of ice...
I would inspect the heater to make sure it's not got a melted spot anywhere.
If it's not heating along its whole length it may not warm the drain tube during defrost cycle.
They are usually "Calrod" heating elements, a black tube about diameter of a pencil.
When they short out it makes a small crater where the case melts through and the remainder of its length makes no heat.. Sometimes a breaker trips and sometimes not, depending on where the fault occurs.
Also, with that much ice - are you sure you don't have a leaking icemaker valve?
You can probably find a parts diagram at the manufacturer's site - unless it's an LG brand.
Sears has a pretty good portal into a large appliance industry parts database.
good luck !
[off-topic] You got that right. I have large capacity '76 model Kenmore washer & dryer that's had a couple parts ware out over the years. I can call them with the old part number and have a new one at my door the next day; and for cheap. [/end off-topic]
good luck !
I've found the cheap bi-metal over-temp switch bad in several that I've fixed over the years. It's dies open so the heater coil never gets hot.
Example switch: http://www.alibaba.com/product-gs/542665482/KSD_ST_001_N13_4_SAMSUNG.html
I see that typed wrong in the beginning...Its not my fridge, but one at my folks's house. I will be visiting again within the week and follow up on some of your questions...
The fridge is level, but I'm not sure about the defective element...will have to inspect.
Yes, every time my dad defrost the chunk of ice he will brush the downpipe to make sure everything is clean.
Not sure, but I will open up and take some pictures.
good luck !
Un/fortunately there is no ice maker on the unit. I will note all the details,eg model number on my next visit.
Thanks for all the help so far!
This effect is not uncommon, I believe. I have found it in a 'frost-free' freezer and the only solution in that case was to let the whole machine defrost completely. Clearly, the 'has it defrosted?' sensor is not in the appropriate place and is too optimistic. But inside a freezer compartment, everything is well sub-zero and the defrost element has a hard job to do. You can tell if the defrost heater in the fridge compartment is actually working because the frost on the cooling plate should melt visibly and form drops which run down into the drip channel just before the compressor starts to run. A thin piece of wire, pushed down the whole length of drain tube should clear any obstruction that could be preventing water from clearing but if there's a plastic / rubber section in the pipe, it may have a kink which still interferes with the draining. The drip channel shouldn't ever get below 0C in a normal fridge compartment so any water in it should run away before the cooling starts again. Have you tried running the fridge at a slightly higher (temperature) setting? Could the fridge be over-full in that area and allowing the drip channel to get too cold by restricting air flow to the rest of the cabinet?
Problem is that these things take a long time to sort out and you really need to be there over a longish period.
16K
  • · Replies 30 ·
9K
  • · Replies 39 ·
18K
