How to Prove the Classical Angular Momentum Commutation Relation?
The classical angular momentum commutation relation is expressed as {Li, Lj} = εijkLk, where Li represents the components of angular momentum and εijk is the Levi-Civita symbol. To prove this relation classically, one must express Li in terms of generalized coordinates (qi) and momenta (pi) and apply the definition of the Poisson bracket. The discussion highlights the importance of clarity in notation, particularly avoiding confusion with square brackets in classical mechanics. Additionally, the extension of this relation to a general vector Vi is addressed, suggesting that the same commutation relation holds if Vi is appropriately constructed.
  • Understanding of classical mechanics and angular momentum
  • Familiarity with Poisson brackets
  • Knowledge of the Levi-Civita symbol and its properties
  • Basic concepts of vector algebra in physics
  • Study the derivation of Poisson brackets in classical mechanics
  • Explore the properties and applications of the Levi-Civita symbol
  • Investigate the construction of generalized vectors in classical mechanics
  • Learn about angular momentum in both classical and quantum contexts
Physics students, researchers in classical mechanics, and anyone interested in the mathematical foundations of angular momentum and its applications in theoretical physics.
ssamsymn
[Li,Lj]=εijkLk
how can I prove this expression classically?
Classically, L is not an operator, so you cannot define a commutator.
You can show that {Li, Lj}=εijkLk. I don't know if that's what you meant by saying "Classically". If so, just write out Li in terms of qi and pi. If you write the correct expression for it using Levi-Civita symbol and apply definition of Poisson bracket, it should be a trivial matter.
Yes, exactly. Thank you very much. Using square brackets may be confusing in classical mechanics. I figured out to make this with levi civita symbol. But there is another problem I have now. if I replace the Li with some general vector Vi, it should still be hold
{Vi,Lj}=εijkVk
how should I constract a general V vector?
  • · Replies 30 ·
  • · Replies 16 ·
