Parton distribution functions plot axes
The discussion revolves around the labeling and interpretation of axes in parton distribution function plots, specifically the vertical axis denoted as xf(x, Q^2). Participants explore the meaning of this notation and its implications for understanding parton momentum fractions within protons.
  • One participant expresses confusion regarding the labeling of the vertical axis as xf(x, Q^2) instead of just f(x, Q^2), questioning the inclusion of 'x'.
  • Another participant clarifies that f and xf represent different concepts, where f is the fraction of partons carrying a momentum fraction x, and xf indicates the fraction of the proton's momentum carried by those partons.
  • A participant suggests that plotting xf instead of f compresses the functions vertically, noting that while f increases significantly for low x, the product xf increases less dramatically.
  • Further clarification is provided that xf represents the fraction of the proton's momentum carried by partons with momentum fraction x, which raises questions about the vertical axis exceeding 1.
  • One participant proposes an analogy of the proton as a "sack of balls" to explain the distribution of momentum among partons, questioning if this is a valid conceptualization.
  • Another participant emphasizes that the integral of xf(x) must equal 1, indicating that the total momentum carried by all constituents sums to 1, while the integral of f(x) can yield different sums.
  • A later reply reiterates the importance of the parton distribution function, stating that it represents the probability of a parton carrying a fraction x of the proton's total momentum, reinforcing the focus on xfi(x) as significant.
Participants exhibit some agreement on the definitions of f and xf, but there remains uncertainty and debate regarding the implications of these definitions, particularly concerning the vertical axis exceeding 1 and the conceptualization of parton distributions.
There are unresolved questions regarding the interpretation of momentum fractions and the behavior of integrals related to parton distribution functions, as well as the implications of using the product xf in plots.
MarekS
I am slightly confused by the labelling of the vertical axis on parton distribution function plots.
Take the one here: http://www.hep.phy.cam.ac.uk/~wjs/partons2008nlo.jpg
as an example.
The vertical axis is labelled as xf(x, Q^2), where f is the probability density of finding a particular parton with a given longitudinal momentum fraction x.
I think it should simply be f(x, Q^2). Why the extra 'x' in front of f?
f and xf are two different things. f is the fraction of partons carrying a momentum fraction f, and xf is the fraction of the proton's momentum carried by partons that each carry a momentum fraction x.
Is the purpose of plotting the product xf instead of f to compress the functions along the vertical direction? That is to say, f goes up for low x quite a bit, but the product xf increases less as one decreases x.
It does that, but the purpose is to represent something different than the fraction of partons carrying a momentum fraction x. It's to represent the fraction of the proton's momentum carried by partons that each carry a momentum fraction x.
I am having difficulty parsing this sentence. "fraction of the proton's momentum" would imply the vertical axis wouldn't go above 1, but it does. Could you phrase it longer/differently?
If I think of the proton as a sack of balls with the sack moving with a large momentum, then all the balls must be moving at the same speed or they wouldn't stay together. In the approximation that the differences in mass are negligible then all the balls will have the same momentum. That is to say, if a ball has momentum fraction x, then there must be 1/x balls in total in the sack each carrying fraction x of the sack's momentum.
Being a quantum sack, the number of balls is not fixed and it is the task of the balls' distribution function to determine the number and kind of them (e.g 10 gluon balls, 2 up balls, 1 down ball).
Is this the right way to think about it?
Maybe examples will help:
The integral of xf(x) must be 1. (The fraction of momentum carried by all of its constituents must sum to 1).
The integral of f(x) can sum to anything.
The integral of u(x)-ubar(x) must sum to 2. (2 up quarks)
The integral of d(x)-dbar(x) must sum to 1. (1 down quark)
The point of having a parton distribution function of course is that they do not all have the same momentum. Paraphrased from Halzen and Martin: fi(x) represents the probability that a particular parton carries a fraction x of the proton's total momentum. All the fractions have to add up to 1, therefore ∑i∫ xfi(x) dx = 1.
And thus good reason for focusing on the quantity xfi(x), which as 50V said, is "the fraction of the proton's momentum carried by partons that each carry a momentum fraction x."
