Dale
Mentor
- 36,454
- 15,183
You have been given some good advice, which you seem reluctant to take, so let me try as well.Moonraker said:The “clock” of the photon shows 0 seconds, according to the above-mentioned time dilation formula:
T‘ = T * sqrt (1-v2/c2),
even if the Lorentz transformation does not apply to photons.
The Lorentz transform is (in part)
t=\frac{1}{\sqrt{1-v^2/c^2}}\left( t' - \frac{vx'}{c^2}\right)
In this equation t and t' are coordinate times in the two frames and v is the relative velocity between the primed and unprimed frames. Since both frames are inertial this v is constrained by -c<v<c.
When you make the simplification x'=0 then you get the equation you posted above:
t'=t\sqrt{1-v^2/c^2}
Here v is still the relative velocity between the primed and unprimed frames. The simplification does not change that in any way, so it is still constrained by -c<v<c. It isn't a matter of whether or not the equation has a division by zero or not, it is simply that doing a little algebra does not change the valid domain of a variable.
Also, t and t' are both coordinate times, not proper times, so they remain coordinate times after the simplification. However, this is a rather minor point. For a clock at x'=0 we have \tau = t', so we can easily make that substitution when we make the simplification, giving: \tau=t\sqrt{1-v^2/c^2}, where t is still a coordinate time but now \tau is a proper time. But even so, -c<v<c.
I hope you agree that the above qualifies as a good reason not to apply the time dilation formula.Moonraker said:There is no reason not to apply the time dilation formula (if there is please let me know), and there are many reasons in favor of application.
