A Few Numbers With Strange Qualities
  • Context: High School
  • Thread starter Thread starter suzi9spal
    Numbers Strange
The discussion revolves around a mathematical exploration of numbers that exhibit a unique looping property when subjected to a specific iterative process involving the sum of the squares of their digits. Participants share their findings, insights, and challenges regarding this property, as well as references to external resources.
  • The original poster (OP) identifies numbers such as 1, 4, 16, 20, 37, 42, 58, 89, and 145 as having a looping property based on a defined iterative process.
  • Some participants suggest that the numbers form a cycle, where starting from any of them leads to the same collection of numbers.
  • One participant provides a link to a resource that discusses similar number games and references a book by J. Madachy.
  • Another participant challenges the claim of a limited number of such looping numbers, questioning whether it has been proven.
  • Several participants discuss the mathematical reasoning behind why numbers with more than three digits cannot be part of a loop, citing the maximum possible sum of squared digits.
  • One participant mentions testing numbers up to 13 million to find those with the looping property.
  • Another participant references Sloane's database, confirming the list of numbers as finite.
  • One participant suggests that the OP's interest in number properties is commendable and recommends exploring the Collatz conjecture as a challenging problem.
There is no consensus on whether the claim of a limited number of looping numbers has been definitively proven. Multiple viewpoints exist regarding the mathematical reasoning behind the properties of these numbers, and some participants express confusion about the explanations provided.
Participants express uncertainty about the proof of the limited number of looping numbers and the reasoning behind the transition from n-digit to 4-digit numbers. There are references to external resources that may provide additional context but are not universally accepted as definitive.
suzi9spal
Hello everyone!
I'm a 1st grade student in a slovenian high school. Recently, I've became very interested in numbers and math itsself.
I was just playing around with a few numbers, when I came across a few that are unique. I was wondering which numbers can loop back
to themselfes after this procedure;
n is a digit, m is a digit, o is an integer, p is another integer
Code:
o = mn
p = m^2 + n^2
o = p
...repeat...
For instance, 16 is one of these numbers;
1^2 + 6^2 = 1+36 = 37 ==> 3^2 + 7^2 = 9+49 = 58 ==> 5^2 + 8^2 = 25+64 = 89 ==>
8^2 + 9^2 = 64+81 = 145 ==> 1^2 + 4^2 + 5^2 = 1+16+25 = 42 ==>
4^2 + 2^2 = 16+4 = 20 ==> 2^2 + 0^2 = 4+0 = 4 ==> 4^2 = 16
I then created a program to find every single number that has this property. It turns out, there are only a limited few:
  • 1
  • 4
  • 16
  • 20
  • 37
  • 42
  • 58
  • 89
  • 145
I thought this was interesting, so I posted it here.
Did anyone find something like this before?
Hello, suzi9spal, and happy new year!
Personally I've never seen this before, but I found something after googling a bit. The following link describes it, and also contains a reference to a book by J. Madachy (which I haven't read) that explores this and other similar number games.
http://mathworld.wolfram.com/RecurringDigitalInvariant.html
Notice that, apart from 1 where the property is trivially true, the other numbers that you discover form a cycle, and you can start from any of them and obtain the same collection of numbers. These are the "cycles" that the link above refers to.
And keep these kinds of hobbies! They will greatly pay off when you go to the university.
here's a helpful link. If you sequence is new, you will not find it here.
http://oeis.org/
if it is known, then you will find it.
And you have proved that?
It's not very hard. If you start with an n-digit number, the largest number that could follow it is 81n. A 4-digit number would have at most 324 following it. All the numbers following it will have 3-digits or less, so a 4-digit or larger number can't be part of a loop, so there are only 1000 numbers you have to check.
I'm sure you're correct but I don't follow what you've said. (You're probably right and I just need a lie down...)
However, it is intriguing that, other than the trivial 0 and 1, the other numbers in this list all sum up to 16 in their digits.
oay, I have tested every single number to about 13 milion :D
I don't get how you've gone from an n-digit to a 4-digit with no explanation.
I'm sure you have, and I don't disbelieve you, I just don't see the proof!
oay said:
... I don't follow what you've said.
What willem2 was saying is that, for all possible n-digit numbers, the sum of squared digits is at its largest when the n-digit number is 9999... (n nines), and that sum is 9^2 . n = 81n.
So, for different values of n (number of digits), you can see that
n=1: 81n = 81 (so, the sum of squared digits has at most 2 digits)
n=2: 81n = 162 (so, the sum of squared digits has at most 3 digits)
n=3: 81n = 243 (so, the sum of squared digits has at most 3 digits)
n=4: 81n = 324 (so, the sum of squared digits has at most 3 digits)
You can see that, when applying the process of adding the squared digits, a 4-digit number can only become smaller (since the result won't be larger than 324).
For n>4, you have that 81n < 10^n (just like the case n=4), so numbers of 5,6,7... digits also become smaller when adding the squared digits.
Therefore, for numbers of 4,5,6,7,... digits, the process of adding the squared digits has no chance of returning to the original number. So you only need to test numbers up to 3 digits.
This has already been described on Sloane's database: http://oeis.org/A039943
It's tagged "fini" for finite - confirming that this is the exhaustive listing.
I love that resource! I've got a few sequences accepted long ago.
I like the OP's interest in this sort of thing, because it reminds me of myself at that age. OP, if you're interested in a genuinely unsolved (and maddening) integer-recursion problem, look up the Collatz conjecture. And before you write a program for that one, try starting out with 27 using just pen and paper (and a calculator, if you wish).
Nope, you need to explain it more clearly!
  • · Replies 30 ·
  • · Replies 24 ·
  • · Replies 48 ·
