Dimensionless analysis in engine cooling
The discussion revolves around the application of dimensional analysis in the context of measuring the cooling performance of a car engine on a chassis dynamometer. Participants explore theoretical aspects of dimensional analysis, particularly the Buckingham pi theorem, and its relevance when certain parameters are held constant. The conversation includes considerations of various physical properties and their roles in forming dimensionless groups.
  • One participant questions the applicability of dimensional analysis when most parameters are constant and seeks clarification on how many dimensionless parameters can be derived from their specific variables.
  • Another participant emphasizes the necessity of including physical properties in the dimensional analysis to form proper dimensionless groups, citing examples like the Prandtl number, Reynolds number, and Nusselt number.
  • A participant lists relevant quantities for their analysis and expresses confusion about the inclusion of dimensions and additional factors such as pressure drops and water pump power.
  • One participant advises breaking the problem into smaller parts, suggesting a focus on the radiator as a starting point, and discusses the importance of various parameters in heat exchanger modeling.
  • A later reply acknowledges the advice but notes that they will not be conducting the measurements, indicating a shift in their involvement in the practical aspect of the problem.
Participants generally agree on the importance of including physical properties in dimensional analysis, but there is no consensus on how to approach the problem given the complexity and the participant's specific circumstances. The discussion remains unresolved regarding the best path forward for the participant's analysis.
Limitations include the participant's uncertainty about which dimensions to include in their analysis and the complexity of the physical system being studied, which may affect the applicability of dimensional analysis.
Zirkus
Hi, I have a problem with measuring cooling performance of a car on a chassis dynamometer. But maybe I should start with the theoretical part of my problem, namely with the dimensional analysis.
If I have a physical system and I am interested in finding one variable as a function of all other variables on which this one depends, I can use the Buckingham pi theorem and reduce the number of parameters involved. I think I understand how to do that. But what if most of these parameters are kept constant all the time and I am not interested in how their changes influence my output variable, can I still use this theory?
In my particular case I measure temperatures in several places of an engine and of the cooling circuit as a function of mass flow of the coolant, blowing air velocity and temperature, braking power and rpm of the dynamometer and gas pedal position (not sure about this one though), some of which are themselves functions of time. The temperatures will be definitely dependent on changes of other parameters as well (thermal capacities, viscosities, densities etc.) but I am not changing these. Can I still use the dimensional analysis on my (probably) seven variables? And how many dimensionless parameters would that give me?
Thank you for any reactions.
Science news on Phys.org
You can't really leave out the physical properties, because they will be critical to arriving at the dimensionless groups. You will not be able to form the proper dimensionless groups without including the physical properties, since their dimensions will cancel in the formulation of the key dimensionless groups. For example, in your system, some of the groups involved will the the Prantdl number, the Reynolds number, and the Nussult number. All of these involve the physical properties.
I see, that is what I suspected, thank you.
If I tried to list all the relevant quantities in this problem I would get to something like:
[tex]T_i=T_i(u_{air}, T_{air},\rho_{air},c_{p,{air}},\nu_{air},\dot{m}_{coolant},\rho_{coolant},c_{p,{coolant}},\nu_{coolant},P_b(t),N(t),\beta(t)),[/tex]
where the last three symbols denote braking power, rpm and gas pedal position. Did I forget about something? How is it with dimensions (lengths) actually...I don't measure on a model but on the real thing. Should one length appear anyway? And how about pressure drops, water pump power...I'm really confused. Thanks for any help.
You are trying to do too much to begin with. One of the basic principles that I recommend in doing good modeling is to break the problem down into smaller bite sized chunks. Why? if you can't do the smaller simpler problem(s), you will never be able to solve the fully integrated problem. Plus, once you get some results for the simpler problem, you will already have your overall problem partially solved, and it may give you insight into the larger problem.
With that said, I recommend you start out by first focusing attention exclusively on the radiator. You have coolant going in at one temperature, and coming out at a cooler temperature. The radiator is a finned heat exchanger. The tube diameters, lengths, and layout are important. The fin geometry and spacing is important. Coolant properties and air properties are important. If you know that air velocity from the fan, that is a parameter to include. Have you learned yet how to set up the differential equation for the coolant heat balance in this type of heat exchanger? If you have, then, rather than using Buckingham, you can reduce the differential equations to dimensionless form and elucidate the key dimensionless groups very easily. Have you learned about heat transfer coefficients? on the air side? and on the coolant side of the tube wall? The heat transfer coefficient on the coolant side of the boundary is a function of the coolant flow rate (velocity), the coolant density, the coolant viscosity, the tube ID, the coolant thermal conductivity, the coolant heat capacity. The dimensionless heat transfer coefficient is called the Nussult Number.
Until I know your background regarding fluid mechanics and convective heat transfer, I will have trouble advising you further. But, all I can say is that you need to be able to do the radiator first.
That is completely true, as a matter of fact I won't be doing the measurment at all in the end, so your nice answer goes in vain...sorry about that. At least I lerned a bit about dimensional analysis, mostly from these lecture notes from MIT, which describe the abovementioned situation of changing only some of the relevant quantities (starting at page 50):
http://web.mit.edu/2.25/www/pdf/DA_unified.pdf
Thank you once again!
  • · Replies 32 ·
16K
  • · Replies 109 ·
10K
