Cardinality of class of worlds in quantum MWT
The discussion revolves around the cardinality of worlds in the context of an Everett-type Many-Worlds Theory (MWT) of Quantum Mechanics. Participants explore the implications of quantum mechanics on the number of worlds, particularly in relation to particles and their interactions, as well as the mathematical frameworks that describe these worlds.
  • Some participants propose that in an Everett-type MWT, each probability amplitude corresponds to a world, suggesting that the number of worlds could be as large as the continuum.
  • There is a question about whether the relationships between particles in different worlds are the same or can vary, which could affect the total number of worlds depending on the assumptions made.
  • One participant notes that the cardinality of worlds in the context of MWT is likely that of the continuum, as Hilbert space is defined over the complex numbers.
  • Another participant discusses the necessity for worlds to be decoherent to be considered distinct, implying a need for a definition of separation in Hilbert space.
  • There is a query about how to define 'distance' in Hilbert space and what constitutes 'sufficient decoherence' for worlds to be counted as separate.
  • One participant argues that the concept of counting worlds may not be meaningful unless specific conditions are met, such as equal weights in a convex combination of states.
  • Another participant emphasizes that the cardinality of infinite sets is not something that can be physically tested, suggesting that the choice of cardinality in theories is incidental.
Participants express differing views on the implications of cardinality in MWT, particularly regarding the nature of worlds and their interactions. There is no consensus on how to define or count these worlds, and multiple competing perspectives remain throughout the discussion.
Limitations include unresolved definitions of distance and decoherence in Hilbert space, as well as the implications of different interpretations of Many-Worlds. The discussion reflects a range of assumptions about the nature of worlds and their mathematical representation.
nomadreid
Two (related) questions:
(A) If I understand correctly (no guarantee to that), in an Everett-type Many-Worlds-Theory of Quantum Mechanics, every probability amplitude is associated with a world. This would mean, for a single particle, that there would be as many worlds ("be" in the sense of a model similar to a Kripke Frame, without taking a stand on any other type of existence) as the continuum. In fact, not only for a particle, but for a point (or quantum grain) in spacetime. Given that the largest proposed cardinality for the number of points or grains seems to also be that of the continuum, the product still ends up giving the number of worlds as the continuum. Is this a valid conclusion?
(B) However, (and here is where things get really shaky), given 2 particles, then are there also various possible relations between the two particles in the different worlds (e.g., different strengths of gravity,etc.), or are these considered to be the same (that is, if two particles are the same in two different worlds, can one assume that the interactions between them are also the same?). In the former case, then given c (continuum) particles (or grains, or points), the number of relations would be 2c, thus giving 2c number of worlds, whereas in the latter case, the number of worlds would remain at c. Which one, or neither, is applicable?
(I am not sure whether physicists care about cardinality, but a mathematician definitely would.)
You should not confuse diffent meanings of 'Many Worlds'.
1) The MWI according to QM refers to one theory where the evolution of the wave function is interpreted as branching into many worlds.
2) String theory indicates that there may exist different solutions in a landscape of theories described by different interactions.
3) According to inflationary scenarios there may exist universes in a larger multiverse where there may.
The fundamental difference is where these worlds exist and in which sense one has to count them, or in which sense one can define a probability measure or whatever
Worlds in the sense of 1) exist in a Hilbert space
Worlds in the sense of 2) live in 'theory space'
And worlds in the sense of 3) live in a spacetime manifold (or some generalization)
thanks, tom.stoer; as I was interested in the MWT#1 in your list, I guess the answer is that the cardinality is that of the continuum 2[itex]\aleph[/itex]0, since Hilbert space is defined over the complex numbers.
I am interested in counting them to know how the "worlds" would look as "worlds" in a Kripke frame or something similar.
To be considered as different worlds, those regions in Hilbert space should be separated enough to have a negligible interaction - in other words, they should be decoherent. If your initial state has some similarity to a classical state ("one world") or a superposition of some classical states, you get a finite (but extremely large) number of worlds after a finite time.
How should one define the relevant 'distance' in the Hilbert space? How can one define 'sufficient decoherent'? Is there a geometrical definition using rays or density matrices? Is there a way to 'partition the unit sphere in different worlds
And based on that - is there a way to define the counting?
If the density matrix A of the state can be approximately written as a convex combination of the density matrices of pure states:
[tex]A \approx \sum_{i=1}^n c_i | \psi_i \rangle \langle \psi_i |[/tex]
then this summation remains valid after unitary evolution too. So, it's fair to describe the state described by A comprising multiple worlds each described by the [itex]| \psi_i \rangle[/itex], weighted by the values [itex]c_i[/itex].
"Counting" really isn't the right word, except in the very special case where you write a sum with all of the [itex]c_i[/itex] the same value.
Note that the decomposition described above is not unique; e.g. for a qubit, the state comprising spin up around Z and spin down around Z in equal weights is the same as the state comprising spin up around X and spin down around X in equal weights.
Anything you like, the "number of worlds" will depend on that, but I think this number is not really interesting anyway.
https://www.physicsforums.com/showthread.php?t=632734
In any case, the cardinality of an infinite set is never something that can be physically tested. If a theory describes nature using an infinite set of this cardinality or that cardinality, that's an incidental feature of that particular presentation of the theory. The set of possible experiments and experimental outcomes is countable. We could construct all our physical theories using the rationals rather than the reals. The reals are just more convenient.
  • · Replies 16 ·
  • · Replies 47 ·
