How to find angle after two rotations
  • Context: Graduate
  • Thread starter Thread starter 1MileCrash
    Angle Rotations
The discussion focuses on determining the angle between two axes after performing two rotations in a 3D coordinate system. The first rotation is a 30-degree rotation around the z-axis, represented by the rotation matrix R_z. The second rotation is a 30-degree rotation around the y-axis, represented by the rotation matrix R_y. The combined effect of these rotations can be calculated by multiplying the two matrices, allowing for the determination of the new angle between the original and transformed axes.
  • Understanding of 3D coordinate systems
  • Familiarity with rotation matrices
  • Knowledge of matrix multiplication
  • Basic concepts of quaternions for spatial rotation
  • Study the properties of rotation matrices in 3D space
  • Learn about quaternion representation of rotations
  • Explore tensor transformation laws in physics
  • Practice matrix multiplication with rotation matrices
Mathematicians, physicists, computer graphics developers, and anyone involved in 3D modeling or simulations requiring an understanding of spatial rotations.
1MileCrash
I have coordinate system A with bases a, b, c.
Say I rotate the whole system 30 degrees, so that the angle between a and a' is 30 degrees.
Then I make another rotation so that this plane of rotation is perpendicular to that of the old one.
What is the angle between a and a' now?
I am trying to find the angles to use in a tensor transformation law, but I am having problems understanding what the angles will be between the old and new axes when a transformation isn't just a single rotation in one plane of the system.
Tia
You can write any rotation as a matrix multiplication. Then two rotations is given by the product of the two matrices.
For example, if you wrote 30 degrees around the z- axis, the rotation is given by
[tex]\begin{bmatrix} cos(30) & -sin(30) & 0 \\ sin(30) & cos(30) & 0 \\ 0 & 0 & 1\end{bmatrix}= \begin{bmatrix}\frac{\sqrt{3}}{2} & -\frac{1}{2} & 0\\ \frac{1}{2} & \frac{\sqrt{3}}{2}& 0 \\ 0 & 0 & 1\end{bmatrix}[/tex]
A rotation around the y-axis, through 30 degrees is given by
[tex]\begin{bmatrix} cos(30) & 0 &-sin(30)\\ 0 & 1 & 0 \\ sin(30) & 0 & cos(30) \end{bmatrix}= \begin{bmatrix}\frac{\sqrt{3}}{2} & 0 & -\frac{1}{2} \\ 0 & 1 & 0 \\ \frac{1}{2} & 0 & \frac{\sqrt{3}}{2}\end{bmatrix}[/tex]
The two rotations together would be given by the product of the two matrices.
  • · Replies 40 ·
9K
