Estimating the number of galaxies
  • Context: Undergrad
  • Thread starter Thread starter jimjohnson
    Galaxies
The discussion revolves around estimating the number of galaxies in the observable universe based on the Hubble deep field image and related calculations. Participants explore various methods for calculating the area of the sky and how this relates to the total number of galaxies, considering both visible and potentially unobservable galaxies.
  • Some participants inquire about the percentage of 3 x 3 arc minutes relative to the total area of the sky, suggesting that this ratio could help estimate the total number of galaxies.
  • One participant mentions that for small angles, the sky can be approximated as flat, allowing for simpler area calculations.
  • Another participant calculates that 3 x 3 arc minutes comprises about one ten millionth of the celestial sphere's surface area.
  • There are differing estimates of the total number of galaxies, with one participant suggesting 5.2 x E10 galaxies based on visible observations, while another argues that the total number is likely much larger, including unobservable galaxies.
  • One participant corrects their earlier calculations, arriving at an estimate of 1.56 x E11 galaxies based on the area of the Moon and extrapolating from the Hubble ultra deep field image.
  • Another participant points out that the estimates of 155-165 billion galaxies may be an underestimate due to the existence of dim galaxies not visible to Hubble.
  • Discussions also touch on the definition of the observable universe and the complexities involved in estimating galaxy numbers based on different criteria.
  • Some participants express uncertainty about the limits of observation and the implications of the cosmic microwave background radiation (CMBR) on galaxy visibility.
Participants express multiple competing views regarding the total number of galaxies and the definitions of the observable universe. There is no consensus on the estimates or the methods used to derive them.
Participants note limitations in their calculations, including assumptions about the observable universe's boundaries and the complexities of defining what constitutes observable galaxies.
This discussion may be of interest to those studying cosmology, astrophysics, or anyone curious about the methods used to estimate the number of galaxies in the universe.
jimjohnson
The Hubble deep sky image is 3 x3 arc minutes and shows an estimated 10,000 galaxies. What percent is 3 x 3 arc minutes of the total area? If this ratio is known, one could estimate the number of total galaxies. Thanks
Space news on Phys.org
hi jim! :wink:
the total area is 4π,
and 3 arc minutes is π divided by … ? :smile:
I know the area of a sphere is 4 x π x r2 . But what percent is the area of 3 x 3 arc minutes? When you look up at a dome, a square is not a square except at the horizon. There may be a simple answer but it is not obvious to me. Thanks
For small angles, you can approximate the sky sphere as flat. Just find the area of the square. Should be close enough.
Compared to the celestial sphere, 3x3 arc minutes only comprises about one ten millionth of the surface area of the entire sky. All you need to do is calculate the surface area of the celestial sphere and compare it to 9 square arc minutes.
Thanks, I was having a mental block. The result is 5.2 x E10 galaxies which is similar to other estimates assuming a finite universe.
Not assuming a finite universe. These are just measures of the visible galaxies. The total number, including the parts of the universe we can't observe, is almost certainly vastly larger. How much larger? We don't know.
Good point, I should have said the "observable universe".
Also, in the original calculations I erroneously inserted the diameter of the Moon rather than the radius. Thus, the correct number of galaxies extrapolated from the Hubble ultra deep field image is 1.56 x E11.
My calculations are probably unorthodox ( a simpler way may exist). But, I used the Moon's radius to compute the Moon's area. The Moon's distance from the Earth was used to compute the surface area of a sphere. Dividing the larger area by the smaller area defined the number of Moons required to fill the entire sphere, 2 x E5.
Addressing the ultra image, 3 x 3 arc minutes (9 square arc minutes) is 78 times less than the area of the Moon with a 15 arc minute radius (706 square arc minutes).The factor used to extrapolate from the 10,000 galaxies in the image was 1.56 x E7 (2 x E5 x 78) which gives 1.56 x E11 galaxies.
I did the same calculation for the Hubble eXtreme deep field which is 2.3 x 2 arc minutes and has an estimated 5,500 galaxies. The answer was 1.67 x E11 galaxies - consistent results.
The Hubble images support an estimate of 155-165 billion galaxies in the observable universe.
Comments?
Comments?
I'd just mention that this is a significant underestimate, as there are a great many galaxies that are too dim for Hubble to see.
This wiki page seems useful:
http://en.wikipedia.org/wiki/Cosmological_horizon#Particle_horizon
Nice plaque - shame it is completely wrong!
I also just noticed that this wiki page says 80 Billion galaxies in the obervable Universe, so they must have a different definition for the size of the observable universe..To calculate the total number of galaxies in the observable universe, it should be possible to estimate the numbers of galaxies per unit volume
and calculate the total volume of the Observable Universe based on the CMBR radius.
On second thoughts we also need to consider that the first galaxies didnt form until around 400Million years after the CMBR so the light from the most distant galaxies cannot reach us despite the matter originally being within the CMBR radius when it was first emitted. Perhaps we need to define the what is meant by the observable universe, because there seems to be more than one possibility.
The Wikipedia article references the 1996 Hubble image and in the original NASA writeup it says there are probably many more.
My references are based on the 2003/4 images.
The definition of observable universe is how far we can see, over 13 billion light years to the farthest galaxies.
Do you still think the estimate is wrong?
Thanks Jim, I had been interpreting the observable universe to be the CMBR radius because those atoms are, well, a part of the observable universe.
In principle we should one day be able to observe galaxies a little older and more distant than the ones we see today, but I am not sure what the limit is.
It is more complex than the statement in my previous message.
One way to think of it is to state the the observable universe is a slice in both space and time. That way the number of galaxies in the observable universe is very well-defined: it's the total number of galaxies that we can observe, neglecting the fact that we might not be able to see a few of them because they are hidden behind other galaxies (or hidden by our own).
My unorthodox way of calculating the area is not necessary because the NASA bulletin describing the ultra deep field image stated that the oldest galaxy existed when the universe was 800 million years old. Thus, a radius can be calculated directly: 13.7 billion years - 800 million tears = 12.9 billion light years. This would be the distance to the faintest galaxies. The surface area of this sphere is 2.09 x E21 light years. Since the image was 3 x 3 arc minutes, the area of the image is 1.38 x E14 light years. Dividing the surface area by the image area gives a ratio of 1.52 x E7. This times 10,000 = 1.52 x E11 galaxies. As noted in previous posts, this assumes an observed universe defined at about 13 billion light years.
  • · Replies 49 ·
  • · Replies 0 ·
  • · Replies 40 ·
