Dale
Mentor
- 36,908
- 15,896
I think that is making a pretty big assumption about the disposition of those following the debate.Sugdub said:Your last reply won't convince those who followed our debate.
The transformation he derived is a single-parameter linear transform which maps lines of constant position in one frame to lines of constant velocity in another frame. That is a boost, by definition. Simply look at the equation at the end of section 3, it is clearly a boost.Sugdub said:I challenge the view that the transformation derived by Einstein in the "kinematics" part of his 1905 SR paper could actually account for a boost: the transformation he derived does not respond to a change of reference frame.
The thing I was supporting was your understandable confusion over the use of "observers" in SR as a shorthand for a reference frame. It isn't even relevant here since there are no observers mentioned at all in the scenario under discussion, as I already pointed out with a verbatim quote of the entire paragraph in question.Sugdub said:However you now become aware of the unavoidable consequences of that discovery and you want to escape. You should feel free to retract your initial support to my analysis. No need to argue, it's much better to play it honestly.
