Question about Newton's Law of Cooling
Newton's Law of Cooling is mathematically represented by the formula T(t) = Ta + (To - Ta)e^(-kt), where T(t) is the temperature at time t, Ta is the ambient temperature, and To is the initial temperature. The cooling constant k is crucial as it indicates the rate of temperature change, with larger values of k signifying faster cooling rates due to factors like insulation and heat capacity. Understanding k's role is essential for accurately applying this law in practical scenarios.
  • Understanding of differential equations
  • Familiarity with exponential functions
  • Knowledge of thermal properties such as heat capacity
  • Basic concepts of insulation and heat transfer
  • Research the derivation of Newton's Law of Cooling
  • Explore the impact of insulation on cooling rates
  • Learn about heat capacity and its influence on temperature change
  • Investigate real-world applications of Newton's Law of Cooling in engineering
Students studying physics or engineering, professionals in thermal management, and anyone interested in the practical applications of cooling laws in various systems.
gokuls
Newton's law of cooking
T(t)= Ta+(To-Ta ) e^(-kt)
or search it up online for a cleaner formula.
Anyways, what does the cooling constant k represent. What do larger or smaller values of k mean?
Thanks
What do you mean by a "cleaner" formula? Are you working on a specific problem? Perhaps it doesn't need Newtons law of cooking to solve it?
Anyway scroll down..
http://www.ugrad.math.ubc.ca/coursedoc/math100/notes/diffeqs/cool.html
k is a constant. Newton says the rate of change of the temperature of an object is proportional to the difference between its own temperature and the ambient temperature. "Proportional to" implies a constant...
dT/dt = -k(T-Ta)k depends on the physical properties of the system... How well insulated it is, the heat capacity of the object etc
  • · Replies 35 ·
