Quiscent voltage as mention in my hall sensor
  • Thread starter Thread starter proing
    Sensor Voltage
The discussion centers on issues encountered with a Hall sensor, specifically the sensor's non-linear response to varying magnetic fields and an incorrect quiescent voltage reading. The user reports that the sensor, which should have a quiescent voltage of 2.5V, is instead showing 0.7V. It is suggested that the sensor may be saturating due to the use of a strong rare Earth magnet, which can exceed the linear range of the sensor. Recommendations include testing with an Alnico magnet and ensuring proper biasing of the device.
  • Understanding of Hall effect sensors and their operation
  • Familiarity with magnetic field strength measurements (Gauss)
  • Knowledge of sensor biasing techniques
  • Experience with different types of magnets (e.g., rare Earth vs. Alnico)
  • Research the linear range specifications of Hall sensors
  • Learn about sensor biasing methods for Hall effect devices
  • Investigate the properties and applications of Alnico magnets
  • Explore the effects of magnetic field saturation on sensor performance
Electronics engineers, hobbyists working with sensors, and anyone troubleshooting Hall effect sensor performance issues.
proing
Hi!
I am using this hall sensor http://docs-europe.electrocomponents.com/webdocs/0d88/0900766b80d88153.pdf
i got 2 problems:
1. When i vary the magnetic field, the hall sensor is acting like digital, i mean, it showing either high value or low value... Its not varying linearly as the distance between the magnet and sensor varies.
2. The quiscent voltage of this sensor is 2.5V (that is, the hall voltage must be 2.5V without the magnetic field), but it showing 0.7V.
I am playing with this voltage only, when i bring the north pole of the magnet near to the sensor, the reading is 0.1V and moves away it showing 0.7V (like digital)
Please help me out..
Thanq
1. You may be saturating the sensor. The range of B fields over which it is linear is small (or smaller than the magnet you are using). A rare Earth magnet can be as high as 10,000 gauss. The transfer ratio is 2.5 mV- 5 mV /G. Try using an Alnico or similar non-rare Earth magnet to test it. However...
2. This may be part of the problem - solve it first because you may not be biasing the device properly in the first place.
  • · Replies 20 ·
  • · Replies 0 ·
10K
