Quantum mechanics in multiple dimensions
The discussion revolves around the treatment of separation constants in the context of solving the Schrödinger equation for a two-dimensional box. Participants explore the implications of choosing different signs for separation constants and how these choices affect the resulting wave functions. The conversation includes theoretical considerations and mathematical reasoning related to quantum mechanics in multiple dimensions.
  • Some participants question how to determine the sign of the separation constant when solving the Schrödinger equation for a 2D box, suggesting that it seems arbitrary and affects the solutions.
  • Others argue that the choice of separation constant must avoid unwanted behaviors, such as infinities, and should adhere to boundary conditions.
  • One participant emphasizes that the separation constant should not be assigned a sign arbitrarily, as its value will emerge from the mathematical process.
  • Another participant discusses the separation of variables and the need for the terms associated with each dimension to equal zero independently, leading to equations that define energies associated with each coordinate.
  • Some participants propose methods for distributing the energy term E between the separated equations, noting that either approach leads to equivalent results.
  • There is a concern raised about determining whether the constants are positive or negative, as this significantly influences the final wave functions.
  • One participant clarifies that boundary conditions dictate the sign of the constants, particularly emphasizing that negative constants would lead to non-physical solutions that do not satisfy the boundary conditions.
Participants express differing views on the determination of separation constants, with some asserting that the choice is non-arbitrary and others questioning how to make that determination. The discussion remains unresolved regarding the implications of these choices on the solutions.
Participants highlight the importance of boundary conditions in determining the nature of the solutions, but there is no consensus on how to approach the assignment of signs to separation constants or the implications of these choices on the physicality of the solutions.
aaaa202
Suppose we have a 2d problem (for instance a 2d box). You look for separable solutions in x and y. But it seems to me that the solutions are in a way determined by how we choose the separation constant. Do we know anything a priori that tells us if the separation constant should be negative or positive?
Consider for instance the 2d box. The separation constant for the x and y solution should have opposite sign, yet the physical situation is exactly the same. What is wrong here?
the wrong choice of a separation constant will lead you in unwanted behavior of your solutions...
So generally you want to avoid infitities and of course you want to apply some boundary conditions...
But I just don't see how you can determine it. Consider for instance the 2D box. You would be crazy not to think that the wave functions in x and y are the same. The SE is:
HY(y)X(x) = EY(y)X(x)
but now comes a choice:
In which of the separated equation does E go? And in which of the separated equation do we put a minus sign and a plus sign? The minus sign will of course be fatal since you then get a solution with an exponential rather than and exp(ix)
The separation constant goes with both.
The way it works is f(x)=g(y) => f(x) = c = g(y). Both functions equal the separation constant.
Second, you don't assign a sign to the separation constant - it's just a constant and the value of it will come out in the math.
So suppose you have the 2d box.
Inside it you will have an SE of the form:
-hbar^2/2m(∂x2 +∂y2 )XY = EXY
So we could separate variables and get the equation:
-hbar^2/2m(∂x2Y = (K+E)X
-hbar^2/2m(∂y2Y = -KY
How am I to determine what the values of these constants K should be? Of course from the symmetry you want the solutions in each dimension to be the same, but with this choice of letting E go into either x and y it doesn't seem like you get that.
There seems to be something odd about your separation of variables.
The way it works is:
-hbar^2/2m(∂x2 +∂y2 )XY = EXY=(Ex+Ey)XY
then :
((1/X)(∂x2X+ 2mEx/hbar^2) +((1/Y)(∂y2Y+ 2mEy/hbar^2) =0
In order for this to be 0 for all x ,y both terms must equal 0 independently.
x2X =-2mEx/hbar^2 X
y2Y =-2mEy/hbar^2 Y
Ex and Ey a are your energies associated to each coordinate and are determined by your boundary conditions. There is no arbitrary choice.
Okay so you start with the two separate equations and add them. Hmm I guess that makes physical sense, but I have just seen the other version used for e.g. the hydrogen atom.
To recap on this form what I do is say:
-hbar^2/2m(∂x2 +∂x2 )XY = EXY
Divide by XY and you get:
-hbar^2/2m(1/X∂x2X +1/Y∂x2 )Y = E
And since the sum of the X and Y term is a constant, they must each be equal to a constant. You can either let the E go into the X or Y equation. Doing so for X you end up with the equations from my previous post.
I have seen this used for the hydrogen atom where you let the E-term go into the radial equation. On the other hand, it is later showed how this separation was actually physically equivalent to constructing simultaneous eigenstates of L2, Lz, H, so maybe this explains it?
I hope I have made my problem clear - I don't see how you just from the math can determine anything about the separation constants.
You can do it either way. It doesn't make any difference in the final result. Using your 2-dimensional box example start with:
$$-\frac{\hbar^2}{2m} \frac{1}{X} \frac{\partial^2 X}{\partial x^2}
-\frac{\hbar^2}{2m} \frac{1}{Y} \frac{\partial^2 Y}{\partial y^2} = E$$
Method 1: Put E with the y-term and define a second separation constant
$$-\frac{\hbar^2}{2m} \frac{1}{X} \frac{\partial^2 X}{\partial x^2} =
\frac{\hbar^2}{2m} \frac{1}{Y} \frac{\partial^2 Y}{\partial y^2} + E = F$$
This leads to the two separated equations
$$-\frac{\hbar^2}{2m} \frac{\partial^2 X}{\partial x^2} = FX\\
-\frac{\hbar^2}{2m} \frac{\partial^2 Y}{\partial y^2} = (E - F)Y$$
Define ##E_x = F## and ##E_y = E - F##. This leads to ##E = E_x + E_y## and
$$-\frac{\hbar^2}{2m} \frac{\partial^2 X}{\partial x^2} = E_x X\\
-\frac{\hbar^2}{2m} \frac{\partial^2 Y}{\partial y^2} = E_y Y$$
Method 2: Put E with the x-tern and define a third separation constant
$$-\frac{\hbar^2}{2m} \frac{1}{Y} \frac{\partial^2 Y}{\partial y^2} =
\frac{\hbar^2}{2m} \frac{1}{X} \frac{\partial^2 X}{\partial x^2} + E = G$$
$$-\frac{\hbar^2}{2m} \frac{\partial^2 Y}{\partial y^2} = GY\\
-\frac{\hbar^2}{2m} \frac{\partial^2 X}{\partial x^2} = (E - G)X$$
Define ##E_y = G## and ##E_x = E - G##. This leads to ##E = E_x + E_y## and
$$-\frac{\hbar^2}{2m} \frac{\partial^2 Y}{\partial y^2} = E_y Y\\
-\frac{\hbar^2}{2m} \frac{\partial^2 X}{\partial x^2} = E_x X$$
which are the same equations as in method 1.
okay of course. There's just one tiny thing that bothers me still - namely how do you determine if the constants are positive or negative? After all that has a lot to say for the final wave functions?
From the boundary condition that on the boundary of the square, the function is 0. If ##F## was negative, the equation for x would not longer have oscillatory solutions (equation of an harmonic oscillator) but would have exponentially rising solutions, which are non-zero everywhere and cannot satisfy ##X = 0## on the boundary.
  • · Replies 21 ·
