Angular Momentum of a sliding disc about a point on the floor
The discussion focuses on calculating the angular momentum of a sliding disc about a point on the floor, specifically addressing the formula L = r × p = ∑(r_i × p_i) = ∑(r_i × m_i v_i) = MRv. The confusion arises regarding the last equality, where the participant questions how the sum simplifies to MRv. The clarification provided indicates that R represents the perpendicular distance from the point to the line of motion of the center of mass, not the radius of the disc itself. This distinction resolves the misunderstanding about the relationship between the radius and angular momentum.
  • Understanding of angular momentum and its mathematical representation
  • Familiarity with vector cross products
  • Knowledge of mass distribution in rigid bodies
  • Basic principles of rotational dynamics
  • Study the concept of angular momentum in non-rolling bodies
  • Learn about the center of mass and its significance in dynamics
  • Explore vector calculus, particularly cross products and their applications
  • Investigate the relationship between translational and rotational motion
Students and educators in physics, particularly those focusing on mechanics, as well as anyone interested in understanding the dynamics of rigid bodies in motion.
naes213
Hi everybody,
A seemingly straightforward example from lecture is causing me some confusion. The example was about calculating the angular momentum of a sliding disk (not rolling) about a point on the floor. The result given in lecture says the distance to the point on the floor is unrelated to the angular momentum:
[tex]\vec{L}=\vec{r} \times \vec{p}=\sum{\vec{r}_i \times \vec{p}_i}=\sum{\vec{r}_i \times m_i\vec{v}_i}=MRv[/tex]
where M is the total mass of the disc, R is the radius of the disc, and v is the translational velocity of the sliding disc. Now my confusion comes in at the last equal sign. I think it should read:
[tex]\sum{\vec{r}_i \times m_i \vec{v}_i}=\sum{m_i r_i v_i \sin{\theta_i}}[/tex]
where [itex]\theta_i[/itex] is the angle between each particles radius vector and the constant velocity vector. I don't see how this sum ends up as [itex]MRv[/itex] as was claimed in lecture.
I tried to write [itex]\theta_i[/itex] as a function of each ri and integrate over the disc, but didn't make progress. I know I can take the mi and vi out of the sum because they are the same for each i, but I still can't deal with the
[tex]\sum{r_i\sin{\theta_i}}[/tex]
Any help would be greatly appreciated! Maybe I'm just missing something really obvious, I don't know.
Thanks,
Sean
Hi Sean! :smile:
No, R is the perpendicular distance from the point to the line of motion of the centre of mass.
ri x mi vi
= (∑ miri) x v since vi = a constant, v
and then use ∑ mi(ri - ro) = 0 by definition, where ro is the centre of mass :wink:
Ok, I see. That makes sense. In my situation it just so happens that the perpendicular distance is equal to the radius of the disc. In a more general scenario this would be different. Thank you!
  • · Replies 30 ·
  • · Replies 17 ·
  • · Replies 30 ·
