What Happens to Work Done by Gravity in First Law of Thermodynamics?
The discussion centers on the application of the first law of thermodynamics (delQ = dE + delW) to a freely falling body, concluding that when delQ equals zero, the work done by gravity (delW) also equals zero. It emphasizes that potential energy (PE) and kinetic energy (KE) changes account for the work done by gravity, thus avoiding double counting. The conversation highlights the importance of understanding the system and surroundings in thermodynamic problems, reinforcing that the internal energy of a rigid solid mass remains unchanged during free fall.
  • Understanding of the first law of thermodynamics (delQ = dE + delW)
  • Knowledge of potential energy (PE) and kinetic energy (KE) concepts
  • Familiarity with gravitational forces and their effects on motion
  • Basic principles of thermodynamics and system-surroundings interactions
  • Explore the implications of the first law of thermodynamics in various physical systems
  • Investigate the relationship between work and energy in gravitational fields
  • Study examples of energy conservation in free-fall scenarios
  • Learn about the role of viscous losses in thermodynamic systems
Students of physics, thermodynamics researchers, and engineers interested in energy systems and gravitational effects on motion.
vasudevan349
I began applying first law of thermodynamics (delQ=dE+delW) to a freely falling body.
We see that for this case delQ=0, so dE=-delW.
As dE consists of both potential and kinetic energies we see that neglecting any viscous losses, dE=0. (At max. height, KE=0,PE=mgh and at bottom most point PE=0,KE=.5*m*v^2=mgh).
This concludes that delW=0.
But what happens to the work done by gravity?
Is there any restriction placed on delW to be used in first law?
If you say that work done by the gravity is compensated by change in potential energy, how to convey this using first law of thermodynamics?
When you use a gravitational PE term, you are already accounting for gravity and any work it does. To also include a dW term for gravity would be to count it twice.
So choose one or the other, but not both.
It is an interesting question. It helps clarify many interesting aspects of thermodynamics.
First law of thermodynamics concerns with internal energy changes of the system as a result of interactions with the surroundings.
In the question under consideration, the system (assuming it to be a rigid solid mass that suffers no change of shape as it falls) suffers no internal energy change. Consequently the algebraic sum of heat interaction and work interaction with the surroundings must be zero. Since heat interaction is zero work interaction is necessarily zero.
Having said that, I may ask you to ponder over what your system is, what the surroundings is and how to account for work interaction between system and surroundings in any problem you tackle in thermodynamics. That helps, I hope, clarify the concepts in thermodynamics to a large extent.
  • · Replies 46 ·
  • · Replies 77 ·
  • · Replies 37 ·
