Transposing formulas/Solving for variables
  • Context: High School
  • Thread starter Thread starter Anon481516
    Variables
The discussion revolves around the challenges of transposing formulas and isolating variables in equations, particularly in the context of algebra and its applications in physics. Participants explore various methods and rules for manipulating equations, addressing specific examples and seeking clarification on the underlying principles.
  • Homework-related
  • One participant expresses difficulty in understanding how to transpose variables in equations, specifically questioning the operations that lead to reversing the orientation of terms.
  • Another participant explains that operations applied to one side of an equation must also be applied to the other side, illustrating this with examples involving multiplication and division.
  • Concerns are raised about isolating variables when multiple terms are present in the denominator, with some participants affirming that one can manipulate individual factors without affecting others.
  • Participants share examples of equations, such as E = I*R and P = I^2*R, and express confusion about isolating variables when square roots are involved.
  • There is a request for detailed explanations and examples to clarify the rules of algebra and transposition, as some participants feel uncertain about their understanding.
  • One participant attempts to isolate variables in the gravitational force equation, seeking confirmation on their methodology and the correctness of their steps.
  • Discussion includes a breakdown of specific transposition steps, with participants questioning and clarifying each other's methods, particularly regarding the treatment of square roots and fractions.
  • Some participants summarize the fundamental rules of transposing equations, emphasizing the importance of maintaining equality by applying the same operations to both sides.
Participants generally agree on the fundamental rules of transposing equations, but there remains uncertainty and confusion regarding specific applications and examples. No consensus is reached on the best methods for handling complex transpositions.
Participants express varying levels of familiarity with algebra, indicating that some foundational concepts may be missing or unclear. The discussion highlights the need for clarity in notation and the importance of properly expressing mathematical operations.
This discussion may be useful for students struggling with algebraic manipulation, particularly in the context of physics and engineering equations, as well as those seeking to reinforce their understanding of mathematical rules and transposition techniques.
Anon481516
Hello,
I have a question about solving or isolating for variables in an equation. It doesn't need to be an equation, however, I've noticed my problems always appear when trying to transpose them. I have read through algebra concepts, but they only tell me what I already know regarding polynomial rules and such. I think my problem is much more basic:
Keq = [CO2][CF4] / [COF2]2
CO2 = [COF2]2 / [CF4]
What exactly happens that causes the top and bottom parts to reverse their orientation? What caused the CO2 to appear on the left side, what operation/method is used?
Are there any posts similar to this that have a detailed explanation? Reading a book about Algebra didnt help the second time around, so I would just like to know how the rules are applied. What if there are two sets of variables in the denominator, can one of them be moved without altering the other? When a square root contains a variable of interest and is being multiplied by another variable in the denominator, what can be done to isolate it? It's these kind of things I've had problems with for a while. Could someone explain?
Mathematics news on Phys.org
Hello Anon481516! :smile:
What exactly happens that causes the top and bottom parts to reverse their orientation? ?
Whatever you do to one side of the =, you must do to the other side.
So when you multiplied that fraction by [COF2]2,
the [COF2]2 on the bottom of the fraction disappears, but you must multiply the other side of the = by [COF2]2 also …
since it's multiplication, it appears on the top.​
By contrast, you are dividing both side by [CF4] …
so the [CF4] is divided out (and disappears) from the top of the fraction, and the other side of the = must also be divdied by it, so it ends up on the bottom.
The writer just swapped sides for no particular reason.
He started with 1 = BC/D, he multiplied both sides by D/C to get D/C = B,
and then for no particular reason swapped side to get B = D/C. :wink:
Yes, you just multiply both sides of the equation by one factor, so it disappears from the bottom and reappears on the top on the other side of the =
Not following you. :confused:
Not following you.
Don't worry about that, I was just using it as an example to elaborate on my problem.
It does make sense the way you did it. However, the way I was trying to do it, was trying to isolate the CO2 right at the beginning, trying to move it to the other side. I had similar problems when trying to simplify differential calculus questions. My algebra was always the problem.
Do you know of any examples with solutions, perhaps detailed explanations? What you said helped, but I'm still not sure why you did it that way. Perhaps its because you have to and those are the rules of math and I can understand that, I just don't understand the rules.
I feel fine with things like:
E = I*R and P = I2*R
But other ones I just forget how to do:
E = [itex]\sqrt{}P*R[/itex] and I = [itex]\sqrt{}P/R[/itex] <---- Its supposed to be a square root symbol.
Could you or someone else explain those rules? I know this seems a bit excessive, there is probably many of them, however I'd like to rid myself of this problem after so many years. Is there a small book, an article/post somewhere that describes or explains this?
Did you ever study algebra? That's where most of the rules come from. The rest come from arithmetic.
P = I2*R​
divide both sides by R …
P/R = I2
take the square root of both sides
√(P/R) = I​
finally substitute that formula for I in the original E = I*R …
E = I*R = (√(P/R))*R = (√P)*R/√R = (√P)(√R) = √(P*R) :smile:
I didnt follow that third part:
(√P)*R/√R
You went from
(√(P/R))*R = (√P)*R/√R <--- How did you get here?
I tried isolating for r^2 in the force of gravity equation:
F = G*m1*m2/r^2
r^2 = G*m1*m2
r = √G*m1*m2
As well as for m1:
r^2 = G*m1*m2
r^2/G*m2 = m1
Are those correct? Could you or someone else explain the methodology/rules you use? Answering and transposing the questions is great, but I could really use an explanation so that the harder transpositions are more clear.
(√P)*R/√R
You went from
√(P/R) = (√P)/(√R)
so ##\sqrt{\frac{P}{R}}*R = \frac{\sqrt{P}}{\sqrt{R}}*R = \frac{\sqrt{P}*R}{\sqrt{R}}##
F = G*m1*m2/r^2
r^2 = G*m1*m2
r = √G*m1*m2
As well as for m1:
r^2 = G*m1*m2
r^2/G*m2 = m1
i can't tell what you mean if you don't use brackets (after the √) to show how much of what follows is included in the √
can you write it out again, with brackets?
(and what happened to the "F" in the first line? :confused:)
I got it now, thanks.
As for my transposition, that's a good question, what did happen to the F...
In the first transposition, everything was square-rooted, the G*m1*m2 and then that entire term is divided by the F. So:
r = √(G*m1*m2) / F
The second one:
F = G*m1*m2 / r^2
F*r^2 = G*m1*m2 <--- I brought the r^2 from the bottom to the left.
F*r^2 / G*m2 = m1 <--- I brought both G and m2 simultaneously to the left.
Apologies, I somehow omitted the F all-together.
Are those correct? And could you explain what rules are needed to properly transpose questions that are of the same difficulty or of higher difficulty? I don't know of any hard formulas that I could use as an example to transpose. Could you try one that you know of and explain which rules you use to find a variable of interest?
Anon481516 said:
The second one:
F = G*m1*m2 / r^2
yes, that's fine :smile:
there's only two rules …
for an equation:
whatever you do to one side, you must do to the other side
eg multipy both by the same
add both to the same
take the reciprocal of both
take the square-root of both
take the log of both​
for a fraction:
whatever you do to the top you must do to the bottom
(multiplying and dividing only!)​
Thats it? I thought there would have been more to it. Nevertheless, I'll still try and find some harder formulas to transpose for extra practice.
Thanks for the help.
  • · Replies 21 ·
  • · Replies 21 ·
