How is the Earth's magnetic field generated and maintained?
  • Context: Graduate
  • Thread starter Thread starter channel1
    Magnetism
The Earth's magnetic field is generated by the dynamo effect, which involves electrical currents produced by the convective movements and rotation of the liquid metallic outer core composed of iron and nickel. This process occurs at depths of approximately 3000 to 5000 kilometers within the molten core. While the exact mechanisms of the dynamo effect are not fully understood, it is established that the rotation of the Earth contributes significantly to the generation of these currents, thereby maintaining the magnetic field.
  • Understanding of dynamo theory
  • Knowledge of magnetohydrodynamics
  • Familiarity with the composition of the Earth's core
  • Basic principles of electromagnetism
  • Research the principles of magnetohydrodynamics in detail
  • Explore advanced dynamo theory and its applications
  • Study the composition and behavior of the Earth's outer core
  • Investigate the magnetic fields of other celestial bodies
Geophysicists, astrophysicists, students of Earth sciences, and anyone interested in the mechanisms behind planetary magnetic fields.
channel1
Do any celestial bodies not have magnetic fields? Why?
I'm having a difficult time finding good resources for dynamo theory a question about that...
So first what I know:
1 - The Sun has a nonmetal hydrogen/helium plasma interior which is generating a magnetic field
2 - the Earth has a liquid iron core with a magnetic field
3 - metals can be magnetized because their electron spin orientations result in the atom having an electric current inducing a magnetic field, and nonmetals are labeled as not having magnetic properties
Q - If both metals and nonmetals (e.g. hydrogen plasma) can be magnetized then why are nonmetals categorized as not being able to be magnetized (according to the periodic table). Clearly I'm missing something in there because that's not consistent.
Many celestial bodies have magnetic fields. It is not always easy to determine if they do, but when there is evidence there is a magnetic field we may rely on our imperfect models of our Earth's magnetic field for tenative explanations.
As for your Q., sorry, I've no idea of how to answer that.
“The origin of the Earth's magnetic field is not completely understood, but is thought to be associated with electrical currents produced by the coupling of convective effects and rotation in the spinning liquid metallic outer core of iron and nickel. This mechanism is termed the dynamo effect.”
http://csep10.phys.utk.edu/astr161/lect/earth/magnetic.html
“Although the details of the dynamo effect are not known in detail, the rotation of the Earth plays a part in generating the currents which are presumed to be the source of the magnetic field.”
http://hyperphysics.phy-astr.gsu.edu/hbase/magnetic/magearth.html
Simulation of the earth’s mantle with a supercomputer:
“The geomagnetic field is generated deep inside the Earth. Within the molten, electrically conducting iron core of the Earth, i.e. at a depth of approximately 3000 to 5000 kilometers, a magnetohydrodynamic dynamo maintains the field.“
http://www.gauss-centre.eu/earth/magnetic_field
  • · Replies 23 ·
