How do you find the distance to the galaxies having equal diameter?
  • Context: Undergrad
  • Thread starter Thread starter iVenky
    Diameter Galaxies
The discussion revolves around the methods used to determine the distance to galaxies that are assumed to have the same diameter as the Milky Way. Participants explore the application of triangulation and the implications of assuming equal sizes for distant galaxies, referencing Richard Feynman's work.
  • One participant describes the triangulation method for measuring distances to galaxies, using the angular size and assumed diameter of the Milky Way as a basis for calculation.
  • Another participant questions the validity of assuming all galaxies have the same size, suggesting that this could lead to significant inaccuracies in distance measurements.
  • Some participants argue that the assumption of equal sizes is not scientifically rigorous, highlighting the variability in galaxy sizes.
  • Conversely, a later reply defends the initial assumption, stating that while galaxies are not all the same size, the method can yield useful approximations for distance calculations.
  • Participants discuss the potential for using other methods, such as standard candles, to refine distance measurements and assess galaxy sizes more accurately.
Participants express disagreement regarding the assumption that all galaxies are of equal size, with some arguing it is a flawed premise while others suggest it can still provide a useful approximation for distance calculations. The discussion remains unresolved on this point.
There are limitations regarding the assumptions made about galaxy sizes, and the discussion highlights the dependence on these assumptions for the accuracy of distance measurements. The mathematical steps involved in triangulation are not fully resolved.
iVenky
I am reading Richard Feynman's book Vol I. There he tells us how people usually used to find out the distance to some distant objects. I understand triangulation for objects that are near to the Earth or for stars that are near to our solar system. But how did they use the same principle to find out the distance to those galaxies(which have the same diameter of our galaxy) that are far away from the Earth ?
Here's the excerpt-
"Knowing the size of our own galaxy, we have a key to the measurement of still larger distances- the distances to others galaxies. Figure 5-7 is a photograph of a galaxy, which has much the same shape as our own. Probably it is the same size, too. (Other evidence supports the idea that galaxies are all about the same size.) If it is the same size as ours, we can tell its distance. We measure the angle it subtends in the sky; we know its diameter and we compute its distance -triangulation again"
Can someone help me?
Astronomy news on Phys.org
Take a pen and a piece of paper. Draw an elongated equilateral triangle with vertex A being the observer, and vertices B and C marking the edges of the observed galaxy.
Simple measurements allow us to name the angle at vertex A - it is the angular size of an object on the celestial sphere. For example, for the Andromeda galaxy it's over 3 degrees.
By assuming that the observed galaxy is of the same size, we are given the length of the distance BC - the same as the size of Milky Way, so ~100 000 ly.
This gives us enough information to calculate the distance using simple trigonometric relations. In the case of our Andromeda example, this nets a result of ~2 million ly, which is not a bad approximation for the ~2,5 million ly of actual distance.
Wait a second here. Assuming the size of a galaxy is a big assumption.
This method could give extremely inaccurate results. All galaxies the same size? I think not my friend.
Size of galaxies will most probably vary as much as the sizes of the stars. Some can be many magnitudes larger then our own. So in all probability galaxies will follow suit. If this is so then judging distant in this methods would be grossly inaccurate. No?
We don't assume a galaxy is a certain size without good reason.
A lot of hand waving, especially for someone like Feynman.
"Probably it is the same size, too. (Other evidence supports the idea that galaxies are all about the same size.)"
This is what I was talking about "PROBABLY" it is the same size." that doesn't sound very scientific to me.
All about the same size... I don't think so.
You're missing the point.
Of course galaxies are not all exactly of the same size. The exercise with calculating distances with the equal size assumption shows that it is possible to get ballpark results by using simple assumptions. It doesn't matter if a galaxy is in actuality half the size or five times the size of ours, you'll get the distance that is accurate to within one order of magnitude, where otherwise you'd have nothing.
You can then try to check or narrow the result by trying to measure the actual size. You can do it e.g., by using standard candles to find out the distance, at which point calculating the size is trivial.
You'll find out then, that the initial assumption of equal sizes was a very good one, especially when comparing galaxies of similar visible macrostructure, that is, spiral galaxies with spiral galaxies etc. - just as it was explained in the quote from Feynman in the OP.
  • · Replies 97 ·
14K
  • · Replies 23 ·
  • · Replies 0 ·
  • · Replies 16 ·
  • · Replies 17 ·
