Do pH levels carry on thorugh evaporation?
The discussion revolves around the effects of evaporation from a mass of basic water in a closed system on the pH levels of the air and subsequently the soil when the air condenses. Participants explore the relationship between pH, evaporation, and the presence of carbon dioxide (CO2) in the air.
  • Some participants question whether the pH of the air is affected by the evaporation of basic water, suggesting that there are no free ions in vapor.
  • Others argue that the chemical composition of the air in a closed system primarily consists of N2, O2, and water vapor, with minimal CO2, which could influence pH indirectly.
  • A participant expresses uncertainty about defining pH for gases and questions how hydrogen ions would be quantified in air.
  • Some participants clarify that pH is a property of aqueous solutions and that gases would need to dissolve in a solvent to affect pH meaningfully.
  • There is a suggestion that CO2 concentration in the air could affect the pH of water when it condenses, as CO2 can form carbonic acid in solution.
  • One participant proposes that the solubility of CO2 may vary depending on the pH of the water, indicating a potential indirect relationship between basic water and CO2 levels.
Participants do not reach a consensus on whether the pH of the air is affected by evaporation from basic water. Multiple competing views remain regarding the definitions and implications of pH in gases and the role of CO2.
Limitations include the dependence on the definitions of pH, the assumptions about the chemical composition of the air, and the unresolved nature of how CO2 concentration might change in relation to the pH of the water.
The Divine Zephyr
I need to know:
In a closed system sealed off from outside air, if water from a mass of basic water evaporates, will the pH of the air be affected? If so, when the air condenses, how wil the pH of soil in the closed system be affected?
Thanks for the help.
Chemistry news on Phys.org
"Is the pH of the air affected ?" No, it is not. You do not have free ions in the vapor - at least, not that I'm aware of.
To answer any more will require that the question be restated more clearly providing more information about the system of interest, as well as what your specific concern is.
That's an interesting part with the "pH of the air"...U'll have to specify what the chemical composition of that air is:normally,for open air,the pH is very,very close to 7,coming from the acid part..,due to various acid anhydrides (from industrial area) and water molecules...But the way you set the problem,i highly doubt that the air in a closed system in which water eveporates contains anything but N_{2},O_{2} & water vapors...Sure,it's CO_{2} as well (that tiny "regulamentar" bit of 0.03%) which would make the pH not exactly 7,but 6.very many nines.
Daniel.
Dexter, I can't see how having carbon dioxide in the air reduces its pH (in fact, I can't see how you could sensibly define pH for a gas, in a manner that is useful). Where are the hydrogen ions coming from ? And how do you define their concentration ? (per liter of air ?) Now if you have CO2 dissolving in rain water, then this rain water will be acidic because the dissolved CO2 aids in ionization.
I have never heard of pH in gases, and this may just be a due to my rather unstructured education. If you know of some link, I'd like to look at it.
Yes,you're right...Misthinking with the parallel with acid rains...Which as you said,imply gases dissolving in water and creating very weak acid sollutions...
Yes,by definition pH is for solutions,which means that gases would have to fit in only by dissolving into a solvent.
Sorry.My affirmations were not as accurate as they were intended...
Daniel.
The Divine Zephyr said:
I need to know:
It would depend on what the CO2 concentration of the air is, and how it is affected by the basic water.
CO2 in air will dissolve over time into water and created [H2CO3], which is an acid. I've seen this affect where dH2O water that starts with pH7.0 will over time acidify due to dissolving CO2.
So, the water won't change the pH of air: there are no free hydronium (H3O+) in air. But indirectly it might change the CO2 concentration.. but I'm not sure whether more CO2 would dissolve in basic water than in acidic water.
pH usually pertains to the acidity (or basicity rather) in aqueous solutions, that is the ability of a specific compound in water to affect the following net equation:
H+ + 0H- --->H20, pH is derived from the K of this equation.
Thus when referring to pH, it is specifically for aqueous solutions. I believe that considerable amount of water is required if one wishes to consider the pH in aq solutions; that is if we wish to apply Ka...in which water is neglected.
For instance, one could propose that high concentrated sulfuric acid, will have a higher pH. However, it does not...can you guess why? After you answer this questions, apply it to your situation in the context of water vapor.
Yeah, in addition to Moniques explanation, C02 is an acidic oxide, frequently acidic are oxides of a non-metallic element and as you can guess basic oxides-metals-and amphoteric oxides exist also. With the proposal that C02 increases pH of an aqueous solution, on can guess that it would dissolve better in basic solutions, one way to expalin this is by common ion effect (if you can trace process out in the long run, you'll see that having a basic solution can indirectly affect the solubility of C02). This is all in theory, my opinion, an expert might disagree stating a factor which I have not heard of.
  • · Replies 23 ·
52K
