Unveiling the Mysteries of Gravity Waves: Origins and Properties Explained"
The discussion centers on the nature and properties of gravity waves, exploring their origins, mechanisms, and implications within the framework of general relativity (GR). Participants engage in technical explanations, conceptual clarifications, and speculative reasoning about gravity waves and their relationship to gravitational forces.
  • Some participants propose that gravity waves are oscillations in the space-time medium, distinct from the normal carrier of gravitational force.
  • There is a suggestion that gravity waves are analogous to electromagnetic waves, with accelerated masses producing gravitational radiation similar to how accelerated charges produce electromagnetic radiation.
  • A participant describes a thought experiment involving heavy balls connected by a spring to illustrate how gravity waves may carry energy away due to the time delay in gravitational attraction.
  • Another participant notes that gravitational waves are a fundamental prediction of GR, emphasizing Einstein's initial reluctance to accept this prediction.
  • Some participants discuss the concept of energy loss in the context of gravitational waves, with one suggesting that a small amount of kinetic energy is "leaked" during the creation of a gravity wave.
  • There is a mention of the relationship between gravitational mass and baryonic mass, with energy dispersal in gravitational radiation being highlighted in specific astrophysical scenarios, such as inspiralling neutron stars or black holes.
  • One participant questions the strict requirement of energy conservation in GR, while another acknowledges that energy loss in decaying orbits can be explained by gravitational waves.
  • Concerns are raised about the implications of energy conservation in general relativity, particularly regarding the notion that gravitational waves may not possess energy in a classical sense.
The discussion features multiple competing views regarding the nature of gravity waves, their relationship to gravitational forces, and the implications for energy conservation in general relativity. No consensus is reached on these points.
Participants express uncertainty about the energy conservation principles in GR and the implications of gravitational waves, indicating that the discussion is limited by varying interpretations of these concepts.
billy_boy_999
what are gravity waves? i am guessing that they are some kind of oscillations in the space-time "medium"?
but gravity waves are not the normal carrier of the gravitational force? otherwise, because its an oscillation, the force wouldn't fall off with the square of the distance. so what special circumstances create gravity waves? where do they come from?
Astronomy news on Phys.org
A simple explanation is that gravity waves are to gravity as electromagnetic waves are to the electrostatic columb force between charges. They are related, but separate. Accelerating charges can produce electromagnetic radiation, and accelerated masses can produce gravitational radiation.
You might also want to read the sci.physics.faq on gravitational radiation
here
Taylor and Wheeler give a really simple explanation of gravity waves and why they are predicted.
Imagine heavy balls falling towards each other (by their own gravitational attraction) connected by an ideal massless spring. In theory, the spring should then be able to push the balls apart to their starting position again after they collide. But, the spring discovers that it requires more energy to return them to their starting position.
The idea is if you take a time slice while the balls are moving towards each other and then away from each other you notice something ... they feel the attraction of where the other ball was an instant in the past, not where it currently is, due to the delay for the information of its position to reach the other ball. So as they fall towards each other, they experience a tiny bit less attraction than they "should" because they feel each other as being slightly farther away, and then as they move apart, they feel slightly more attraction then they should for the same reason.
This means that energy has magically disappeared from the system because of this time delay in communication between them (assuming that gravity information travels at less than or equal to C).
The idea is that gravity waves carry this energy away as ripples in the fabric of spacetime.
If you think about it an em wave if you like is where a vector field defined over space is 'changing', simalirly a gravitational wave is where a tensor field defined over space is 'changing'.
Good explanation, Gonzo, in fact it is quite excellent. Gravity waves are a fundamental prediction of GR. Einstein realized this, but was reluctant to accept it. He finally took the very bold step of predicting gravity waves because it was the only apparent solution that satisfied the energy conservancy required under GR. Detecting them would be yet another monumental testimony to the sheer brilliance and depth of GR. Go LISA!
Ya, just to comment on gonzo's explanation, so a slight amount gravitational energy (attraction) is lost in the creation of a gravity wave?
So, let's say a star forms, its gravitational attraction will be slightly smaller then...what amount of energy? I hope I've been clear...
No effect on gravitational attraction. A small amount of the kinetic energy of the accelerating/decelerating object is leaked out via gravity waves.
Actually, a little bit of energy has been dispersed in the radiation. This is sometimes expressed that the object's "gravitational mass" is less than its "baryonic mass". This can also be called a "loss" (actually a dispersal) of "binding energy". In the formation of most condensed objects i.e. stars, most of this binding energy escapes as electromagnetic radiation rather than gravitational radiation, except in cases such as inspiralling neutron stars or black holes. In these cases a significant amount of energy is released in the form of gravitational waves.
Hope that helps.
best.
Jim Graber
Are you sure, in GR conservation of energy is not strictly required.
I'm not sure of anything. It leads to poorly conceived wagers. But in cases such as decaying orbits, there is an energy loss [albeit small] that is inexplicable without gravitational waves.
I see now graviational waves conserve energy in the classical limit (gravaitaional waves don't actually have energy in some sense though, that is if you look at a small enoguh region of any part of a graviational wave and meausr eit's energy it will be zero), so I guess in order for conservation you need to pick a preferred frame and you'd also need asymnpotical flatness.
It still seems odd to me that Einstein would worry about energy conservation edited to add: when, for regions of space the law of energy conservation is ruled out as being generally covariant a priori and general covaraincy was one of Einstein's main motivations to formulate the theory of genarl relatiivty.
  • · Replies 30 ·
  • · Replies 140 ·
