Moment of inertia/radius of gyration
  • Thread starter Thread starter Nylex
    Moment
The discussion centers on the calculation of the radius of gyration (k) for a thin rectangular sheet with dimensions 2a and 2b about an axis through its center of mass. The correct formula for the radius of gyration is established as k = a/√3. The initial integration approach was flawed due to incorrect axis selection, leading to confusion in the calculation of the moment of inertia (I_y). The corrected integration method demonstrates that I_y = (4ρb/3)a^3, which aligns with the derived formula for k.
  • Understanding of moment of inertia concepts
  • Familiarity with integration techniques in physics
  • Knowledge of mass density (ρ) and area (A) calculations
  • Ability to apply the parallel axis theorem
  • Review the derivation of moment of inertia for various shapes
  • Study the application of the parallel axis theorem in rigid body dynamics
  • Learn about the significance of radius of gyration in structural engineering
  • Explore advanced integration techniques for calculating physical properties
Students and professionals in physics, engineering, and applied mathematics who are involved in mechanics and structural analysis will benefit from this discussion.
Nylex
Can someone please tell me where I've gone wrong with this question?
"A thin rectangular sheet of sides 2a and 2b about an axis through its centre of mass and parallel to the side 2b. Show that the radius of gyration, k, of the sheet is given by [itex]k = \frac{a}{\sqrt{3}}[/itex]"
I drew a rectangle of sides 2a and 2b and then drew an axis through the centre of the rectangle and parallel to the 2b side and labelled it y.
Then
[tex]I_{y} = \int_{-b}^{b} y^2 dm[/tex]
I divided the sheet into strips perpendicular to the axis, each having a mass [itex]dm = \sigma dA = \sigma 2a dy[/itex] where [itex]\sigma[/itex] is the mass per unit area.
So, [tex]I_{y} = \sigma 2a \int_{-b}^{b} y^2 dy = \sigma 2a \left[ \frac{y^3} {3} \right]_{-b}^{b} \Rightarrow I_{y} = \sigma 2a \frac{2b^3} {3}[/tex]
Now [tex]M = \sigma A = \sigma 2a 2b \Rightarrow I_{y} = \frac{Mb^2} {3} = Mk^2 \Rightarrow k = \frac{b} {\sqrt{3}}[/tex]
I don't understand why my integration is wrong.
Thanks.
You are mistaking your axes for the integration.
To find Iy you need to (using rho as mass per area):
[tex]I_{y} = \int_{-a}^{a} x^2 dm[/tex]
[tex]I_{y} = 2 \rho b \int_{-a}^{a} x^2 dx[/tex]
[tex]I_{y} = \frac{2 \rho b}{3} (a^3 - (-a^3))[/tex]
[tex]I_{y} = \frac{4 \rho b}{3} a^3[/tex]
Now you can say that [tex]M = \rho 4 a b[/tex]
That leaves you with:
[tex]I_y = k^2 M[/tex]
[tex]\frac{4 \rho b}{3} a^3 = \rho 4 a b k^2[/tex]
[tex]k = \frac{a}{\sqrt{3}}[/tex]
Oh damn it! Thank you :smile:.
  • · Replies 26 ·
