How much commutativity in associativity
  • Context: Undergrad
  • Thread starter Thread starter Kocur
The discussion revolves around the relationship between commutativity and associativity in binary operations, particularly focusing on the operation of addition. Participants explore whether an operation can be associative without being commutative, and they examine examples from group theory and matrix multiplication.
  • Some participants assert that an operation "+" is associative if it satisfies the condition x + (y + z) = (x + y) + z for all elements x, y, and z.
  • Others argue that if "+" is non-commutative, different results may arise depending on the order of operations, which raises questions about the validity of associativity in such cases.
  • A participant mentions that in a group (G,+), if the operation is abelian (commutative), then it is also associative, but this does not imply that non-commutative operations cannot be associative.
  • Matrix multiplication is cited as an example of an operation that is associative but not commutative.
  • Some participants challenge the reasoning behind the assertion that associativity requires commutativity, suggesting that the two properties are independent.
  • One participant presents a constructed operation that is commutative but not associative, illustrating the independence of these properties.
Participants express disagreement regarding the necessity of commutativity for associativity. While some believe that associativity cannot exist without commutativity, others argue that the two properties can be independent. The discussion remains unresolved with multiple competing views.
Some arguments rely on specific definitions and properties of groups, which may not be universally applicable. The discussion also touches on the implications of non-commutative operations on the results of expressions involving addition.
Kocur
How much commutativity in associativity?
Please correct me if I am wrong.
By the definition, binary operation "+" on set S is associative if and only if, for all elements x, y, and z from S, the following holds:
x + (y + z) = (x + y) + z.
In other words, the order of operation is immaterial if the operation appears more than once in an expression.
Now, operation "+" may be either commutative or not. Let us consider the later case. If "+" is not commutative, we have the following:
x + (y + z) may be different from x + (z + y) and
x + (y + z) may be different from (y + z) + x and
x + (y + z) may be different from (z + y) + x.
Thus, the result of x + (y + z), depending on the way the operation is performed may by different from the result of (x + y) + z.
The whole problem disappears whenever "+" is commutative.
So, can we really claim that "+" is associative without referring, maybe even not explicitly, to commutativity?
Kocur.
Huh? If your operation is associative, then no, the result will not be different. What does:
have to do with whether or not (x + y) + z = x + (y + z)?
We can as long we're speaking about a group with addition.
Let (G,+) be a group.
Proposition
(G,+) abelian--------->"+" associative.
In the following,the "x","y" & "z" are elements of the group.
x+y+(-(x+y))=0 (1) ("x+y" is an element of the group (closure) and it has an inverse wrt "+")
From (1) it follows that
-x+x+y+(-(x+y))=-x =>y+(-(x+y))=-x=>-y+y+(-(x+y))=-y+(-x)=>-(x+y)=-x+(-y) (2) (i used commutativity of addition & inverses)
Consider the expression
x+(y+z)+(-(x+y))+(-z) (3)
If i show that (3) =0,then,from the inverse property and commutativity (meaning i can add both to the left & to the right)
x+(y+z)=(x+y)+z ,which is what i should be proving.
x+(y+z)+(-(x+y))+(-z)=x+(y+z)+(-x)+(-y)+(-z)=x+(-x)+(y+z)+(-(y+z))=0
Q.e.d.
dexter, the question was whether an operation can be associative without being commutative, not that being commutative implied being associative. Also, I don't think you mean to call G a group, since the group operation is associative by definition.
Also, here you have:
-x+x+y+(-(x+y)) = -x --> y+(-(x+y)) = -x
but this does not follow. I'm going to write xy instead of x + y, and I (for identity) instead of 0. You started with:
[tex](xy)(xy)^{-1} = I[/tex]
then you said:
[tex]x^{-1}[(xy)(xy)^{-1}] = x^{-1}(I) = x^{-1}[/tex]
which is a correct inference. You then concluded that
[tex]x^{-1} = x^{-1}[(xy)(xy)^{-1}] = [x^{-1}x][(y)(xy)^{-1}] = I[(y)(xy)^{-1}] = [(y)(xy)^{-1}][/tex]
But the second equality presumes associativity, so the proof fails.
Matrix multiplication is associative, but not in general commutative.
Well, I just wanted to show, that if "+" is non-commutative, we can obtain different results for x + (y + z), depending on the order in which we perform operations.
The results for (x + y) + z may also be different, due to the same reason.
It follows that (x + y) + z might be different from x + (y + z).
Dextercioby:
I was thinking about something else. Namely, I was trying to show that the order in which non-commutative operations are performed is always important. Thus, I am not sure if we can talk about associativity in such a case :confused:.
AKG:
You got it right in your second post.
Arildno:
You are right.
Yes you *can* but you are not necessarily guaranteed to do so, and indeed if '+' is associative you are guaranteed *not* to. And? The commutativity or otherwise of * is neither here nor there.
Here is an operation that is commutative but not associative:
define * on {a,b,c} by a*b=b, a*a=c and c*b=a extending to commutativity by fiat and thence to any binary operation on {a,b,c}. Any choice of extension wil do
Then (a*a)*b=c*b=a, yet a*(a*b)=a*b=b
That can easily be adapted to give an operation that is neither associative or commutative by losing the "by fiat" bit and say decalring b*a=c
matrix multiplication is associative but not commutative
and addition on R is both associative and commutative, therefore all 4 possibilities can occur, and the properties are seen to be completely independent!
Note, Dexter, how come you 'prove' the operation in an abelian group is associative? That is part of the definition of group. Did you mean to say that in an abelian group some of the axioms are redundant?
If "+" is non-commutative, then there's nothing to show. If "+" is non-commutative, then that means precisely that we can obtain different results depending on the order we perform operations. Well actually, it's not the order of operations (that's the idea behind associativity), it's the order that we put the elements that we're operating on. Associativity says that (x + y) + z = x + (y + z). The two plus signs in each expression of the equation are the operations, and associativity is saying that the order of doing the operations don't matter, you can go left to right or right to left. Commutativity says that x + y = y + x. That is, the order in which you put the elements you're operating on doesn't matter.
It absolutely does not if we're assuming "+" is associative, which is what your first post appears to do. It says that we cannot say that "+" is associative without referring to commutativity, that is, an operation cannot said to be just associative but non-commutative. However, that's wrong, and nothing you've done even suggests otherwise. You've basically demonstrated what non-commutativity means, that a sum written in different orders might be different. Where in the world you get from this that associativity might not hold, I have no idea.
As far as I can tell, you might be hoping to prove it based on something like this:
[tex]a \neq b \neq c[/tex]
Therefore
[tex]a \neq c[/tex]
Replace a and c with 5, and b with 3, and see if this is valid. If this is not what you're thinking, then I honestly have no clue why you believe that something in your posts shows that associativity requires commutativity.
I think that you are right AKG. Thank you for helping me out of confusion.
Kocur.
Did you not read my post where I gave expicit binary operations that show that commutativity and associativity are unrelated?
  • · Replies 26 ·
  • · Replies 0 ·
