Why Does the Cylindrical Shells Method Give a Different Volume for a Torus?
The cylindrical shells method for calculating the volume of a torus can lead to discrepancies if the integral setup is incorrect. The integral presented, \int_{R-r}^{R+r} 4 \pi x \sqrt{1-x^2} \Delta x, fails to account for the correct geometric relationships between the torus radius (R) and the circle radius (r). A conceptual flaw arises from not clearly defining the dimensions and orientation of the shapes involved. For accurate results, it is essential to refer to the coordinate plane and ensure precise definitions of the radii and the rectangle's dimensions.
  • Understanding of integral calculus, specifically volume calculation techniques.
  • Familiarity with the cylindrical shells method for volume integration.
  • Knowledge of geometric properties of a torus and circles.
  • Ability to interpret and manipulate mathematical expressions involving integrals.
  • Study the application of the cylindrical shells method in various geometric contexts.
  • Learn about the geometric properties of a torus and how they relate to volume calculations.
  • Explore the concept of defining shapes in the coordinate plane for clarity in integration.
  • Review the integration of volumes using the difference of two volumes method for comparison.
Mathematicians, engineering students, and educators seeking to deepen their understanding of volume calculation methods, particularly those involving complex shapes like a torus.
ktpr2
I know one can figure the volume of a torus by the difference of two volumes, but I'm trying out the method of cylinderical shells. As far as i understand, you can often create a primitive with a calcuable volume and approximate the volume of the shape you wish by scaling the primitive along the curve it creates, adding infinitely many times.
The problem is that my answer is wrong when i try to set up an integral when thinking in terms of cylinderical shells:
We have a rectangle, bent in the shape of a circle, with length [tex]2 \pi r[/tex] height [tex]\sqrt{1-x^2}[/tex] and width[tex]\Delta x[/tex], so it's volume should be all that multiplied together.
I have torus radius (this torus is just a circle, really) of R and the circle being revolved has a radius of r. So my integral is:
[tex]\int_{R-r}^{R+r} 4 \pi x \sqrt{1-x^2} \Delta x[/tex]
and the above is off by [tex]r^3 R[/tex] when i use differences of two volumes, what conceptual flaw am I making?
You should better define your intended torus, be more specific with which radius is which, and what you mean by rectangle, the length, and the height with respect to.
http://whistleralley.com/torus/torus.htm does a good explanation of the general integration of a torus.
If you wanted to try again, an easier way to explain your situation (even for yourself) is to refer everything to the coordinate plane, i.e.
A line drawn from the origin along the x-axis to a point (R,0) is the center of a circle with radius r. The volume of the torus created by rotating the figure described is given by integrating the area of the torus along the path of revolution... etc etc
Hmm, i'll see if casting things in that light simpifies things.
  • · Replies 18 ·
