What is the difference between pound-mass and pound-force in HVAC equations?
  • Context: Undergrad
  • Thread starter Thread starter russ_watters
The discussion revolves around the distinction between pound-mass and pound-force within the context of HVAC equations, particularly focusing on the derivation of a velocity pressure equation and the interpretation of density units on psychrometric charts.
  • One participant expresses confusion about whether "pounds" on a psychrometric chart refers to mass or weight density, specifically questioning if 14 lb/ft³ is mass or weight density of air.
  • Another participant mentions a discrepancy between an equation in a flow-hood manual and their own "cheater" equation, indicating that the manual's equation may be incorrect.
  • A participant provides a derivation involving pressure differences and density, leading to a velocity equation that approximates the constant 4005, suggesting that better conversion factors yield results close to this standard constant.
  • One participant suggests that the constant 4005 is derived from rounding in the ASHRAE handbook and points out a correction needed in the referenced equation regarding the placement of density under the square root.
  • Several participants share their experiences of confusion with unit systems, particularly the distinction between mass and weight in the Imperial system compared to the ISO/SI system.
Participants express varying levels of confusion regarding the use of pound-mass and pound-force, with some agreeing on the need for clarity in unit distinctions while others debate the correctness of specific equations and constants without reaching a consensus.
There are unresolved assumptions regarding the definitions of mass and weight in the context of HVAC calculations, as well as potential inaccuracies in the referenced manual's equations.
I'm having a slow day (pun intended) today, and I need a little help. I'm getting pound-mass and pound-force mixed up in my head. On a psychrometric chart, it just says "pounds", but is 14 lb/ft^3 the mass or weight density of air? I've been using cheater equations for the past few years, but now I need to do derive the typical hvac cheater equation for pressure vs velocity:
VP=4005 V^1/2
VP = velocity pressure in inchess of water
V = Velocity of air in feet per minute
So where does the 4005 come from...?
Ok, so it would appear that I'm not a complete idiot. See, the problem my boss and I were having is that we were not able to reconcile equation 1 on PDF page 55 http://www.alnor.com/downloads/manuals/1980497B.pdf with our "cheater" equation. The problem -- the equation is wrong in our flow-hood manual. Still, I'd like to finish the derivation...
(P1-P2)/Rho = V^2/2g (P1 is the total pressure, against the flow, and P2 is the static pressure, perpendicular to the flow, of the measurement)
Density of air at STP is, approximately, 0.075lbm/cu.ft.
1lbf/sq.ft = 0.1922 inches wg
g = 115820 ft/min^2
So, V = [2g(P1-P2)/Rho]^1/2 = [2x115820(VP)/(0.075x0.1922]^1/2 = 4008.66(VP)^1/2
Better conversion factors yield the result close to the standard constant 4005.
(eh.. with all hatred towards IP system) Change that g to gc (32.2 lbm.ft/lbf.sec^2)
By the way, the constant 4005 is derived not because better unit conversions are used but the decimal value is chopped off (courtesy : ASHRAE handbook of fundamentals 2005)
Only correction required to the eq. given in the above reference is to put the density under the square root.
Thanks - I must've worked on that for an hour and couldn't get my units straight. I've only been in "the real world" for 4 years and already I'm starting to get rusty...
I know the feeling! Possibly the best thing about the ISO/SI system is that it forces a clear distinction between mass and weight?
One of the primary reasons I prefer metric/SI! IP is so . . .
10K
  • · Replies 131 ·
9K
