Can You Solve These Challenging Partial Differentiation Problems?
  • Thread starter Thread starter dagg3r
    Hard Partial
The discussion focuses on solving challenging problems related to partial differentiation, specifically finding the partial derivative of the function z = 4y^3 * sqrt(x) - ln(4xy^3) + 2x with respect to y, and determining the stationary point of the function z = 5x^2 + 23x + y^2 + 8y + 3xy + 32. The correct partial derivative is confirmed as ∂z/∂y = 12y^2 * sqrt(x) - 3/y. The stationary point is found to be (2, -1) with a corresponding z value of 85, indicating a minimum point based on the second derivative test.
  • Understanding of partial differentiation
  • Familiarity with the chain rule and product rule in calculus
  • Knowledge of stationary points and their significance in multivariable functions
  • Ability to apply the second derivative test for determining the nature of stationary points
  • Study the application of the chain rule in partial differentiation
  • Learn about the second derivative test for functions of multiple variables
  • Explore the implications of stationary points in optimization problems
  • Review advanced topics in multivariable calculus, including Hessian matrices
Students and professionals in mathematics, engineering, and physics who are dealing with multivariable calculus and optimization problems, particularly those focused on partial differentiation and stationary points.
dagg3r
HI GUYS
i just have some hard problems on partial differentiation... hope you guys can help out
1. find "day z / day y" its the funny backwards 6 symbols instead of the normal differntiation symbole
if z=4y^3 * sqrt(x) - ln(4xy^3) + 2x
i did this:
i diffenriated 4y^3 * sqrt(x) with respect to y, and since sqrt(x) stays constant, it remains hence i get
12y^2*sqrt(x) . i then diffed ln(4xy^3) + 2x
i did
ln(u)
u=4xy^3 u`= 12xy^2
=1/u * u`
=(1/4xy^3) * 12xy^2
= 3/y
and the 2x disappears
hence my ultimate answer is
"day z/ day y"=12y^2*sqrt(x) - 3/y
2. FInd the stationary point of
z= 5x^2 + 23x + y^2 + 8y + 3xy + 32 amd determine the nature of this point
day z / day x = 10x + 23 + 3y
day z / day y = 2y + 8 + 3x
use elimination hence
10x + 23 + 3y *2
2y + 8 + 3x * 3
20x + 46 + 6y 3)
6y + 24 + 9x 4)
11x -22 = 0
x = 2 sub this into eqn 3)
y= -43/3
now sub x=2, y=-43/3 into z=
hence z=5(2)^2 + 23(2) + (-43/3)^2 + 8(-43/3) + 3*(2)(-43/3) + 32
z=925/9
hence stationary points i think are (2, -43/3 , 925/9)
ok assuming that's right i have to determine the nature of the point, to my knowledge i would have to
use the formula g= (day^2 z/day*x^2)*(day^2 z/ day*y^2) - ( day^2*z / day*x*day*y )
day^2 z / day^2 x^2 = 10
day^2 z / day^2 y^2 = 2
day^2*z / day*x*day*y = 3
hence g = (10)*(2) - 3
G= 17
HENCE 17 > 0 , AS (day^2 z / day^2 x^2) IS > 0, AND G> 0, THEN THE STATIONARY POINT IS A MINUMUM POINT
I THINK I DID IT WRONG HAVE NO IDEA
isnt der of z wrt y of sqrt(x) = 0
Yes, it is that's why the derivative of [tex]4y^3\sqrt{x}[/tex] is
[tex]12y^2\sqrt{x}[/tex] just as dagg3r says- even if you use the "product rule". What did you think the derivative should be?
The partial derivative of [tex]z= 4y^3\sqrt{x} - ln(4xy^3) + 2x[/tex]
with respect to y is:
[tex]\frac{\partial z}{\partial y}= 12y^2\sqrt{x}- \frac{1}{4xy^3}\left(12xy^2)\right)[/tex]
= [tex]12y^2\sqrt{x}- 3y[/tex] exactly what dagg3r had!
(Click on the TEX above to see the code I used- your "day" is driving me mad! I would have preferred you just use "d" with the notation that it is partial differentiation.)
Okay, you got
[tex]\frac{\partial z}{\partial x}= 10x+23+ 3y[/tex]
and
[tex]\frac{\partial z}{\partial y}= 2y+ 8+ 3x[/tex]
Of course, at a stationary point, the partial derivatives are 0:
10x+ 3y+23= 0 and
3x+ 2y+ 8= 0 (You did not write "= 0". While I understood what you were doing, the "= 0" makes it clearer. Also I have written the two equations with x first, then y. That also makes it a little simpler to see what to do.
Yes, multiply the first equation by 2 and the second by 3, to get "6y" in both and then subtract:
20x+ 6y+ 46= 0
9x+ 6y+ 24= 0
which gives
11x+ 22= 0.
You subtracted wrong! (That might be because of the way you had written the equations.)
x= -2, not 2, and then, from the second initial equation, -6+ 2y+ 8= 0 so
2y= -8+ 6= -2, y= -1. The stationary point is at (2, -1).
z(2, -1)= 5(4) + 23(2) + (-1)^2 + 8(-1) + 3(2)(-1) + 32
= 20+ 46+ 1- 8- 6+ 32= 85.
NOW determine the nature of the stationary point.
