How to Estimate Contact Time Between Racquet and Tennis Ball?
  • Thread starter Thread starter standardflop
The discussion revolves around estimating the contact time between a racquet and a tennis ball, assuming a constant force acts on the ball. The known parameters include the final speed of the tennis ball after the stroke and its reduced dimensions during contact.
  • Participants explore various methods to estimate contact time, questioning the assumptions about the motion of the ball's center of mass and the effects of force during contact. Some participants suggest using impulse and energy equations, while others raise concerns about the initial conditions and the distance over which the force is applied.
The discussion is active, with participants providing different interpretations and approaches to the problem. Some have offered calculations based on their assumptions, while others have questioned the validity of those assumptions and the implications of the applied force and distance.
Participants note the importance of considering the compression of the ball and the motion of the racquet, which may affect the assumptions about the force application distance. There is also mention of the need to clarify the initial conditions and the relationship between average and final velocities in the context of constant force.
standardflop
which is the best way to estimate contacttime between racquet and a tennisball, under assumption that the force acting is constant? Also known is the speed of the tennisball after the stroke, v=27.8 m/s (100km/t), and the dimension of the ball under the stroke is half of normal.
The force of the racket on the tennis ball has the effect of accelerating the tennis ball's center of mass. If the radius of the tennis ball is R, then the center of mass of the tennis ball is initially a distance R/2 from the racket (the dimension is half according to your description). Please tell me if I have interpreted something wrong so far. What are your given quantities?
The contact time for this phase of the stroke will then be the time it takes for the center of mass to move from R/2 to R, why? Can you find this time in terms of given quantities using your knowledge of the final velocity?
Using the assumption that the center of mass under the stroke will move 2R i got the result t=5.8ms. this sounds fair, i guess..
found it using, m=0.1kg R=4cm and:
F=Ekin/2R and then t=mv/F=5.8ms
How did you decide that the center of mass would move 2R? You need to be careful about what you assume the initial condition is. I described one possible phase of the stroke above, but you need to ask yourself, based on the initial conditions, just exactly what the full stroke is.
I think the question expects one to assume that the force is applied over the compression distance (d/2 or R).
If you assume that the force is constant, F, for a time [itex]\Delta t[/itex] the impulse [itex]F\Delta t[/itex] is equal to the momentum of the ball. Also, [itex]Fd/2 = mv^2/2[/itex] where d is the diameter of the ball.
Combine the two equations to get rid of m to find the time and you end up with:
[tex]mv/\Delta t = mv^2/d[/tex]
[tex]\Delta t = d/v[/tex]
But I don't think it is a reasonable assumption. The racquet is moving and the racquet strings contract as the ball remains in contact with the racquet. You have to take into account the distance that the force is applied through in the original frame of reference (of the stationary tennis court). This could be considerably larger than half the diameter of the ball.
AM
I think all you need to do is , considering absence of any external forces , the Force applied over time 't' would give impulse tot he ball initially assumed to be at rest.
So F.t = Change in momentum
This would give you the answer including the compression effects , which would lead to only internal forces.
BJ
BJ
That gives you the impulse. How do you work out just the time without knowing F? In order to determine F one has to use energy and the distance over which the force applies. My point is that distance is greater than the distance the ball compresses.
AM
another thing i wondered about was:
using the following two eq.s ( [itex]F \Delta x = 1/2 mv^2[/itex] and [itex]F \Delta t = mv[/itex]) you could solve and find
[itex]\Delta t = 2 \Delta x /v[/itex]. why is this result different (by factor 2) than the well known [itex]x = x_0+v t[/itex]? and which is the "right" to use?
Remember the velocity in [tex]\Delta t = 2 \Delta x / v_f[/tex] is the final velocity, while the velocity in [tex]\Delta x = v_a \Delta t[/tex] is the average velocity. What is the relationship between [tex]v_f[/tex] and [tex]v_a[/tex] for a constant force (assuming the system starts at rest)?
14K
11K
