View Single Post
Nov20-05, 06:52 PM   #1
help with an algorithms
Hello math crew!
Here's the problem: http://www2.edc.org/makingmath/mathp...ins/trains.asp
just in case somebody doesn't want to click on the above link,
trains:
You can use rods of integer sizes to build "trains" that all share a common length. A "train of length 5" is a row of rods whose combined length is 5. Here are some examples:
Notice that the 1-2-2 train and the 2-1-2 train contain the same rods but are listed separately. If you use identical rods in a different order, this is a separate train.
* How many trains of length 5 are there?
* Come up with a formula for the number of trains of length n. (Assume you have rods of every possible integer length available.) Prove that your formula is correct.
* Come up with an algorithm that will generate all the trains of length n.
Now I solved this problem, at least I think I solved it.
A formula for the number of trains of length n will be
a=length of a train
h=how many trains of a given length
2^(a-2) + 2^(a-3) + 2^(a-4)+........+ 2^2 + 2^1 + 2^0 = h
if a > 3
I'm not truly sure, if this formula is right, it works for 4,5,6,7 and seems to work for every length above 7, it doesn't work for lengths 1,2,3 though,
Also I have a problem with an algorithm.
Can anyone help me make one, or at least give some clues ont "how to make a good algorithm?" (eventually you may post some good books on algorithms. I got some books in my eye on algorithms, however still have not enough money or time to read 'em)
thanks for all the help fellows,
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> Ants and carnivorous plants conspire for mutualistic feeding
>> Forecast for Titan: Wild weather could be ahead
>> Researchers stitch defects into the world's thinnest semiconductor
