Check my work on torque and angular velocity
The discussion revolves around a physics problem involving torque and angular velocity, specifically in the context of an athlete performing on a high bar. The original poster presents calculations for torque at various angles and seeks to understand the relationship between torque, angular acceleration, and angular velocity throughout the motion.
  • Exploratory, Conceptual clarification, Mathematical reasoning, Problem interpretation, Assumption checking
  • The original poster attempts to calculate torque at different angles and questions how to determine angular velocity based on these torque values. They explore the implications of angular acceleration and the effects of friction on the system. Some participants suggest re-evaluating the calculations and considering the time intervals for angular displacement.
Participants are actively engaging with the problem, offering insights into the calculations and questioning the assumptions made by the original poster. There is a mix of attempts to clarify concepts and provide alternative approaches, but no explicit consensus has been reached regarding the final calculations or interpretations.
There are ongoing discussions about the assumptions related to time intervals for torque application and the implications of negative torque values. The original poster expresses urgency regarding submission deadlines, indicating the need for timely feedback.
NotaPhysicsMan
Hey, here's the question:
You are an athlete on the high bar in a fully extended position 180 degrees from the right horizontal.
My weight: 667.08N
Center of mass:80.5cm
Radius of gyration: 122 cm
1)Calculate the torque at the beginning of the bar and for every 30 degrees until the rotation stops or changes direction. Assume that friction from bar produced a constant torque a 30 Nm.
http://www.geocities.com/mvxraven/gymnastdiagram.JPG"
So from my diagram:
sum(torque) at horiziontal=0
0=(F1xd) + (-(30Nm))
=(667.05*0.805)-30
=506.9 Nm
I can tell it's angular velocity is increasing by: angular acceleration=T/I
in this case a=+ve.
sum(torque) at 30degrees=0
=(667.05)(0.805cos30)-30
=435.03 Nm
a=+ve, so still not slowing down or changing direction
sum(torque) at 60 degrees=0
=(667.05)(0.805cos60)-30
=238.49 Nm
a=+ve still.
sum(torque) at 90 degrees=0
=(667.05)(0)-30
=-30Nm
Angular acc (a)
a=-ve, so it means a change in direction or stopping?
2)calculate the angular velocity at each position assuming that the torque from the previous position was applied for a period of 0.1s.
Ok, so this is just w=@2-@1/t
so should I be taking the @1 as 0, or 180 degrees?
if @1=0 then @2=30 degrees or 0.523rads.
And I just 0.523-0/0.1s = 5.23rads/s
and the next one is similar @2=60, and @1=0
so 1.04rads/0.1s or should it be 1.04/0.2s?
...etc
Anyone? It would be much appreciated :p
Did I at least get the concept of the question right?
Just wanted to bump this up. I'll take any advice, really.
So...nobody knows how to do this question? or has any ideas? :cry:
With that many views, but no responds. Please help with this question.:confused:
Ok I might have figured something out,
I tried to rework it...I still get the same values for the torques. Now using cons. of mechanical energy path to find ang velocity:
angular velocity for the first at 180 degrees is 0.
But for the the one at 60 degrees or 30 degrees depending on which reference you use, the angular velocity is:
PE=mgh (h being my center of mass) I don't understand why in your example you have 1/2 mgh??
KE=0
KERotat=1/2Iw^2, I=mk^2, I =68(1.25^2), I =106 kgm^2
ok so at that point
PE=KErot
mgh=1/2(106)(w^2)
68*9.81*0.805=53*w^2
537=53w^2
w=(squroot)(537/53)
w=3.2 rad/sec.
So...How is this value going to change overtime, because I can't see a value in the equation that will change as I change every 30 degrees. Everything stays practically the same...Except maybe h? (but that's just the value of center of mass, shouldn't change).
Please do help, I really tried. :smile:
Your exercise seems to be Torque (which you've done okay)
as a cause of angular momentum or angular velocity. (Postpone Work and PE.)
Now, if the Torque you had at the beginning acted on a rigid object
with your radius of gyration, what angular acceleration would there be?
starting from zero angular velocity, how long would it take to travel 30 degrees (=pi/6 radians)? (recall, ½at^2)
How fast (angularly!) would you be going by the time you've moved 30 degrees?
Now do the same thing for the next sector (a spreadsheet might help ...)
Thanks for the response: I tried it immediately:
So, to your question about angular acceleration. At that position I'd have a positive ang acceleration or one that can be calculated as:
a(angular acc)=T/I, I=mk^2 (k=radius of gyration)
So, 506.9Nm/(68x1.25^2)=4.77rad/s^2.
Now to find the angular velocity (w) :
so to move that distance or 30 degrees. I'd have to be moving a distance of 0.524 rads.
Using your d=1/2at^2, or @(ang displacement)=1/2at^2
so 0.524rads*2/4.77=t^2
t=0.47s? with that time value I sub into w(ang vel)=@/t
w=0.524/0.47s
w=1.11 rad/s?
Hope that works but I wonder where this part of the question comes in
torque from the previous position was applied for a period of 0.1s.<<--where do I ever use the 0.1s?
your w = 1.11 [rad/s] is the average angular speed in that interval ...
(w_f + w_i)/2 = 1.11 [rad/s] . so , w_f = 2 w_avg - w_i = 2.22 [rad/s].
Use this for the w_i in the next interval , etc.
You did better than presuming 0.1 for the acceleration,
you found out how long it lasted. 30 degrees is a bit coarse, but it's a sim.
Ok,
hmm. I guess I could have used a(ang acc)=w(final)- w(initial)/time.
Ok, just let me see if I can the second one then:
So with the second torque, the ang accel is 4.07rad/s^2 (which decreased, makes sense starting to slow down)
For @(ang displacement) I'm now using 60degrees with respect to horizontal. I had consider using 180+60 because that is the 180 degree mark, but I found the calculation screwed up, got negatives...
anyway,
time I found to be 0.71s.
so a(ang accel)=(w2-w1)/t
4.07=(w2-2.2)/0.71
w2=5.09rad/s (which makes sense because ang vel still increasing as you go down.)
Last question, my assumption that since torque is negative, acts in opp direction of ang velocity, this is essentially where he stops or slows down and I stop calcuations?
Ok, if this is correct, I thank you. Much simpler than I had thought...:smile:
No, if alpha = 4.07 [rad/s^2],
then .507 [rad] = 2.22 [rad/s] t + ½ 4.07 [rad/s/s] t^2 , so t is 0.194
ok, I see.
So then 4.07=(w2-w1)/t
(4.07*.194)+2.2=w2
w2=2.98
Wait, couldn't I just use time as 0.1s for the first sec. then 0.2s for the second, then 0.3 s for the third. It'd be so much more simpler and less calcuations...
Also, one critical question. It says when it stops or changes direction, stop calculations...Doesn't that mean when the torque is smaller than the frictional force?? I can do up to 90 degrees but everything after seems a bit messy. Do I use 120 degrees for the next one or just 60 degrees again?
Ok using excel, and using time values not through the quadratic method(hope that still worked) I got the folliwn values
Code:
angle   radian    Torque   ang acc.   d time    ang vel(w1) angular(w2)
0.00	0.00	506.98	4.77	     0.00	          0.00	   2.22
30.00	0.52	435.04	4.09	     0.10	          2.22	   3.04
60.00	1.05	238.52	2.24	     0.20	          3.04	   3.71
90.00	1.57	-29.94	-0.28	     0.30	          3.71	   3.60
120.00	2.09	-298.42	-2.81	     0.40	          3.60	   2.20
150.00	2.62	-494.98	-4.66	     0.50	          2.20	   -0.60
180.00	3.14	-566.98	-5.34	     0.60	           ----	   ----
Ok, so does the negative angular velocity mean I have stopped and now going the opp direction??
I feel good if I'm right lol.
Someone please check. I have to hand it in tomorrow morning at 9:00 or it's 10 % off my head.I really need this. :cry:
ah crap, half n hour before sleep...bump bump bump lol
  • · Replies 30 ·
  • · Replies 35 ·
  • · Replies 17 ·
  • · Replies 25 ·
