Integral - what does it represent?
  • Thread starter Thread starter Benny
    Integral
The discussion revolves around the interpretation of a specific integral related to vector fields, particularly focusing on the concept of flux across a surface. Participants are exploring the meanings of the integral and its components, including the outward unit normal vector and the implications of the integral in terms of flow across a surface.
  • Participants are questioning the meaning of the integral and its relation to physical concepts like flow and surface interactions. There is also a discussion about the definitions of the variables involved, particularly "S" and "D".
Some participants have provided clarifications regarding the interpretation of the integral as representing flow across a surface. There is acknowledgment of the need for careful definition and understanding of the variables involved. The conversation is ongoing, with participants sharing insights and seeking further clarification.
One participant notes a common procedure of rewriting the integral in terms of a normal vector and suggests that further work is needed to transition from a surface integral to a double integral over a domain in the xy-plane. There is also a mention of the Divergence theorem as a relevant concept in this context.
Benny
Hi, I am given the following integral.
[tex] \int\limits_{}^{} {\int\limits_S^{} {\mathop F\limits^ \to } } \bullet d\mathop S\limits^ \to = \int\limits_{}^{} {\int\limits_D^{} {\mathop F\limits^ \to \bullet \mathop n\limits^ \to } } dS[/tex]
The n vector is an outward unit normal. So does the RHS of the above represent how much 'stuff' is coming out of a surface? Or does it have something to do with what is happening on a surface? The book says that the integral is called the flux of F across S. In many examples, there are little arrows point out of the surface so I'm not sure what the integral is supposed to represent.
Any help would be good thanks.
Yes, both of those can be interpreted to represent the total "flow" of something across the surface (so that flow in opposite directions at different parts of the surface cancel). I am, however, puzzled over what "S" and "D" are. For those to be equal, in general, S and D must be the same.
D and S are right next to each other on one's keyboard.
Oops, I need to be more careful when copying out the definitions. Thanks for the help.
Edit: In many of the questions I've been doing, the procedure is generally to rewrite the integral so that the dS is repalced by ndA where n is a normal to the surface. After the replacement, instead of integrating over a surface, is the integration done over the x-y plane?
The form you put above is still a surface integral on either side, further work is required to change such into a double integral over a domain D in the xy-plane; one such way is to parameterize the surface by, say [itex]\vec{r}(u,v)[/itex] where the parameters u and v range over values in D, the formula is then
[tex]\int\limits_{}^{} {\int\limits_S^{} {\mathop F\limits^ \to } } \bullet d\mathop S\limits^ \to = \int\limits_{}^{} {\int\limits_D^{} {\mathop F\limits^ \to \left( \vec{r}(u,v) \right) \bullet \left( \vec{r}_{u} \times \vec{r}_{v}\right) } } dA[/tex]
Ok thanks for the clarification. I've been working through some questions using the procedure you've presented during the last few days so I'm fairly comfortable with them now.
[tex]\int\limits_{}^{} {\int\limits_S^{} {\mathop F\limits^ \to } } \bullet d\mathop S\limits^ \to = \int\limits_{}^{} {\int\limits_S^{} {\mathop F\limits^ \to \bullet \mathop n\limits^ \to } } dS[/tex]
Just different ways of writing the same thing:
[tex]d\mathop S\limits^ \to[/tex] is defined as [tex]\mathop n\limits^ \to } } dS[/tex]
Yes, it can be interpreted as "flux of F across S"- that is, the rate at which some property (whatever F represents) is flowing through surface S. One way to interpret the Divergence theorem:
[tex]\int\int\int\limits_B^{ } (\nabla \bullet \mathop v\limits^ \to )dV= \int\int_S \mathops v\limit^ \to \bullet d\mathop \sigma\limit^ \to[/tex]
is that the amount of something inside region B depends upon how much is flowing in or out through the surface S.
16K
